Re: 572 engine, PG or 727 trans?
[Re: fast68plymouth]
#2978251
10/25/21 01:28 PM
10/25/21 01:28 PM
Posts: 31,261 Oregon
AndyF
I like the idea of the “all new” trans built with all the components designed for the rigors of drag racing. So, budget allowing...... a TH400 or PG based combo would be my choice. Yeah that is my thinking also. These guys have the budget for new parts and they like to tow every weekend to a race so it seems smart to use the good stuff rather than recycle old passenger car parts.
[Re: pittsburghracer]
#2978288
10/25/21 03:51 PM
10/25/21 03:51 PM
Posts: 12,598 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It’s about time you got here. Aren’t you retired like most of us old timers. Lol 😂 Must be comedy to supplement his retirement.
[Re: 440Jim]
#2978293
10/25/21 04:01 PM
10/25/21 04:01 PM
AndyF
I'm leaning towards the PG since they have a couple of other cars with glides in them so they have PG spare parts. Also, the PG can be built with an aftermarket case which is SFI legal while the 727 requires a blanket or shield. I'm not sure which will be quicker down the track. They bracket race so they car about consistency more than ET. My guess is that the PG should work just fine behind the 572 and it might be a tad bit more consistent since it only has one gear change. 900 hp, 572 CID will have plenty of torque to get that car moving with a PG. I highly recommend the aftermarket case (with bell). All the guts should be aftermarket at that level, so there is some choice of 1st gear ratio. Like a straight cut 1.80 gear set. And the Turbo style input shaft with matching converter. I agree. I'm going to recommend that they get a quote from their transmission supplier for a PG. They'll have to make some changes to the car to fit a PG but nothing difficult for a race team. New driveshaft, shifter and crossmember should cover it. I'm assuming the Mopar starter will bolt right back in if the case was built correctly.
[Re: CROWBAR]
#2978366
10/25/21 07:32 PM
10/25/21 07:32 PM
Posts: 10,119 MN
JERICOGTX
MN
Since breaking my 499, and working on building a 563, my Jerico would be a ticking time bomb. Starting from scratch, I wouldn’t even consider a 727. Either a TH400 or Glide. Why not start with an aftermarket case, and much better parts? Better options for gear sets. Options are endless. After weighing out all my options, I came to the best option available...
I ordered a Clutchless Liberty 4 Speed.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2978438
10/25/21 11:32 PM
10/25/21 11:32 PM
Posts: 9,119 Rogue River, OR
Jeremiah
Rogue River, OR
I ordered a Clutchless Liberty 4 Speed. At least something is going in the right direction these days. That is great news and I am exited to see it! I have so many questions.
[Re: Jeremiah]
#2978472
10/26/21 06:27 AM
10/26/21 06:27 AM
Posts: 10,119 MN
JERICOGTX
MN
I ordered a Clutchless Liberty 4 Speed. At least something is going in the right direction these days. That is great news and I am exited to see it! I have so many questions. I'll post a new thread when it arrives. I was very close to pulling the trigger on a ATI TH400 for the car... Would not spend one dime on a stock case transmission at this power level.
69 GTX
68 Road Runner
[Re: Jeremiah]
#2978478
10/26/21 07:00 AM
10/26/21 07:00 AM
Posts: 4,281 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I ordered a Clutchless Liberty 4 Speed. At least something is going in the right direction these days. That is great news and I am exited to see it! I have so many questions. Nice! lol
[Re: dvw]
#2978511
10/26/21 08:55 AM
10/26/21 08:55 AM
Posts: 4,662 Motor City
6PKRTSE
Motor City
I see lots of worries about the 727. Mine runs stock input and output shafts, stock input hub, 3 pin planets. Though I did go to a steel front planet after stripping 2 in aprox 725 passes. It does have aluminum drums and a home modified sun shell. Stranded me 3 times in 9 years. 2 of those were me being to cheap to invest in a steel front planet. The other was an aftermarket aluminum front clutch carrier failure. Who knows how many passes it had. I traded for it used. It was easily repaired and is still in service. Not that there isnt a time and place for a TH400 or a glide. But my 727 has certainly served me well. Doesn't kill clutches or band either. So basically it has a good front drum, Super sprag (though it never hurt the stock one), steel front planet. Like I stated it has some other used aluminum stuff. Front clutch carrier and a rear drum. But neither of those do I consider stronger than stock. Doug Same here. Still running my ole 727 with plenty of street miles. Knock on wood so far so good. May try the billet 2nd gear launch valve body for my next upgrade. Anyone else with results of one of those valve bodies? Good or bad?
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Harry's Taxi 2]
#2978586
10/26/21 12:11 PM
10/26/21 12:11 PM
Posts: 43,913 Bend,OR USA
Cab_Burge
The parts and cases, call them for more info please The Proflyte is a all out drag racing tranny with multiple choices on the ratio and is suppose to be (I've never own one yet ) very easy to maintain at the races and change gear ratios at the track also A good friend of mine ran one for years in a very fast PSCA 10.5 Outlaw car in SO CA , it wasn't a Mopar but it did end up with a Brad Andersen #8 billet blown Hemi motor in it
[Re: Cab_Burge]
#2978621
10/26/21 02:18 PM
10/26/21 02:18 PM
Posts: 10,119 MN
JERICOGTX
MN
The parts and cases, call them for more info please The Proflyte is a all out drag racing tranny with multiple choices on the ratio and is suppose to be (I've never own one yet ) very easy to maintain at the races and change gear ratios at the track also A good friend of mine ran one for years in a very fast PSCA 10.5 Outlaw car in SO CA , it wasn't a Mopar but it did end up with a Brad Andersen #8 billet blown Hemi motor in it Is the Proflyte a SFI case? Or is it a remachined 727 case?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2978625
10/26/21 02:26 PM
10/26/21 02:26 PM
Posts: 4,118 Yes
sixpakdodge
Yes
The parts and cases, call them for more info please The Proflyte is a all out drag racing tranny with multiple choices on the ratio and is suppose to be (I've never own one yet ) very easy to maintain at the races and change gear ratios at the track also A good friend of mine ran one for years in a very fast PSCA 10.5 Outlaw car in SO CA , it wasn't a Mopar but it did end up with a Brad Andersen #8 billet blown Hemi motor in it Is the Proflyte a SFI case? Or is it a remachined 727 case? 727 case. No one makes an SFI Torqueflite case at this time. Most Proflites are 727 cases with 904 internals amongst other rollerized components. Nothing different as far as regular 727 maintenance other than it probably has to be done more often. As far as the whole multiple ratio thing...A&A has a whole gamut of ratios available in their catalog. Being easy to change ratios at the track....no easier than a standard 727. ProTrans, A&A, Joel's on Joy, and A-1 amongst others all build their own version of a Proflite.
[Re: sixpakdodge]
#2978626
10/26/21 02:34 PM
10/26/21 02:34 PM
Posts: 10,119 MN
JERICOGTX
MN
The parts and cases, call them for more info please The Proflyte is a all out drag racing tranny with multiple choices on the ratio and is suppose to be (I've never own one yet ) very easy to maintain at the races and change gear ratios at the track also A good friend of mine ran one for years in a very fast PSCA 10.5 Outlaw car in SO CA , it wasn't a Mopar but it did end up with a Brad Andersen #8 billet blown Hemi motor in it Is the Proflyte a SFI case? Or is it a remachined 727 case? 727 case. No one makes an SFI Torqueflite case at this time. Most Proflites are 727 cases with 904 internals amongst other rollerized components. Nothing different as far as regular 727 maintenance other than it probably has to be done more often. As far as the whole multiple ratio thing...A&A has a whole gamut of ratios available in their catalog. Being easy to change ratios at the track....no easier than a standard 727. ProTrans, A&A, Joel's on Joy, and A-1 amongst others all build their own version of a Proflite. I can understand using something like that when it comes to Class racing, and a 727 case is required, but in a Bracket car, I see no reason it's a better option? How much does a trans like that cost? Seems like no one wants to say...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2978726
10/26/21 07:32 PM
10/26/21 07:32 PM
Posts: 10,637 Rittman Ohio
fourgearsavoy
Rittman Ohio
The parts and cases, call them for more info please The Proflyte is a all out drag racing tranny with multiple choices on the ratio and is suppose to be (I've never own one yet ) very easy to maintain at the races and change gear ratios at the track also A good friend of mine ran one for years in a very fast PSCA 10.5 Outlaw car in SO CA , it wasn't a Mopar but it did end up with a Brad Andersen #8 billet blown Hemi motor in it Is the Proflyte a SFI case? Or is it a remachined 727 case? 727 case. No one makes an SFI Torqueflite case at this time. Most Proflites are 727 cases with 904 internals amongst other rollerized components. Nothing different as far as regular 727 maintenance other than it probably has to be done more often. As far as the whole multiple ratio thing...A&A has a whole gamut of ratios available in their catalog. Being easy to change ratios at the track....no easier than a standard 727. ProTrans, A&A, Joel's on Joy, and A-1 amongst others all build their own version of a Proflite. I can understand using something like that when it comes to Class racing, and a 727 case is required, but in a Bracket car, I see no reason it's a better option? How much does a trans like that cost? Seems like no one wants to say... Probably after the converter and shield it's up there with an Equalizer only less durable Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2978743
10/26/21 08:10 PM
10/26/21 08:10 PM
Cab_Burge
Those guys I'm talking about made a 2900 Lb. car run 6.17 at 234.+ MPH on a 10.5x33x16 tire with one of those trannies. They had switch from a Mikes Monster Glide to the Proflyte when they were running a Ford motor in it with a lot of NOS, they later switch to twin torbos and them to crank driven Pro Charger on c16 and Q16. BobR was involved with that deal for a long time and he finally convince the car owner to switch to a Hemi I'm almost sure they don't use any stock parts in that tranny including the case, call them and find out
