Re: roll bar in a street car?
[Re: justinp61]
#2977289
10/22/21 03:31 PM
10/22/21 03:31 PM
Posts: 4,213 New York
polyspheric
New York
That was so helpful. My point is that they see no reason to discuss decisions that have been made with little input from engineers.
Boffin Emeritus
[Re: jcc]
#2977291
10/22/21 03:35 PM
10/22/21 03:35 PM
polyspheric
New York
I agree, larger diameter is much better, but very difficult to live with in the car. I limit my remarks to a single point of attachment, in which bending allows collapse of the adjacent tubes.
Boffin Emeritus
[Re: justinp61]
#2977375
10/22/21 08:58 PM
10/22/21 08:58 PM
polyspheric
New York
I wrote something about a new product as sarcasm about 30 years ago, can't find it. Ever hear of NIH? A force stronger than the hydrogen bomb, it protects important people from new ideas. Used by all car manufacturers and defense contractors. NIH = not invented here.
Boffin Emeritus
[Re: polyspheric]
#2977380
10/22/21 09:20 PM
10/22/21 09:20 PM
Posts: 11,709 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I agree, larger diameter is much better, but very difficult to live with in the car. I limit my remarks to a single point of attachment, in which bending allows collapse of the adjacent tubes. A properly designed chassis is a series of triangles. To your other comments...I'm certain engineers who are very familiar with the chassis in question, and the forces involved in accidents, are involved in the establishment of these specs and rules. Chassis builders, OE factory engineers, safety experts, sophisticated CAD and analysis, etc. Fuel cars, Pro Stock, NASCAR, Big bucks. That all filters down to the lower classes. Unfortunately, it usually takes someone being killed to cause a serious look at the cars in question and get them updated.
[Re: CMcAllister]
#2977396
10/22/21 09:36 PM
10/22/21 09:36 PM
Posts: 4,704 Wichita
GY3
Wichita
I agree, larger diameter is much better, but very difficult to live with in the car. I limit my remarks to a single point of attachment, in which bending allows collapse of the adjacent tubes. A properly designed chassis is a series of triangles. To your other comments...I'm certain engineers who are very familiar with the chassis in question, and the forces involved in accidents, are involved in the establishment of these specs and rules. Chassis builders, OE factory engineers, safety experts, sophisticated CAD and analysis, etc. Fuel cars, Pro Stock, NASCAR, Big bucks. That all filters down to the lower classes. Unfortunately, it usually takes someone being killed to cause a serious look at the cars in question and get them updated. He's smarter than all those people.
[Re: GY3]
#2977453
10/23/21 02:14 AM
10/23/21 02:14 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
Another question: I haven't installed my subframe connectors yet. If I put in a 6-pt. roll bar, are the connectors still useful? Absolutely! They make a world of difference in a uni-body car! If they are welded to or through the floor!!
[Re: cudadoug]
#2977457
10/23/21 02:39 AM
10/23/21 02:39 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
Another question: I haven't installed my subframe connectors yet. If I put in a 6-pt. roll bar, are the connectors still useful? Absolutely! They make a world of difference in a uni-body car! If they are welded to or through the floor!! Both will work, I've used 2x2 as well as 2x3 .083 rectangular tubing for sub frame connectors in the past ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) It is up to you which size and how to have it installed ![weld weld](/ubbthreads/images/graemlins/custom/weld.gif)
[Re: Cab_Burge]
#2977509
10/23/21 09:29 AM
10/23/21 09:29 AM
polyspheric
New York
2 X 3 is much, much stiffer than 2 X 2, not just the obvious 50% height increase.
Boffin Emeritus
[Re: polyspheric]
#2977526
10/23/21 10:23 AM
10/23/21 10:23 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I agree 2x3 is stiffer, but the roll bar helps too.
[Re: gregcharger72]
#2977564
10/23/21 12:33 PM
10/23/21 12:33 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Do any of you get away with running mid 10 second passes at the drag strip with out a roll bar? my car is primarily a street car that i take to the track a couple times a year. what are your thoughts about roll bars in street cars. I see there are several newer challengers that are that fast and faster and are not required to have roll bars. If you can’t bend/weld a bar in yourself, find a quality shop to install a moly 8.50 cert setup. Make sure you’re at the shop when they’re measuring/cutting and welding-in the main hoop and halo so they can build it around your actual sitting position while in the car. Not sure what belts, seats you’re using, but consider Kirkey’s or seats that would not allow your body and head to flop around a lot in the event of an accident on the street, i.e, keeping your body, head from contacting the main hoop and halo. If most of your time spent in the car is on the street, then I’d install door-side swing-out bars. Lastly, unless you’re wearing some sort of head protection, no way in hell would I ever run a car on the street with a funny car cage. I personally know two guys who died from head injuries when their heads smacked their funny car cage bars on the street. They were driving normal and were hit on the driver and passenger sides of their cars. They weren’t hot-rodding or acting like hooligans, just freak accidents. If anyone were to install or currently has a funny car cage they run on the street there is a company that makes a helmet shaped like a baseball cap that doesn’t look too goofy. It would at least allow you to live most likely.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#2977579
10/23/21 01:34 PM
10/23/21 01:34 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Do any of you get away with running mid 10 second passes at the drag strip with out a roll bar? my car is primarily a street car that i take to the track a couple times a year. what are your thoughts about roll bars in street cars. I see there are several newer challengers that are that fast and faster and are not required to have roll bars. If you can’t bend/weld a bar in yourself, find a quality shop to install a moly 8.50 cert setup. Make sure you’re at the shop when they’re measuring/cutting and welding-in the main hoop and halo so they can build it around your actual sitting position while in the car. Not sure what belts, seats you’re using, but consider Kirkey’s or seats that would not allow your body and head to flop around a lot in the event of an accident on the street, i.e, keeping your body, head from contacting the main hoop and halo. If most of your time spent in the car is on the street, then I’d install door-side swing-out bars. Lastly, unless you’re wearing some sort of head protection, no way in hell would I ever run a car on the street with a funny car cage. I personally know two guys who died from head injuries when their heads smacked their funny car cage bars on the street. They were driving normal and were hit on the driver and passenger sides of their cars. They weren’t hot-rodding or acting like hooligans, just freak accidents. If anyone were to install or currently has a funny car cage they run on the street there is a company that makes a helmet shaped like a baseball cap that doesn’t look too goofy. It would at least allow you to live most likely. Excellent, excellent advice!! As much as most of us do not want to hear that, it is very true. Thanks!!
[Re: Chargerfan68]
#2977613
10/23/21 03:21 PM
10/23/21 03:21 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I agree on using a racing seat and harness if you have a roll bar/cage. Anything lees than that (stock seats and lap belts bar or no bar) and you are at the mercy of a higher power in the case of an accident. The crash tests from the 60-60s era were brutal. One of the reasons I like beating on my cars at the track. Chances of a hard, head on front end collision are much lower with no telephone poles etc. At that point you end up abiding by the rules of where you race and add safety precautions for the street use.
A few things also come into play with design of the cage too. You don't want to be under the hoop. I have seen taller guys do this when laying the seat back or using a factory bench. It is acheived with a kicked out horizonal bar in the hoop instead of running it straight across so it does it's job. Bad place to be without a helmet, padding or not.
The other problem I see with the factory flip up seats of 67 and back is that they do not lock in position. Then you see the harness bolted to the floor behind the seat just right so in an accident the seat will fold you up as both it and you torso get intiment eith the dash. My 66 b bodies both have race seats because of this.
The rules say the hoop must be higher than you helmet so definitely check that as you put it together. For sure use swing out bars unless you are really throwing the world at it lol. I also like forward bars in our unibody mopars. Cab turned me on to the idea of running them outside of the fender apron. Way easier to work on the car with the bars out of the way.
[Re: DrCharles]
#2977615
10/23/21 03:33 PM
10/23/21 03:33 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
Another question: I haven't installed my subframe connectors yet. If I put in a 6-pt. roll bar, are the connectors still useful? Angling two bars that intersect the frame connectors from the main hoop( making it an 8 point) are extremely worthwhile regards chassis rigidity upgrade and making the car “ one piece” In other words, these two angled bars would go through the rear seat footwell and weld to the frame connectors on each side.
[Re: B3422W5]
#2977624
10/23/21 04:20 PM
10/23/21 04:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
In the drivers compartment, the only adjustment to be made to the bar locations would be fore and aft on the main hoop for leg room if using stock steering and pedals. Unless the driver is freakishly short or tall, that's pretty much a standard location. Back in the car a bit. The seat doesn't need to be against it. And the next guy to own it might want the seat to go back. The rest of it gets put in as close to the body/headliner/B pillar/ doors as possible to give as much room as possible. This usually takes some planning and effort to get it all welded up 100%. Helps to get the windshield out, Fast Super Stock and other stock body 25.x type deals or cars like a SN95 Mustang often have the roof removed to get it all done.
Frame ties are 2x3x.083, stood on end through the floor. Mopars get the back of it poked into the front of the stock frame rail, maybe half above and half below the floor. Section it up in so it fits up against the torsion bar X member, Outriggers from the frame rail to the rocker, also sectioned into the floor, provide solid mount points for the cage.
[Re: B3422W5]
#2977625
10/23/21 04:23 PM
10/23/21 04:23 PM
Posts: 22,731 Bitopia
jcc
Bitopia
I would add the need for .125" wall FC is IMO reduced as one installs more cage components. I don't see many cases that .125" is required once one starts adding a roll bar+.. A pair of .125" 2x3 tubes are heavy for little gain.
