Re: 1200 Horsepower options?
[Re: Mr PotatoHead]
#2976995
10/21/21 09:12 PM
10/21/21 09:12 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
They are saying 16-17k on the ZZ632 Think that article said the 572 was that price, not the 632, which they didn't have a price on, as i recall, just speculation
[Re: B3422W5]
#2977004
10/21/21 09:20 PM
10/21/21 09:20 PM
Posts: 9,554 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thanks for the correction.
The few things ive read said in the neighborhood of. Whats neighborhood mean, 17, 18k? Should be interesting.
The Detroit automaker did not offer a price to go along with this impressive new beast of a motor, but a new 572 with 727 horsepower typically costs around $16,000. Expect the price for this new 632 to be in that neighborhood. And start thinking of places to stick it.
STOP POTATO HATE!
[Re: Mpetros]
#2977021
10/21/21 09:40 PM
10/21/21 09:40 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks Can probably be done or close to it, but with a well massaged modified cast single-4 intake converted for EFI, very very good set of heads/all other parts combo, and in the hands of the right engine builder who has a warehouse for you to fill it with enough cash! Call Best Machine, Book Racing, Buck, Uratchko, BES or even Brett Miller could get down with it if he wanted to.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: Mpetros]
#2977039
10/21/21 10:15 PM
10/21/21 10:15 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks With or without a power adder?
[Re: Mpetros]
#2977165
10/22/21 10:31 AM
10/22/21 10:31 AM
Posts: 4,699 Wichita
GY3
Wichita
As bad as I hate to say it, BBC is probably going to be the most reasonable option.
It's going to be expensive to begin with but you will easily take the Chevy price and double it for anything Mopar at this level.
[Re: camastomcat]
#2977217
10/22/21 12:20 PM
10/22/21 12:20 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
It can be done if your pockets are deep enough and you are willing to go there and have time to spend waiting for it to get done.
As for the Chevy engine it is a new cylinder head, symetrical spread port deal. It wont be coming in anywhere near $16-17k
[Re: Mpetros]
#2977244
10/22/21 01:23 PM
10/22/21 01:23 PM
Posts: 4,210 New York
polyspheric
New York
This is well inside the bracket of "if the purpose is to go fast, boost is the best value per dollar spent".
Boffin Emeritus
[Re: Al_Alguire]
#2977286
10/22/21 03:28 PM
10/22/21 03:28 PM
Posts: 31,069 Oregon
AndyF
As for the Chevy engine it is a new cylinder head, symetrical spread port deal. It wont be coming in anywhere near $16-17k My guess on the new ZZ632 price is $28,000 but that is just a guess based on where the market for 1000 hp BBC crate motors is. Some of it depends on if the EFI system is complete with controller, injectors and throttle body or if it is just a bare intake manifold. The EFI system alone will add another $5000 to the bill. Shafiroff sells a 632 twisted 20 crate engine that makes 1000 hp for $22,000. By the time you put some good parts on it the price goes up a few thousand but it is still a good deal compared to asking the machine shop at the local NAPA to build you a 1000 hp engine. https://www.shafiroff.com/chevy-pump-gas-engine/632-bigdawg-twisted-sr20.php
