Re: Changed oil, no pressure, now this! [Re: A727Tflite] #2975447
10/17/21 09:41 PM
10/17/21 09:41 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Originally Posted by Transman
Originally Posted by Bad340fish
If you have a good oil filter you are probably OK.
The below pics are my oil pump that was super ugly, and the rod bearings. The ole Mopar M090 oil filter did its job.
Bad340fish -
What kind of cover did you have on your pump? A flat one or a recessed cover like a Milodon? How long did that pump last ?
My comment was more to say that the oil filter probably got most or all of that material. Mine was a small block Melling High Volume that chowed down some needle bearings from a rocker arm failure. I should have take a picture of the pump taken apart it was ugly but it fit lots of needle bearings through it lol.
68 Barracuda Formula S 340
Re: Changed oil, no pressure, now this! [Re: Bad340fish] #2975464
10/17/21 10:30 PM
10/17/21 10:30 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Mill or no mill, there is no "easy" fix. To the best of my recollection those pump covers are all hard anodized. Mill it and run it and you'll have the same issues in a very short time. You have multiple issues to fix, the pump cover is just one of them.
Re: Changed oil, no pressure, now this! [Re: Stanton] #2975477
10/17/21 11:04 PM
10/17/21 11:04 PM
A727Tflite Offline
A727Tflite  Offline
65 A-990 race Hemi used aluminum pumps without being anodized. Never saw one go bad as long as the engine was built properly and didn’t experience a failure.
But like I said earlier, anodizing does help durability and allows the pump to digest some particles.
Re: Changed oil, no pressure, now this! [Re: A727Tflite] #2976526
10/20/21 02:59 PM
10/20/21 02:59 PM
gregsdart Offline
gregsdart  Offline
Beyond checking all clearances for the pump, I would pull the pan and check some bearings. That missing metal is a lot, and it went somewhere.
Re: Changed oil, no pressure, now this! [Re: gregsdart] #2977432
10/22/21 11:17 PM
10/22/21 11:17 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Problem solved! Recommended intermediate shaft and installed shaft were different lengths. Pump primed and fired up with more pressure than it's ever had at idle. I let it get to ~110 before shutting it off as I thought the pressure was excessive (it dropped once it warmed up). Per all the comments above; I contacted Milodon about the torque specs. I was told "Spark plug tight. Snug plus 1/4 turn." Also from the above comments; after following the Milodon directions, I spun the pump by hand with a screw driver and intermediate shaft with no gear. Next I spun it with a drill and monitored oil pressure. Several over precautionary steps in between and it's happy!
[Linked Image]Untitled by Greg Ault, on Flickr
Re: Changed oil, no pressure, now this! [Re: J_BODY] #2977443
10/23/21 12:23 AM
10/23/21 12:23 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Good deal!
"Any fool can know. The point is to understand"
- A. Einstein
Re: Changed oil, no pressure, now this! [Re: EvilB1Dart] #2977563
10/23/21 12:12 PM
10/23/21 12:12 PM
moparx Offline
moparx  Offline
how much too long was the previous shaft ? the pic makes it look like about 1/4"ish ?
it's amazing it went together and functioned at all. shruggy
beer
Re: Changed oil, no pressure, now this! [Re: moparx] #2977584
10/23/21 01:53 PM
10/23/21 01:53 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
beer
~1/4in.
Re: Changed oil, no pressure, now this! [Re: gsmopar] #2977828
10/24/21 10:57 AM
10/24/21 10:57 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Any idea why the diff lengths? Guess I got to assume some aftermarket race blocks use that???
Did you cut the oil filter open?
Re: Changed oil, no pressure, now this! [Re: J_BODY] #2977914
10/24/21 04:39 PM
10/24/21 04:39 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Come on Jay don’t spoil the party. The oil filter caught all that metal. Lol 😂
Next years post. Why do my bearings and pistons look like this.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Changed oil, no pressure, now this! [Re: pittsburghracer] #2978252
10/25/21 02:30 PM
10/25/21 02:30 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I hope not, but at this point it is what it is. The damage was done at start up. This was a scheduled oil change and the car was running fine. The first oil filter would have been the one to cut. That was last year and no I did not open it up.
Re: Changed oil, no pressure, now this! [Re: J_BODY] #2978273
10/25/21 03:48 PM
10/25/21 03:48 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
There are three length shafts to accommodate the different pumps.
The shortest shaft goes with a stock style pump.
The middle length is used with the Milodon 21815 pump.
The long shaft is used when you’re running the sandwich plate between the pump and the block.
Re: Changed oil, no pressure, now this! [Re: fast68plymouth] #2978385
10/25/21 09:09 PM
10/25/21 09:09 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Thanks Dwayne….
….and if that was my W8 mill I’d tear it down. If it was my iron headed “Bracket Betty” I’d RUN IT!
Re: Changed oil, no pressure, now this! [Re: J_BODY] #2978473
10/26/21 07:29 AM
10/26/21 07:29 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Thanks Dwayne….
I call BS on that Jay. Not your style.
69 GTX 68 Road Runner
Re: Changed oil, no pressure, now this! [Re: J_BODY] #2978500
10/26/21 09:27 AM
10/26/21 09:27 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Thanks Dwayne….
I'm going to do some more inspecting this weekend. If it's bad, it's going to sit for quite a while (shoulder surgery in a couple weeks).
Re: Changed oil, no pressure, now this! [Re: JERICOGTX] #2978507
10/26/21 09:45 AM
10/26/21 09:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Thanks Dwayne….
Your speaking of a guy that has rolled rod bearings into an engine after a poor nitrous decision….
That has gorilla taped parts together in a trans to make next round….
Don’t underestimate me! laugh2
