Changed oil, no pressure, now this!
#2974982
10/16/21 01:31 PM
10/16/21 01:31 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
The engine has been together for several years with no issues. I did the annual oil change and no pressure on start up. Pulled the distributor and tried priming the pump manually. Pulled the oil filter (dry). Tried partial fill of the oil filter, no luck. Pulled the pick up line and filled the pump, no luck. Pulled the pump apart and found this. Milodon single line pump. Had good pressure before the oil change. Any ideas as to what caused this? Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr
Re: Changed oil, no pressure, now this!
[Re: Kern Dog]
#2974985
10/16/21 01:36 PM
10/16/21 01:36 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Cut the old filter open and see whats inside. You either had a clearance problem or some trash is moving through the pump. A dry filter is not the end of the world in a scenario like this i wouldnt think.
[Re: Jeremiah]
#2974996
10/16/21 02:08 PM
10/16/21 02:08 PM
Posts: 3,087 Michigan
A727Tflite
That damage didn’t just happen.
You had pressure before the oil change because the system was full - pickup to pump. Once you drained the oil the pump wasn’t able to get prime.
What does the pocket of the pump housing look like?
[Re: A727Tflite]
#2974998
10/16/21 02:13 PM
10/16/21 02:13 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
You had pressure before the oil change because the system was full - pickup to pump. Once you drained the oil the pump wasn’t able to get prime. ^ Agreed
[Re: A727Tflite]
#2975002
10/16/21 02:34 PM
10/16/21 02:34 PM
gsmopar
Arizona, USA
What does the pocket of the pump housing look like? Untitled by Greg Ault, on Flickr
[Re: gsmopar]
#2975086
10/16/21 06:02 PM
10/16/21 06:02 PM
Posts: 610 Boise
Moparteacher
Boise
Looks like abnormal downward force on the gear, thus into the cover. Do you have a an old-school rubber hose on the distributor shaft to prevent intermediate gear (timing) movement? What does the intermediate shaft bushing top side look like? Check the to see if the shaft has slipped and walked down the gear.
I don't think it's garbage related. It looks assembly related of something has moved around. Do you have the correct intermediate shaft installed? Is it possible you have a longer Milodon shaft installed?
Wedge and Hemi using Milodon Oil Systems with a steel high volume oil pump or Milodon #21814 and dual line spacer: #21001, #21150, #21160. Overall length 8.562", 7" of shaft out the gear. -Steel Gear 21500 -Bronze Gear 21520
Wedge and Hemi using Milodon aluminum pump #21815. Use with Milodon Oil Systems #21175, #21185, #21190, #21195. Overall Length 8.187", 6 5/8" of shaft out the gear. -Steel Gear 21503 -Bronze Gear 21523
Wedge and Hemi using stock-style pan and tube pick-up. Also used with Milodon Oil Systems #21000, #21010, #21100, #21110 and systems using a stock, Keith Black or Milodon #21814 pump. Overall Length 7.875", 6 5/16" of shaft out the gear. -Steel Gear 21505 -Bronze Gear 21525
[Re: gsmopar]
#2975104
10/16/21 06:53 PM
10/16/21 06:53 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The engine has been together for several years with no issues. I did the annual oil change and no pressure on start up. Pulled the distributor and tried priming the pump manually. Pulled the oil filter (dry). Tried partial fill of the oil filter, no luck. Pulled the pick up line and filled the pump, no luck. Pulled the pump apart and found this. Milodon single line pump. Had good pressure before the oil change. Any ideas as to what caused this? Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr Untitled by Greg Ault, on Flickr Annual oil change. I take it you don’t race very often or put many miles on. Get yourself an oil cutting tool from summit and make a habit of using it. That whole engine needs rebuilt NOW!!!
[Re: pittsburghracer]
#2975120
10/16/21 07:12 PM
10/16/21 07:12 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
If you have a good oil filter you are probably OK.
The below pics are my oil pump that was super ugly, and the rod bearings. The ole Mopar M090 oil filter did its job.
68 Barracuda Formula S 340
[Re: lewtot184]
#2975223
10/17/21 06:46 AM
10/17/21 06:46 AM
Posts: 2,926 A shed in England
Tig
A shed in England
I run Milodon billet oil pumps. In my experience you can't fit these with the same torque settings as the iron ones (bolts to block), they will bind. If my memory serves me correctly, we torque ours to some thing ridiculous like 15 inch/pounds (yep INCH/pounds). Needless to say we always use some sort of studlock on the bolt threads. I don't know what the manufacturers recommended torque settings are, I tried to find them online but haven't been able to. Previous to all this, a buddy of mine had the same issue, he had problems priming the oil on a rebuilt motor and warned us about this. I've also tried gently snugging the pump up when the motor was on the stand and winding the pump with a priming shaft by hand. It doesn't take a lot of torque to put these pumps into bind. I have them on two engines, fitted with a gasket to block and it's the same with both pumps. I have had no issues otherwise, they work fine.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#2975235
10/17/21 08:39 AM
10/17/21 08:39 AM
Posts: 2,514 PA
moparacer
PA
Yes definitely a setup issue. Something weird with the shaft bushing and shaft engagement in gear was going on here. Or internal clearances. .004 is the minimum gear clearance. Make sure to check that when it goes back together.
I have been using the same Milodon system for years and several block combos and never had an issue like that.
I always give it the "finger twist" with my priming shaft to make sure everything in the pump is happy before I prelube it too.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Bad340fish]
#2975275
10/17/21 11:10 AM
10/17/21 11:10 AM
A727Tflite
Bad340fish - What kind of cover did you have on your pump? A flat one or a recessed cover like a Milodon? How long did that pump last ?
[Re: A727Tflite]
#2975293
10/17/21 11:43 AM
10/17/21 11:43 AM
Posts: 8,881 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I run Milodon billet oil pumps. In my experience you can't fit these with the same torque settings as the iron ones (bolts to block), they will bind. If my memory serves me correctly, we torque ours to some thing ridiculous like 15 inch/pounds (yep INCH/pounds). Needless to say we always use some sort of studlock on the bolt threads. I don't know what the manufacturers recommended torque settings are, I tried to find them online but haven't been able to. Previous to all this, a buddy of mine had the same issue, he had problems priming the oil on a rebuilt motor and warned us about this. I've also tried gently snugging the pump up when the motor was on the stand and winding the pump with a priming shaft by hand. It doesn't take a lot of torque to put these pumps into bind. I have them on two engines, fitted with a gasket to block and it's the same with both pumps. I have had no issues otherwise, they work fine. Milodon or ANY aluminum pump cover - you're going to have issues if you use stock torque specs. To get my pump to spin freely with an aluminum cover the bolt torque is so low it makes me nervous that the bolts will fall out or that the pump will leak like a sieve. And I have no choice because of external oiling! I haven't done it yet but my intention is to drill and safety wire the bolts. What you see in the photo is a thick cover made by Muscle Motors. Thickness didn't matter, it would bind with stock torque. retry with a stock iron cover ... no problem. Put this one back on ... it binds.
[Re: gsmopar]
#2975362
10/17/21 03:43 PM
10/17/21 03:43 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
If you look closely you can see the bypass valve is stuck open in that cover I've seen aluminum Milidon pump covers like that also I think the oil pump drive is forcing the rotor down into the pump cover making metal that gets stuck in between the bypass valve and the cover. I've had that happen and unstuck the valve and the pump work normally after that
[Re: J_BODY]
#2975389
10/17/21 05:42 PM
10/17/21 05:42 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
If you look, the wear on the cover, it's from the drive gear and not the driven gear. looks like there was downward pressure on the gear. I would look real close at the intermediate shaft and the shaft bushing. also take a look at how much clearance you have between the distributor and the intermediate shaft (will need to look with intake off). If you know someone with a mill, that's a easy fix.
Joe PS if your not going to fix it, PM i will buy it from you.
PPS I just seen you found the issue.
Without Data, you’re just another guy with an opinion.
