Re: Dana 60 - 3.08 Gear Set
[Re: Rustydog]
#297322
04/23/09 11:02 PM
04/23/09 11:02 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
So, the conclusion is that 3.54s are still the highest ratio available for the Dana 60
3.33 in dana 60 in late 70's and some 80's ford truck axles. I had a set, and sold them on the bag about a year ago.
I don't know if they'd be worth the work. The .21 difference from the 3.54 can probably be made up in tire selection
[Re: dave571]
#297323
04/24/09 06:23 AM
04/24/09 06:23 AM
Posts: 1,567 Ky
jt4406
Ky
Just thinking out loud here: "after careful measuring I determined that the ring gear to pinion shaft center must be exactly 3/8" closer on the Dana 60 than on the Dana 61" Why couldn't one machine 3/8 inch off the ring gear mounting surface on the carrier unit and use the 3.08?, if that is the ONLY difference. jt
Yeah, it's hopped up to over 160...
