What to use to clean an automatic trans case? #2972488
10/09/21 07:51 PM
10/09/21 07:51 PM
Mass
charge70 Offline OP
charge70  Offline OP
Mass
Does anyone know what to use to clean a transmission case?I'm rebuilding the trans in my Charger and I want to get the deep oil stains out of the case. Any suggestions?Thanks,John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: What to use to clean an automatic trans case? [Re: charge70] #2972506
10/09/21 08:40 PM
10/09/21 08:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
A aluminum wheel cleaner for non coated wheels may do the trick if they're not to bad and the case is complete degreased
or google cast aluminum cleaner beer
Re: What to use to clean an automatic trans case? [Re: TJP] #2972559
10/09/21 10:55 PM
10/09/21 10:55 PM
A727Tflite Offline
A727Tflite  Offline
Mineral spirits first. Then hit varnish and serious stains with toluene.
Don’t breathe the fumes.
Re: What to use to clean an automatic trans case? [Re: A727Tflite] #2972620
10/10/21 10:23 AM
10/10/21 10:23 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
or smoke, Toluene in model glue is what would get the glue sniffers high whistling
Re: What to use to clean an automatic trans case? [Re: TJP] #2972623
10/10/21 10:34 AM
10/10/21 10:34 AM
A727Tflite Offline
A727Tflite  Offline
Maybe that’s why I am happy when I clean cases. wink
Re: What to use to clean an automatic trans case? [Re: A727Tflite] #2972626
10/10/21 10:44 AM
10/10/21 10:44 AM
Maryland
MoparMike1974 Offline
Maryland
I use a regular degreasser first then pressure wash all the bulk of grease and oil off. I use Zep Orange but any degreasser will work like purple power. Then I use a caustic degreasser that basically etches the aluminum and gets it perfectly clean. The best stuff was some I got from a friend who worked for a hvac company. It cleaned awesome and left the aluminum shiny. Most leave the aluminum a dull grey.
Only pressure wash a transmission if you will be taking it apart immediately. No matter how well you try to seal it up there will be some water that makes its way in.
Re: What to use to clean an automatic trans case? [Re: charge70] #2972629
10/10/21 10:47 AM
10/10/21 10:47 AM
Alberta
440_Offroader Offline
Alberta
There's a local guy that advertises Vapor Blasting for aluminum parts. The parts come out like brand new. Not sure if there is someone in your area that does It?
Re: What to use to clean an automatic trans case? [Re: 440_Offroader] #2972661
10/10/21 12:18 PM
10/10/21 12:18 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Glass bead/media blast always gives a nice surface look. Vapor blasting is the same process but with water instead of air.
Re: What to use to clean an automatic trans case? [Re: Moparite] #2972704
10/10/21 02:07 PM
10/10/21 02:07 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Purple power is a strong degreaser that has "brightner" in it and i agree with Mike, its a great way to cut the lardy caked on sludge accumulate. You may have to agitate with a stiff brush after it has sat for a few minutes. Then, find a truck wash( big rigs) or similar place that will sell you straight wash acid. It will disintegrate any remaining grease or residue and leave a nice etched surface suitable for painting or polishing. Do not leave acidic products on aluminum for too long, they will start to dissolve the metal.
Re: What to use to clean an automatic trans case? [Re: charge70] #2972737
10/10/21 03:57 PM
10/10/21 03:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Case (and other stuff) cleaner.
Re: What to use to clean an automatic trans case? [Re: A727Tflite] #2972846
10/10/21 08:52 PM
10/10/21 08:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
LOL up
Re: What to use to clean an automatic trans case? [Re: Moparite] #2972847
10/10/21 08:58 PM
10/10/21 08:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I wouldn't go any near a glass or media blaster of any kind as the abrasive dust can get into the smallest openings/areas. Had a friend do his oil pan that was supposed to be sealed off. Even said he flushed it several times. Ate the bearings within 5 minutes of start up frown
Re: What to use to clean an automatic trans case? [Re: TJP] #2972854
10/10/21 09:41 PM
10/10/21 09:41 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
If it had any baffles, then yes. Same as with most valve covers. But a plain pan wouldn't be a problem.
Re: What to use to clean an automatic trans case? [Re: PhillyRag] #2972863
10/10/21 09:59 PM
10/10/21 09:59 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you want it look original in texture and finish, see if you have someone that does dry ice blasting in your area......
Re: What to use to clean an automatic trans case? [Re: DAYCLONA] #2972890
10/10/21 11:17 PM
10/10/21 11:17 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Nice👍
China is the enemy.
Re: What to use to clean an automatic trans case? [Re: 1972CudaV21] #2972915
10/11/21 07:57 AM
10/11/21 07:57 AM
Castlegar, BC, Canada
That AMC Guy Offline
I'm pretty partial to Easy-Off oven cleaner. The yellow stuff, not the new blue stuff, though, the blue can ain't terrible.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: What to use to clean an automatic trans case? [Re: PhillyRag] #2972944
10/11/21 10:09 AM
10/11/21 10:09 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree But it had baffles. On a trans case ? I'll pass. Wonder if the OP knows anyone with a hotsy ?
Re: What to use to clean an automatic trans case? [Re: TJP] #2976554
10/20/21 04:16 PM
10/20/21 04:16 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I'll second Easy Off.
Re: What to use to clean an automatic trans case? [Re: John_Kunkel] #2976629
10/20/21 09:19 PM
10/20/21 09:19 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
