mechanical fuel pump recommendations
#2968586
09/29/21 07:24 PM
09/29/21 07:24 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Needing help choosing a mechanical fuel pump for a mild 440/727 under 500 HP mostly street driven. I see some stock style pumps ranging in price from $20 to $250. Some say rebuildable but the rebuild kits cost as much as the replacement pump. What fuel psi is normal/ideal for a 750 vacuum secondary carburetor? If I were to go with an electric fuel pump, how to choose the right one that's not overkill or junk? Thanks Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: mechanical fuel pump recommendations
[Re: 68rrunner]
#2968599
09/29/21 08:04 PM
09/29/21 08:04 PM
Posts: 4,807 Wichita
GY3
Wichita
Carter street/strip pump.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#2968659
09/30/21 01:30 AM
09/30/21 01:30 AM
Posts: 28,718 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Carter street/strip pump. That is what I have used and never a problem with them. Plus they come apart if need be. Nice to have something you can fix.
[Re: GY3]
#2968663
09/30/21 04:48 AM
09/30/21 04:48 AM
Posts: 21,910 Kirkland, Washington
Pacnorthcuda
Carter street/strip pump. Yep. The Carter M6903 mechanical has been the go-to pump for big block mopars for a LONG time!
[Re: GY3]
#2968681
09/30/21 07:59 AM
09/30/21 07:59 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Carter street/strip pump. They work great.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: an8sec70cuda]
#2968688
09/30/21 08:43 AM
09/30/21 08:43 AM
Copper Dart
I read several guys modify the M6903 to fit the larger 3/8" fittings. I suspect this mod isn't necessary for my use/application. No one chimed in about simple electric fuel pump options that would substitute for a stock pump pressure and volume. Thanks Copper
[Re: Copper Dart]
#2968700
09/30/21 09:55 AM
09/30/21 09:55 AM
Posts: 3,916 usa
lewtot184
usa
I read several guys modify the M6903 to fit the larger 3/8" fittings. I suspect this mod isn't necessary for my use/application. No one chimed in about simple electric fuel pump options that would substitute for a stock pump pressure and volume. Thanks Copper converting to 3/8" pipe thread is irrelevant unless your using AN fittings. the issue is 1/4"I.D. internal passages which are ok for 5/16" line but are small for 3/8" fuel lines. the edelbrock pumps are carters and have these mods done to them. the issue i've had with edelbrocks is pressure and i can do the internal mods myself and save the extra cost.
[Re: lewtot184]
#2968714
09/30/21 10:35 AM
09/30/21 10:35 AM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
I read several guys modify the M6903 to fit the larger 3/8" fittings. I suspect this mod isn't necessary for my use/application. No one chimed in about simple electric fuel pump options that would substitute for a stock pump pressure and volume. Thanks Copper converting to 3/8" pipe thread is irrelevant unless your using AN fittings. the issue is 1/4"I.D. internal passages which are ok for 5/16" line but are small for 3/8" fuel lines. the edelbrock pumps are carters and have these mods done to them. the issue i've had with edelbrocks is pressure and i can do the internal mods myself and save the extra cost. I've had 2 Edelbrock pumps literally fall apart on me in the car.
[Re: dragon slayer]
#2969056
10/01/21 08:46 AM
10/01/21 08:46 AM
Copper Dart
It is like the nascar pump and much larger diamter so it needs to be ground to fit against block. That has to be for the "Thirsty Engine" option? Where on the broadcast sheet does does that option appear? Copper
[Re: 68rrunner]
#2969408
10/01/21 08:27 PM
10/01/21 08:27 PM
Posts: 1,381 VA
dragon slayer
VA
I read several guys modify the M6903 to fit the larger 3/8" fittings. I suspect this mod isn't necessary for my use/application. No one chimed in about simple electric fuel pump options that would substitute for a stock pump pressure and volume. Thanks Copper converting to 3/8" pipe thread is irrelevant unless your using AN fittings. the issue is 1/4"I.D. internal passages which are ok for 5/16" line but are small for 3/8" fuel lines. the edelbrock pumps are carters and have these mods done to them. the issue i've had with edelbrocks is pressure and i can do the internal mods myself and save the extra cost. I've had 2 Edelbrock pumps literally fall apart on me in the car. I am not sure how much difference that is going to make for moderate applications such as yours. 3/8" tube has a .297" ID. The 1/4" NPT fitting is about .250" ID going into the suction side of the pump. Output is a 5/16" fuel line with .256" ID. The needle and seat are the smaller restrictions. Even the hemi runs a dual off the 4024 which is very similiar except a scalloped chamber with slightly more volume than the 6903/4862. All three use a 3/8" tube input (1/4" NPT fitting) and 5/16" tube output. The 6903/4862 are the same pump major parts, except the diaphragm spring is stiffer on the 4862 and a slightly different diaphgram disk. What fuel pump pressure is right is really based on your carb spec. Old carter had smaller needle and large float and were rate at a higher psi like Chrysler asked for. Helps with preventing vapor lock. Also helps ensure full pump stroke at high rpm. Edelbrock seem to like a lower pressure, they use the smaller float and larger needle seat which means more force on needle, less force countering from float. But I have seen both used fine with no issues on moderate hp cars. Even in combo with low pressure electric fuel pump. The pump is a positive displacement diaphram pump and works fine as designed. Now I can't say if the modern version have strayed from the design criteria and the chinese or who ever have not messed up creating some pumps with much higher pressure. But the original Carter design worked fine.
[Re: dragon slayer]
#2969435
10/01/21 09:07 PM
10/01/21 09:07 PM
Posts: 3,916 usa
lewtot184
usa
I read several guys modify the M6903 to fit the larger 3/8" fittings. I suspect this mod isn't necessary for my use/application. No one chimed in about simple electric fuel pump options that would substitute for a stock pump pressure and volume. Thanks Copper converting to 3/8" pipe thread is irrelevant unless your using AN fittings. the issue is 1/4"I.D. internal passages which are ok for 5/16" line but are small for 3/8" fuel lines. the edelbrock pumps are carters and have these mods done to them. the issue i've had with edelbrocks is pressure and i can do the internal mods myself and save the extra cost. I've had 2 Edelbrock pumps literally fall apart on me in the car. I am not sure how much difference that is going to make for moderate applications such as yours. 3/8" tube has a .297" ID. The 1/4" NPT fitting is about .250" ID going into the suction side of the pump. Output is a 5/16" fuel line with .256" ID. The needle and seat are the smaller restrictions. Even the hemi runs a dual off the 4024 which is very similiar except a scalloped chamber with slightly more volume than the 6903/4862. All three use a 3/8" tube input (1/4" NPT fitting) and 5/16" tube output. The 6903/4862 are the same pump major parts, except the diaphragm spring is stiffer on the 4862 and a slightly different diaphgram disk. What fuel pump pressure is right is really based on your carb spec. Old carter had smaller needle and large float and were rate at a higher psi like Chrysler asked for. Helps with preventing vapor lock. Also helps ensure full pump stroke at high rpm. Edelbrock seem to like a lower pressure, they use the smaller float and larger needle seat which means more force on needle, less force countering from float. But I have seen both used fine with no issues on moderate hp cars. Even in combo with low pressure electric fuel pump. The pump is a positive displacement diaphram pump and works fine as designed. Now I can't say if the modern version have strayed from the design criteria and the chinese or who ever have not messed up creating some pumps with much higher pressure. But the original Carter design worked fine. the 1/4" pipe fittings i have measure around .290+", still bigger than .250" . the 3/8" tube i have measures .300+". if a 3/8" supply line is used with a 1/4" pipe fitting wouldn't opening up the supply port to .31" be an advantage; i think so. if a 3/8" tube is used to supply a carb then wouldn't a .31 pump pressure side passage be more compatible, i think so. now if 5/16" tube is used on the supply and pressure side then the mods are a mute point. the smaller edelbrock carbs use a .093" seat with the small float and seem to work ok. the 800's i've messed with use a .110 with a small float. i know from experience the small float isn't ideal with the larger needle and seat. the larger needle and seat seem to work better with the larger float which edelbrock doesn't supply. i am picky on tune up so maybe i notice something some folks may ignore. i've seen mopar use the larger float with both small and large needle and seats. all the 340/383 factory avs's i've messed with had small floats and small needle and seats, while the bigger avs's i've had had large needle and seats with large floats. i think the smaller float provides less pressure to the needle and seat and doesn't provide the control that the big float does. i don't think mechanical pumps are as straight forward to get ideal performance as some electrics are. i've found messing with mechanical pumps that the proof in the pudding is a road or track test with a pressure gauge. this has been an eye opener for me. i used to mock pumps up on a block with a camshaft and push rod installed and spin it all with an electrical motor and do pressure/volume tests. that was a good learning experience. i've looked into the clay smith pump and do believe for the average guy they could be a can of worms. think they're 12-14psi so they need control, physically don't fit with some folks actually grinding holes in the blocks water passage trying to get them to fit. they were designed specifically for oval track were electric pumps were forbidden. i have to wonder if mopar did some minor casting changes to get them to fit nascar/usac blocks. it's all interesting stuff if one likes the details.
[Re: lewtot184]
#2969470
10/01/21 11:02 PM
10/01/21 11:02 PM
Posts: 1,381 VA
dragon slayer
VA
Maybe. What is the BSFC requirement of the motor. The pump as is, can pump the normal motor requirement and beyond. As long as the input chamber fills on a stroke, there is no difference regardless of the hole size. The pump isn't starving for fuel at the inlet. All those smaller oriffices upstream limit the volumetric flow. If the pump was oversize you would spend much of the time with the diaphragm hung in the up position because of the needles being shut. You do want the pump to draw a vacuum on the tank if it needs to pull fuel. My point is it is not too small on the suction side for the design output.
If you look at the hemi inlet it is actually larger, but the bottom design is slightly different. Inlet is at the port, while the 6903/4862 has the actual pump inlet on the opposite side of the bottom with that 1/4" port transfering fuel to the other side. Does beg the question why the carter engineers did that.
Regardless still a 3 valve small chamber pump. The Nascar/Smith type is a 6 valve large chamber. Fuel pressure can still be controlled by spring tension. Just large volume to meet needs of the higher horsepower high speed endurance running.
