Re: New rear
[Re: an8sec70cuda]
#2969319
10/01/21 04:23 PM
10/01/21 04:23 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
NICE NEW ROLLERS TOO! Lookin' good!
"Any fool can know. The point is to understand"
- A. Einstein
Re: New rear
[Re: EvilB1Dart]
#2969323
10/01/21 04:28 PM
10/01/21 04:28 PM
Posts: 20,204 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Nice to see you guys making progress. I like his rearend. Lol 😂
Re: New rear
[Re: an8sec70cuda]
#2969325
10/01/21 04:31 PM
10/01/21 04:31 PM
Posts: 4,701 On the parachute mount
n20mstr
What wheels are those Tony? I like em. Billet specialties . Rears are 15x12 I think they are 4” backspace . 10.5 x 29.5 bracket radials for now . This is going to be a street car / 10.0 index / pro dial bracket race car . ……. For now 😂
....BAD A$$ STREET CAR.....
Re: New rear
[Re: gsmopar]
#2969341
10/01/21 04:51 PM
10/01/21 04:51 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Nice Hinder. ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) I use the 9" in everything I build for play cars , and have no complaints. Probably been a half dozen of them and I have yet to hurt one , from milder deals with 31 spline to 35 spline for the quicker cars. Stock N cases at a minimum , but most got Strange with the 3.25 housing bore. My first was an HRW case...........USA made back then. But I don't think they are around anymore. That was a hunk-o-iron.
Re: New rear
[Re: moparx]
#2969628
10/02/21 01:48 PM
10/02/21 01:48 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Nice ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I may be moving to a 9" soon. Just can't seem to find pro gears in 3.91 or below for a Dana ![frown frown](/ubbthreads/images/graemlins/custom/frown.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
Re: New rear
[Re: Cab_Burge]
#2970201
10/04/21 08:21 AM
10/04/21 08:21 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
Monte Smith always said that eventually you get to the point where you start bending housings...with a Dana, there's nothing you can do to stop it. This is less likely to happen with really narrow housings like on a big tire car (depending on the power level of course). On a small tire car w/ stock style suspension (wide housing), especially on a drag radial, this is more of an issue. I talked this over w/ him and he advised me to keep an eye on the housing and when (not if) it bends, to bite the bullet and change rears. Keep in mind, he's not talking about a 700 hp bracket car on slicks. Every part of a race 9" is aftermarket, so the stock 9" strength argument need not apply here.
Re: New rear
[Re: an8sec70cuda]
#2970219
10/04/21 08:46 AM
10/04/21 08:46 AM
Posts: 4,592 Motor City
6PKRTSE
Motor City
I am still running a Dana 60 in my Challenger. However, mine is an old 1 ton Dodge Ram axle I cut down and narrowed. They have thicker wall tubes. If I remember correctly they are 3/8" or 1/2" wall thickness. Also added ultra light weight spool, 40 spine gun drilled axles with 5/8" studs. Billet custom made caps and girdle support rear cover as well as additional structured welded/bracing to housing. Going to be hard to break or bend it.
Funny thing is all of my buddies that run 9" never swap the center sections once a gear ratio is chosen, so the simplicity of just being able to swap center sections never helps.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: New rear
[Re: 11secdart]
#2970221
10/04/21 08:49 AM
10/04/21 08:49 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Looks great,,,,,,,Daddy! ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
Re: New rear
[Re: Cab_Burge]
#2970374
10/04/21 01:36 PM
10/04/21 01:36 PM
Tig
A shed in England
Re: New rear
[Re: Tig]
#2970596
10/04/21 10:05 PM
10/04/21 10:05 PM
Posts: 43,355 Bend,OR USA
Cab_Burge
We all know then Brits can screw up a 50 ton wrecking ball in a sandbox with feather ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) Just kidding ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) My 2850 Lb. S/P Cuda has hundreds of runs on the used 4:56 Dana brand pickup gears running in the high eights at 148+ MPH ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Different folks get different results ![work work](/ubbthreads/images/graemlins/custom/work.gif)
Re: New rear
[Re: Cab_Burge]
#2970624
10/04/21 11:24 PM
10/04/21 11:24 PM
Posts: 6,151 Melbourne , Australia
LA360
Nice upgrade. Probably the majority of modified Mopars over here in Australia have 9" rears.
Dana 60 and 8 3/4" rears and their parts aren't everywhere, and in most cases parts are a special order.
Alan Jones
Re: New rear
[Re: Cab_Burge]
#2970909
10/05/21 12:56 PM
10/05/21 12:56 PM
Tig
A shed in England
We all know then Brits can screw up a 50 ton wrecking ball in a sandbox with feather ![haha haha](/ubbthreads/images/graemlins/custom/haha.gif) Just kidding ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) My 2850 Lb. S/P Cuda has hundreds of runs on the used 4:56 Dana brand pickup gears running in the high eights at 148+ MPH ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Different folks get different results True on both counts ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) . Challenger is over 4000lbs and to be fair, it was a set of street gears that bust.
