Re: Whats the best way to clean hazed glass?
[Re: dssaa]
#2969106
10/01/21 10:30 AM
10/01/21 10:30 AM
Posts: 15,355 Omaha Ne
TJP
Omaha Ne
Definitely strange. Can you feel the film? Kind of looks like a hard water film or it may have been exposed to something for a long period of time that may have etched the glass.? What's the history on the car ? Did you just buy it ? Sorry for all the questions but information is helpful to solve an problem Several tips on Google how to clean cloudy glass windows Another that may not be listed was to soak a towel in white vinegar, place it on the window, cover the towel with something like saran wrap, seal most of it (tape?) to limit the evaporation and leave it overnight. or try calling GORDON GLASS COMAPNY LINK
[Re: dssaa]
#2969361
10/01/21 05:41 PM
10/01/21 05:41 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
The dash is cooked. Is that sand laying on the wiper blade? Was this car exposed to desert heat and sand for years? Can you feel roughness like it was blasted with fine sand?
[Re: dssaa]
#2969511
10/02/21 07:21 AM
10/02/21 07:21 AM
Posts: 5,815 ohio
ruderunner
ohio
Hint when polishing, use long straight strokes not circles. Also do not focus on one area.
I've used Fast Orange successfully on glass. The mild abrasive and citric acid work wonders on hard water deposits.
Rubbing compound usually has an oil base lube that needs cleaned up afterwards. The oils might make things look better until they get washed off.
Angry white pureblood male
[Re: GomangoCuda]
#3051928
06/20/22 09:56 AM
06/20/22 09:56 AM
Posts: 10,714 North Dakota
6PakBee
North Dakota
The dash is cooked. Is that sand laying on the wiper blade? Was this car exposed to desert heat and sand for years? Can you feel roughness like it was blasted with fine sand? That's what I'm guessing, it's been 'sandblasted' with fine grit. My '95 Neon after decades in ND wind-blown grit had a windshield that looked very similar to that.
