Whats the best way to clean hazed glass? #2968270
09/28/21 10:22 PM
09/28/21 10:22 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So, my glass looks like its completely dirty....no matter how much I clean it. It has a haze that always comes back. I have tired all the cleansers, 3000 grit wet sanded, razor blades....all the stuff that usually works. No matter what, it clouds back up. Its every window on the car. There has to be a trick I don't know....and if anyone does, its on this forum. HELP! Its a 67 Charger that I would love to drive i I could see out the front window clearly!
Dave in Colorado
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2968295
09/29/21 12:27 AM
09/29/21 12:27 AM
New York, USA
Chargerfan68 Offline
New York, USA
If it is not the glass itself that is hazed with scratches, i have had issues cleaning the glass and having residue left that looks like smudging. If this is you case, the Mr clean magic eraser works miracles. I didn’t believe it until i tried it. Leaves the glass crystal clean and at night, no hazing or smudges from oils/grease/dirt.
Re: Whats the best way to clean hazed glass? [Re: Chargerfan68] #2968319
09/29/21 05:56 AM
09/29/21 05:56 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I have the same problem in an 08 charger. Seems some cleaners leave a residue that smears and fogs up bigly.
I haven't had success yet either. Guess I'll try the eraser thing.
Angry white pureblood male
Re: Whats the best way to clean hazed glass? [Re: ruderunner] #2968328
09/29/21 07:35 AM
09/29/21 07:35 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Usually the haze in a windshield is the vinyl sandwiched in the middle.
Re: Whats the best way to clean hazed glass? [Re: B1MAXX] #2968358
09/29/21 09:18 AM
09/29/21 09:18 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have a side window where it looks like it de-laminated from the inside.
I have polished / cleaned my windshield with rubbing compound and it worked well.
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2968380
09/29/21 10:35 AM
09/29/21 10:35 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If it really is a dirty glass and not a scratched glass, then tire bleach and ultra fine steel wool will clean the glass just about as clean as you're going to get it. This is a very effective way to get dried bugs off. The Mr Clean pads might work, too. I use them some, but the steel wool and tire bleach works so well that I haven't tried the Mr. Clean pads on the glass. I use the steel wool and tire bleach on chrome tips with the same results.
Master, again and still
Re: Whats the best way to clean hazed glass? [Re: DaveRS23] #2968416
09/29/21 12:08 PM
09/29/21 12:08 PM
moparx Offline
moparx  Offline
my brother swears by just using a damp [water only], used soft T-shirt to "clean", then dry with another used, soft T-shirt.
his windows are always clear. i don't know how he came up with this method. he doesn't smoke, so that helps a bunch.
i have, over the years, found that the plastic in vehicles [going back mucho years] "outgasses". this causes glass to fog, smear, or cause something of a cloudy appearance, requiring frequent cleaning. newest vehicles seem to be worse than older ones, and some do this process [outgassing] more than others. as it will never [seem to] quit, it will slow down [some or a lot] as the plastics age.
i learned about that in a class taught at work, where we were having a problem viewing through a glass lens at internal components made of plastic.
beer
Re: Whats the best way to clean hazed glass? [Re: moparx] #2968435
09/29/21 01:08 PM
09/29/21 01:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Correct on the out-gassing.
I just use Windex and a couple terrycloth towels.
I've noticed that the paper "mechanic's" stuff leaves a kind of greasy or hazy surface.
Some folks claim using newspaper as a towel leaves a perfectly clean window, but I've never tried it.
Hazy glass is just one of the things that drive me nuts.
Re: Whats the best way to clean hazed glass? [Re: topside] #2968451
09/29/21 01:34 PM
09/29/21 01:34 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Worked as a Commercial Glazier for 20+ years and have cleaned more glass than I care to remember. We always used, exclusively, a readily available glass cleaner called Sprayway. We used paper towels but if you do use paper towels use the blue lint free kind. A squeegee is best if you can find a small one, like for a bathroom shower. And never use a metal razor blade to clean glass unless you have some soap solution on the glass or you will scratch it. Plastic blades are available, they wont scratch glass but are not very durable.
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: Whats the best way to clean hazed glass? [Re: U code RR] #2968456
09/29/21 01:41 PM
09/29/21 01:41 PM
moparx Offline
moparx  Offline
i have used the newspaper trick [?] before. however, it seems i have to wipe it vertically, then horizontally, [or the other way around, it doesn't matter, just so you do it both ways] to make sure it doesn't streak.
and i just HATE the modern dashes that make you need arms half again as long as they are, and hands that need to have your fingers come to a point, so you can reach clear to the junction of the dash or rear shelf, and the glass itself ! mad GRRRR !
beer
Re: Whats the best way to clean hazed glass? [Re: moparx] #2968523
09/29/21 04:35 PM
09/29/21 04:35 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
News Paper with Chemicalguys non-streak glass cleaner since the ammonia in spray cans I had tons of is no longer made and I used it all. It worked best if you can find it.
The outside glass if needs water spots etc off Bar Keppers Friend powder type with water added then glass cleaner after. The Bar Keppers Friend works great
I clean the Wiper Blades with Alky as they get stuff on them as well.
If you wipe the blades you will see how much gunk was on them
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Whats the best way to clean hazed glass? [Re: 340SIX] #2968527
09/29/21 04:49 PM
09/29/21 04:49 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Newspapers. vinegar and water in a spray bottle.
Re: Whats the best way to clean hazed glass? [Re: Sniper] #2968613
09/29/21 08:45 PM
09/29/21 08:45 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I gave up on Windex and paper towels.....works like crap. I use a spray foam type window cleaner we have at work with clean micro-fiber towels........incredible difference!
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2968672
09/30/21 06:41 AM
09/30/21 06:41 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Dave in Colorado
Post a few pics if you can.
Re: Whats the best way to clean hazed glass? [Re: moparjim79] #2968786
09/30/21 02:30 PM
09/30/21 02:30 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is it on the inside, the outside or in the middle plastic layer? When you try to clean it does it smear around? Does it clean off and then come back later?
Re: Whats the best way to clean hazed glass? [Re: U code RR] #2968800
09/30/21 03:34 PM
09/30/21 03:34 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have never used Sprayway but will look for it now.
I like “Invisible Glass” spray better than Windex.
I have used newspapers many times on large 4x8 ft glass sliding doors, but like microfiber towels better still.
I have seen Magic Eraser do “minor miracles” on many surfaces and will try it (cautiously) on glass.
In the family we have many pieces of Steuben Glass to gently clean,
the art glass of animal figures made by Corning Glass Company,
as my grandfather was the longtime company employed Dermatologist burn specialist at the Corning NY glass furnaces from 1931 to 1971
Re: Whats the best way to clean hazed glass? [Re: 360view] #2968880
09/30/21 07:26 PM
09/30/21 07:26 PM
GomangoCuda Offline
GomangoCuda  Offline
I also use Invisible Glass and microfiber. The one I use has a rainx type effect as well as a good streak free cleaner.
Re: Whats the best way to clean hazed glass? [Re: moparjim79] #2968924
09/30/21 09:33 PM
09/30/21 09:33 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Here is a pic...clear looking side was just wiped down with cleaner and hazed up as soon as it dried...
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2968926
09/30/21 09:37 PM
09/30/21 09:37 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I think the glass is just cooked. Its not a film left behind that wipes off...it just reverts to cloudy looking. I think a new front windshield is in my future....
Re: Whats the best way to clean hazed glass? [Re: dssaa] #2969029
10/01/21 07:39 AM
10/01/21 07:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
That could possibly be polished out, with a angle grinder, pad and rouge. That isn't vinyl haze. Maybe try rubbing compound in a spot by hand. New windshield would be quicker.
