1970 E body:How to reduce disk brake drag? #2968217
09/28/21 05:16 PM
09/28/21 05:16 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
My left frond disc brake drags more than the right. I have changed calipers, pads, pins, and hoses, and the left brake drags more than the right side. Is there any trick to reduce this? Thanks.
Re: 1970 E body:How to reduce disk brake drag? [Re: ragtop] #2968382
09/29/21 10:40 AM
09/29/21 10:40 AM
IMGTX Offline
IMGTX  Offline
What kind of master cylinder do you have?
Drum brake master cylinders have a residual pressure valve that can cause drag.
Re: 1970 E body:How to reduce disk brake drag? [Re: ragtop] #2968423
09/29/21 12:36 PM
09/29/21 12:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You might have some residual pressure from the booster/master if the piston/rod air gap is not adequate?, have you checked this?.... your air gap should be between .020 to .060
Re: 1970 E body:How to reduce disk brake drag? [Re: ragtop] #2968616
09/29/21 09:12 PM
09/29/21 09:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Try opening the bleeder on the LF and see if the drag goes away. If it does, hit the pedal a few times and see if it returns.
If if does, Open the bleeder on the opposite side and recheck the drag. if it is still there you have a restriction somewhere on the L side hydraulics, a sticking caliper piston, mounting pins, misalignment etc.
If it is not, then the problem is somewhere else in the hydraulics like the MC pushrod, Porp valve etc.
keep us posted beer
Re: 1970 E body:How to reduce disk brake drag? [Re: ragtop] #2968643
09/29/21 11:11 PM
09/29/21 11:11 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I had a similar problem and I replaced the stamped steel 2 finger retractor springs on the 2 pins with small coil springs from Ace hardware. Solved my problem
The only Carbs I care about are under the hood!
Re: 1970 E body:How to reduce disk brake drag? [Re: ragtop] #2968975
10/01/21 12:27 AM
10/01/21 12:27 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
How thick are your rotors? The further the piston moves out of the caliper the more resistant it will be to return.
