71 Challenger - no low beams, only high beams(RESOLVED)
#2962871
09/11/21 09:27 AM
09/11/21 09:27 AM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
I'm helping a friend with his 71 Challenger issue:
Started out with low beam headlights went out - car already had new dimmer switch, and all other lights work; dash, tail, parking. But when the dimmer switch is activated on high beam, all 4 lights work.
Thought maybe it was the headlight switch, so he bought a new dash switch and I swapped it out for him. The low beams then worked.
Fast forward to last night he was at a cruise night and when he turned on the headlight switch, the same issue, no low beams, so he had to drive home with all 4 lights on high beam.
Before I trek out to his place, looking for suggestions?
Could the low beams on both side be bad? If so, why would they go on when the high beam is activated? Could the new dimmer switch be bad?
TIA!
GY3 71 Demon 340
Re: 71 Challenger - no low beams, only high beams
[Re: John_Kunkel]
#2963006
09/11/21 03:15 PM
09/11/21 03:15 PM
ricomondo
Thank you everyone - I brought my FSM and tester to his house and after some tests, we wound up replacing both low beam headlights and that solved it!
Thanks again!
GY3 71 Demon 340
[Re: ricomondo]
#2963101
09/11/21 08:37 PM
09/11/21 08:37 PM
Posts: 15,472 Omaha Ne
TJP
Omaha Ne
Thanks again! thanks for the report back Strange that it would lose both low beams at the same time, Myself, I would still check the grounds and also the charging system to make sure its not overcharging.
[Re: TJP]
#2963211
09/12/21 11:56 AM
09/12/21 11:56 AM
Posts: 12,238 Looking for a way out of Middl...
IMGTX
Strange that it would lose both low beams at the same time, Myself, I would still check the grounds and also the charging system to make sure its not overcharging. It is strange but I have seen it more than once. I usually chalked it up to people who wait until they can't see anything before they replace the bulbs but high voltage/overcharging could be a culprit.
