Re: AFR meters?
[Re: scratchnfotraction]
#2961846
09/07/21 12:44 PM
09/07/21 12:44 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
I have an Autometer 3579 (analog 2-5/8" gauge) which I find very useful for tuning. For example, I can see the difference between the common pump E10 and no-ethanol gas (about 0.3-0.4 AFR). I couldn't have tuned my Holley 850 without it (IAB, MAB, IFR, TSR, PVCR and of course main jets). The replacement oxygen sensor that they sell for $120+ is actually a common Bosch unit that you can get considerably cheaper. The major problem with their design is that it is not tolerant of the voltage drop during cranking (it will never warm up and actually start reading). The tech line actually told me to put a switch in the +12v line and don't turn it on until after the engine is started. Which did "fix" the problem. Really great engineering there, guys ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif) A more expensive one (than the Autometer that was over $200!) would have datalogging capabilities that are even more useful. You need some kind of wideband AFR otherwise you are just guessing from ET/mph (assuming you're even at the strip) or trying to figure out if a driveability bog, sag, stumble, etc. is too rich or too lean ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
Re: AFR meters?
[Re: DrCharles]
#2962094
09/08/21 08:53 AM
09/08/21 08:53 AM
Posts: 6,330 nowhere
Sniper
nowhere
I have an Autometer 3579 (analog 2-5/8" gauge) which I find very useful for tuning. For example, I can see the difference between the common pump E10 and no-ethanol gas (about 0.3-0.4 AFR). I couldn't have tuned my Holley 850 without it (IAB, MAB, IFR, TSR, PVCR and of course main jets). The replacement oxygen sensor that they sell for $120+ is actually a common Bosch unit that you can get considerably cheaper. The major problem with their design is that it is not tolerant of the voltage drop during cranking (it will never warm up and actually start reading). The tech line actually told me to put a switch in the +12v line and don't turn it on until after the engine is started. Which did "fix" the problem. Really great engineering there, guys ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif) A more expensive one (than the Autometer that was over $200!) would have datalogging capabilities that are even more useful. You need some kind of wideband AFR otherwise you are just guessing from ET/mph (assuming you're even at the strip) or trying to figure out if a driveability bog, sag, stumble, etc. is too rich or too lean Two things, who measures the AFR during cranking? No one. Why didn't you already have it wired in to a switched in run 12V? I don't think the issue is Holley's engineering.
Re: AFR meters?
[Re: Sniper]
#2962372
09/09/21 05:35 AM
09/09/21 05:35 AM
DrCharles
West Plains, MO
I have an Autometer 3579 (analog 2-5/8" gauge) which I find very useful for tuning. For example, I can see the difference between the common pump E10 and no-ethanol gas (about 0.3-0.4 AFR). I couldn't have tuned my Holley 850 without it (IAB, MAB, IFR, TSR, PVCR and of course main jets). The replacement oxygen sensor that they sell for $120+ is actually a common Bosch unit that you can get considerably cheaper. The major problem with their design is that it is not tolerant of the voltage drop during cranking (it will never warm up and actually start reading). The tech line actually told me to put a switch in the +12v line and don't turn it on until after the engine is started. Which did "fix" the problem. Really great engineering there, guys ![eyes eyes](/ubbthreads/images/graemlins/custom/eyes.gif) A more expensive one (than the Autometer that was over $200!) would have datalogging capabilities that are even more useful. You need some kind of wideband AFR otherwise you are just guessing from ET/mph (assuming you're even at the strip) or trying to figure out if a driveability bog, sag, stumble, etc. is too rich or too lean Two things, who measures the AFR during cranking? No one. Why didn't you already have it wired in to a switched in run 12V? I don't think the issue is Holley's engineering. You are missing the point. I didn't SAY I was trying to measure cranking AFR. Good grief. ![rolleyes rolleyes](/ubbthreads/images/graemlins/custom/rolleyes.gif) I ran power to my homemade dash gauges during crank and start positions of the column ignition switch. The voltmeter, for example, is useful that way... And I DO think Holley/Autometer's engineering is the problem. Perhaps I need to provide more detail: The gauge is supposed to enter warmup mode any time the voltage is below 12.5 volts, (AFR reading slowly moves between 8 and 10, indicating sensor heating), and once the O2 sensor heater is hot, it automatically swings to an actual reading. It even has an override input (to automatically start the gauge warming then reading) for cars without alternators where the battery is likely to be less than that during a run. When cranking with the battery power directly connected to the gauge, with or without the override connected, the gauge stays in warmup mode forever. Whether the engine is running or not! That tells me that the dip to ~10 volts during cranking confuses it for good - since once the engine starts the alternator is charging at 14 volts. Confirmed on the dash gauge and with external meters. The ONLY way to get the gauge to work is to start the engine, THEN close the additional switch to the gauge power once the batt voltage is above 12.5 volts. If the gauge won't work at 10 volts, it should automatically reboot once it has 12.5 volts or higher. As clearly stated in the spec sheet. So that is crappy design.
Re: AFR meters?
[Re: DrCharles]
#2962404
09/09/21 08:30 AM
09/09/21 08:30 AM
Sniper
nowhere
Installation problem, pure and simple. Quote from the installation instructions Connect to a fused and switched 12V positive source that is turned on and off with the ignition switch. Nowhere does it say to hook to a source that is hot when cranking. Link to instructions https://static.summitracing.com/global/images/instructions/atm-3579.pdfFurthermore, the instructions say, if you bother to get down far enough to read the Sensor Control Mode section, that 12v is the minimum voltage needed for the gauge to work, but it will not turn on the heaters until the voltage is above 12.5v. As that tells the gauge the alternator is on. Your switch setup is designed to be used in a race car without a charging system, not as a crutch for improper installation. So you can either connect your power source to a hot in run only connection or continue to think you are right and Holley is wrong.
