Flex Seal Tape, the Canned Flex Seal or JB Weld
#2961622
09/06/21 04:25 PM
09/06/21 04:25 PM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Well the Generators B&S engine now has a cooling port. Rod right out the side of the block. One large Bam! https://youtu.be/YvdlD_b9uXo Way louder than you would expect. Then darkness at same time, as it happened last night.
Re: Flex Seal Tape, the Canned Flex Seal or JB Weld
[Re: Powerflow]
#2961656
09/06/21 06:39 PM
09/06/21 06:39 PM
340SIX
FWIW, home generator manufacturers usually recommend an oil change every 25 hours of operation. That time limit is easily exceeded in emergency situations so sometimes there is a catastrophic failure. I posted kinda as a joke. I can not believe how well that Gen lasted. It has had maintenance like it should have. Plus some. To tell the truth I have a large Gen we got 9 months ago that is Powered by Honda. I had and licenced electrician put in the transfer switch. It was used 9 10 times before breaking. Had say 40 hours on it. It was needed for my wife's job Hospital routed calls here, due to Covid. It broke and was brought to the place the factory said to. 6 weeks ago. They said well we are backed up front call us we will call you. They must have caller ID as they ditched my calls and the factory rep got no place. So it was use the old B&S with almost 5000 hours of use or nothing. No.mater how well maintained it was living on borried time. Last 2 days it had a knock that got wosre. I was surprised it made it that long. Even oil swaps and good oil is not going to make it new again. If and when I get the big one back it will be hooked to NG. Not sure who is responsible? I dropped it off at who the manufacture said to. Their authorized repair place. If I do not get it back. The business may be wiped out. [B]Debating down the line sticking a new B&S on the old gen as a back up. Since motors are like $275_$300
[Re: 340SIX]
#2961696
09/06/21 09:07 PM
09/06/21 09:07 PM
Posts: 15,424 Omaha Ne
TJP
Omaha Ne
[Re: poorboy]
#2961727
09/06/21 11:19 PM
09/06/21 11:19 PM
340SIX
The current crop of BS engines are not the same quality as the old BS engines. I wouldn't expect that long of life from the current engines, but I suspect, a shorter life expectancy would be better then what you have now.
Are you guys seeing any gove relief yet? I saw this old guy named Joe he said it was here. There is one Natl. Guard set up on my side the river. East bank Jeff Parish. MRE, ICE ,WATER. Like is about 3 plus miles long. Same on West Bank. I am glad I know to take care of my self.o I have food in freezer. Over 350 cans of food. Canned, and Dry milk and foods.Had my all electric home converted in 1995 it now has, natural gas hot water heater, oven/ stove top, furnace, fireplace, and gas drier. So as long as we have backup power we can wash/dry clothes cook, keep warm or cold depending on the season. Have been washing clothes, cooking and feeding my family and friends neibors. I am as of typing this fuel wise for the borrowed generator three 15 gallon VP Racing Drums, ( that used to contain 110 with lead ) with a hand pump, four, 5 gallon VP Racing Fuel Jugs, two 5 gallon Jerry cans and two normal person red lawn type gas cans. See I am normal. Well at least sometimes. And 6 in the gen I just filled. So what's that 85-90 Tuesday I already had someone try to steal from us. But ran off like he'll.yes I am armed. And my norm is sleep 2 to 3 hours a day. Have been in that pattern for a long time Sad part is if they had asked I would have gladly helped them. Look like Wal-Mart opened with limited product's so anyone who really needs should be able to get what they need. GAS IS RATIONED though. Might get power back end of week or the week after. If after I will just run gen to keep freezer_ fridge alive. I got 22 cubic feet if meat in there lol We are under boil water only thet say not safe to drink. Is contaminated due to power loss. So the ones that have all electric houses, had little to no supplies, are the ones who are totally in dire need to get it from the Fed's or stand in lines at stores as it comes in. Who has really stepped up was out of town churches! The Fed's should be ashamed of what they have done or should say not done
[Re: Pacnorthcuda]
#2961733
09/06/21 11:41 PM
09/06/21 11:41 PM
Posts: 16,491 On the run…
BloFish
On the run…
Get an Onan. How many watts do you need? 120 or 240? 220, 221 whatever it takes
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: NITROUSN]
#2961751
09/07/21 04:11 AM
09/07/21 04:11 AM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Get an Onan. How many watts do you need? 120 or 240? They are expensive but tough. I use a 2.5 kw remote start Onan AJ to run small loads overnight, and a 10 kw (pull! start) CCKA if I need hot water or to recharge the well tank. I also have a 4 kw portable generator with an 8 hp B&S. Got it cheap with a hole in the crankcase in exactly the same spot. Same failure too. So I used some aluminum brazing rod (the guy used to sit there at shows and braze aluminum cans together with it) and a plate to cover the hole, got a used rod, threw it all back together and it works fine (burns oil though. Should have re-ringed it too)
[Re: DrCharles]
#2961761
09/07/21 06:48 AM
09/07/21 06:48 AM
340SIX
Get an Onan. How many watts do you need? 120 or 240? They are expensive but tough. I use a 2.5 kw remote start Onan AJ to run small loads overnight, and a 10 kw (pull! start) CCKA if I need hot water or to recharge the well tank. I also have a 4 kw portable generator with an 8 hp B&S. Got it cheap with a hole in the crankcase in exactly the same spot. Same failure too. So I used some aluminum brazing rod (the guy used to sit there at shows and braze aluminum cans together with it) and a plate to cover the hole, got a used rod, threw it all back together and it works fine (burns oil though. Should have re-ringed it too) Cool you were able to save it. Funny mine did not smoke but used oil bad. For the cost of a new B&S engine even though they do not make them like they used to. I think it is the smart thing to do to save it as a back up. Even though I will be getting my large that can run whole home back. That one will get a NG Carb or conversion. As a friend is a HVAC guy who is licenced to run gas. Can't hurt to have a,spare in case, or I could loan it next time tij a family in need. I an running one of my good friends extra now. I was topping off oil at every gas fill and it did not like Synthetic oil. Used 1/3rd more than Dino same thickness.
[Re: A12]
#2961971
09/07/21 06:50 PM
09/07/21 06:50 PM
340SIX
Kohler or Honda no BS for me. If that's the BS 3000 series single cylinder then there's a good chance the automatic decompression mechanism broke and took out the engine/rod. Just fixed a guy's Craftsman BS that broke the decomp mechanism, luckily he couldn't get it started for the broken piece to do the usual damage. After seeing how frail the decomp mechanism is I would never purchase a BS single. So did you have a suggestion as to what I can replace the Old B&S with that would bolt right in? Other than another B&S
[Re: 340SIX]
#2962052
09/07/21 11:35 PM
09/07/21 11:35 PM
Posts: 21,525 N.E. OHIO, USA
A12
N.E. OHIO, USA
Try here CLICK HERE for Small Engine Warehouse I bought a Honda engine here for a for a 35 year old Troy Bilt tiller for a woman that just couldn't part with it. The Tecumseh was worn out and needed a total rebuild down to the pull starter. SEW will help you with your decision on what will work for you. From a little research the prices were competitive to the lowest price for some of their engines. Mike
