Re: David Visard on exhaust and mufflers [Re: 1Fast340] #2961170
09/05/21 09:41 AM
09/05/21 09:41 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Don't know if any of you caught the muffler test on a new episode of Engine Masters(it was just on this past week). They ran straight pipes then tested a hooker muffler(don't remember witch one) but it made more power than just straight pipes and all the other mufflers tested! The muffles had a 4 inch in/out design.
Re: David Visard on exhaust and mufflers [Re: Clanton] #2961188
09/05/21 10:36 AM
09/05/21 10:36 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
according to your chart 2.5 inch dual exhaust makes 463 hp hows david dudek running 9s in his cuda
Re: David Visard on exhaust and mufflers [Re: plycuda] #2961237
09/05/21 01:28 PM
09/05/21 01:28 PM
gregsdart Offline
gregsdart  Offline
Up to 500 hp, newer mustang GTs have a great big resonater that may be a nice choice for some projects. It has a LOT of volume and 2.5. Inch dual in/out pipes. No drone, and with great mufflers in the trunk area and you will have a very low hp loss system and be able to hear your stereo at speed!
Re: David Visard on exhaust and mufflers [Re: Moparite] #2961358
09/05/21 08:25 PM
09/05/21 08:25 PM
Central NC
gch Offline
gch  Offline
Central NC
It was the Hooker Maximum Flow muffler.
Re: David Visard on exhaust and mufflers [Re: gregsdart] #2961417
09/05/21 10:16 PM
09/05/21 10:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I have radio delete.
Re: David Visard on exhaust and mufflers [Re: Moparite] #2961436
09/05/21 11:22 PM
09/05/21 11:22 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'm currently using max flows. Kinda quit til ya nail it, then very loud. Using them in a 3.5" extension 18" then into 4" pipe and into 4" max flow. They are heavy mufflers thou.
Re: David Visard on exhaust and mufflers [Re: mopar dave] #2961492
09/06/21 09:36 AM
09/06/21 09:36 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
All this discussion about expensive mufflers and complicated systems seems like a bit of a waste of time to me. Why not just put electric cut-outs on and forget it? Pick any system that fits, is affordable, sounds like you want and go with it. No lost ponies. And if you attend cruises or car shows or the like, the cut-outs are a ton of fun. Fun and functional, what's not to like? I have had electric cut-outs on my cars for over 20 years and feel that they are an important part of the combo. twocents
Master, again and still
Re: David Visard on exhaust and mufflers [Re: DaveRS23] #2961605
09/06/21 03:33 PM
09/06/21 03:33 PM
I had a set of the old Magnaflow 14 inch oval by 7 inch tall 3.0 inch side inlet straight through to a center outlet mufflers with 3.0 inch pipes from the BB Hooker 1 7/8 primary pipes headers with 3.5 inch collectors, the muffs were mounted behind the rear end. It was fairly quiet at part throttle and got louder at WOT shruggy
That combination was .02 ET and .2 MPH slower hooked when up than removed on my old pump gas Duster, 7.01 at 95.2 MPH in the 1/8 mile versus with them removed 6.99 ET at 95.4 MPH, I'm sure that the weight had something to do with those results, not the back pressure form the pipes and muffs twocents
