Re: Burned piston diagnosis help
[Re: Moparite]
#2961551
09/06/21 12:51 PM
09/06/21 12:51 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
CP custom pistons, thermal coated heads and scuff coating on skirts. Not sure the alloy or more detail.
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
[Re: Bad340fish]
#2961553
09/06/21 12:58 PM
09/06/21 12:58 PM
Lifsgrt
I think in retrospect fat is where it's at... Started at 10.1, then 11.7, then 12.7 on the dual O2 guage. Leaned one more jet size and still showed 12.7. Thought it was good (obviously!). I had 5" dual side exhaust pipes and they had a black haze, so thought it was still rich enough. Tiny black specs on a couple plugs, I now think was thermal coating vacating, still not sure. It was not aluminum. I think if I would have lifted at the 5 mile it would have survived, but who knows. I know for this combo about 5 3/8 miles hurt it, and I stayed in it to the 6 because I made a bad choice.
[Re: FastmOp]
#2961554
09/06/21 12:59 PM
09/06/21 12:59 PM
Lifsgrt
I agree, but there was aluminum plasma-sprayed on the cylinder and head so did the detonation head vaporize the piston which caused it to break? I don't know.
[Re: Al_Alguire]
#2961556
09/06/21 01:04 PM
09/06/21 01:04 PM
Lifsgrt
I was running it at 36° fixed, VP C14 fuel. Innovate Motorsports dual wideband O2, new system, calibrated per instructions, but didn't change from their calibration. One sensor in each collector, wishing I would've had one in each primary.
[Re: Lifsgrt]
#2961563
09/06/21 01:12 PM
09/06/21 01:12 PM
Lifsgrt
If you notice at the upper position on the piston where the piston is broken away is right at the ring gap. Thoughts? Is this just where it happened to give up, or will alignment of the top ring gap with a vertical gas port hole cause this?
[Re: NITROUSN]
#2961573
09/06/21 01:46 PM
09/06/21 01:46 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
AFR and scale does matter if using say a Racepak set up. It is WAY easier to kill an engine going FAT than it is going lean. Especailly if one id 10-1 on a stoich scale of 14-7. Way easy to stick a ring from heat of being fat than lean, microwelding of ring lands happens from being overly fat and not that uncommon especially with certain fuels. That heat can be enough to burn a piston top but have to be pretty extreme for sure, but this application woudl be extreme. Two O2's for race tuning are almost useless in all out effort cases. Its an average only if one cylinderis WAY fat it will just drop the average number. If he was 10-1 AVERAGE that hole could have very well been well in excess of that. All race fuels have an ideal stoich number, some prefer lambda but that number is not as easily found from most race fuel manufactures. You could convert that but as I say most use Stoich racepak can use either if changed to lambda
[Re: Al_Alguire]
#2961594
09/06/21 02:57 PM
09/06/21 02:57 PM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
Well yes if you are trying to target alcohol air/fuel and it's on a gasoline scale that's definitely a problem.
Just saying if you're aware it's on a gasoline scale and different fuel it can be calibrated on a gas scale to achieve the same lambda. (whatever that target may be)
[Re: NITROUSN]
#2961598
09/06/21 03:06 PM
09/06/21 03:06 PM
Lifsgrt
Yes, I noticed that too. It almost appears that the inside edge of the Cometic gasket protruded into the chamber a bit in a few spots. Yet another issue I have to address.
[Re: Al_Alguire]
#2961599
09/06/21 03:15 PM
09/06/21 03:15 PM
Lifsgrt
I ran it on this pass showing 12.7 on both banks, which I get is an avg of those 4 holes best case, so could be all over. It stayed solid at 12.7 and accelerated well until well over 220mph, then I believe the turbulence through the unfiltered cowl scoop got to a point that it disrupted flow over the carb and affected fuel distribution to a critical point. I will be addressing that as well before next year. Further looking at the vertical ports, I am thinking lateral gas ported rings and different pistons would be better for this application, and of course being a little richer vs a little leaner.
[Re: Lifsgrt]
#2961600
09/06/21 03:17 PM
09/06/21 03:17 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
He suggested to skip EGT probes, as there is a delay in heating the thermocouples for EGT and by the time you have a critical indication it is too late. He suggested O2 sensors in each primary and a way to monitor it real time. While expensive, I would have probably be at the break even point now if the system would have prevented me making this mistake. Thanks for the reply! I let a dyno operator in Caldwell, ID put 8 O2 sensors in my Cuda B1 headers when testing a B1 motor on his dyno with the cast B1 single four intake, the customer had a custom built Dam Best 1450 CFM Dominator type carb and another smaller Dam Best Dominator carb on it. Once we started doing the testing I realized there was no way for me, us, to fix unequal mixtures to the center cylinders by jetting or not working on inside the intake manifold to influence the mixture flow by reading the O2 readings form each cylinder ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) You will have a PM from me today ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
[Re: dvw]
#2961637
09/06/21 05:27 PM
09/06/21 05:27 PM
Posts: 117 Aus
hysteric
Aus
I'm not familiar with running B-1 heads. But 36 degrees sounds like a lot of timing. My -1 Indys run at 32. I know many racers run more timing. But my Mph doesn't improve over 32 degrees. Mine is 4.500" bore flat top, 15-1. Doug This! Why would a modern chamber design require so much timing? Unless its lean of course.
[Re: Cab_Burge]
#2961671
09/06/21 07:40 PM
09/06/21 07:40 PM
Al_Alguire
Las Vegas
There are ways to alter the mixture in a single 4 intake, but you gott be willing to do it. This is a place where a 3 or more curcuit carb can shine. We run a single 4 intake and carb on the Vette and they are all within a tenth or so from the beginning to end of a run. There are no damns or obstructions inside the plenum as that would change the volume there. We do it with a combnation of jetting, bleeds, offset boosters and a few other little things to get it that way. Takes work but it can be done to lay perfectly together.
As for he lambda thing yes I get it trust me. I am just stating if he is using a racepak or similar they are based of stoich for pump gas. If you do not change that number in the software for your particular fuels stoich reading then the results you get are not accurate. If he was reading 10-1 based on a 14.7 he could have been much much fatter or leaner(for instance C14 is 15.07-1 stoich) than he thinks he was...FWIW you can change your racepak to read in lambda but finding the lambda numbers for alot of race fuels is not as easy.
[Re: Al_Alguire]
#2961788
09/07/21 09:24 AM
09/07/21 09:24 AM
INTMD8
Lake Villa Il
I'm not sure if we are agreeing or not ![smile smile](/ubbthreads/images/graemlins/custom/smile.gif) If it's on a gasoline scale where 14.7 is stoich or lambda 1.0 and it's ran on- E85 with 9.8 stoich Or C14 at 15.07 stoich At -actual- stoich, the gauge will still read 14.7-1 because that's what it's programmed to read at 1.0 lambda no matter what fuel it's running. So take any fuel and tune it to known gasoline numbers and it tunes the same as gasoline whether it is correlating with that fuels actual stoich number or not. 10-1 on a gasoline scale is .68 lambda. (14.7x.68). So on C14 that would be 15.07 x.68, or 10.24-1 Looking at it another way, what is your target lambda? If you target .87 lambda WOT on gasoline that's 12.8-1 air/fuel on a gas scale gauge. So any fuel you run if you wanted to target .87 lambda and your wideband is on a gasoline scale, you would tune it to 12.8-1 on that gauge. If you change the scaling of a wideband you're just changing what number it reports for the same lambda value. (so sometimes easier to just look at it in terms of lambda instead of air fuel ratio)
[Re: INTMD8]
#2961849
09/07/21 12:50 PM
09/07/21 12:50 PM
Al_Alguire
Las Vegas
Like I say Lambda s fine and universal. However finding that number for many race fuels is not so easy. And the target number varies greatly from race fuel to race fuel. Just something to consider when someone says and average AFR is 10-1 it is fat, not knowing the scale being referenced it could be dangerously fat depending on the fuel used. He is not giving you a Lambda number, only an AFR which is likely based off of an inaccurate scale. Fat mixtures create alot of heat and can cause catastrophic damage. Much more so than being overly lean can and will. All Im saying. You are converting his number to Lambda not knowing what the idea lambda number is, and he is clearly not using lambda. I have not seen any reference to what fuel he is using so just speculating. I can tell you the fuel we use in the Vette if it sees anything close to what 10-1(.68 lambda) it will absolutely microweld rings and torch a piston, ask me how I know. FWIW this is with a fuel thats target is 13.31(.91ish). Tome its why scale and fuel used matter. Id be happy to se a lambda number but without knowing the fuel used it does not mean as much. Almost as little as a single O2 per bank on a maxx effort deal like this one.
[Re: Al_Alguire]
#2961857
09/07/21 01:15 PM
09/07/21 01:15 PM
INTMD8
Lake Villa Il
I see where your difference in view is. For me target lambda is not determined by what fuel you're using but the combination/intended use.
Either way, if you know what scale the gauge is on (and we do) and what it's outputting you can back calculate for lambda value. (whether you know what lambda you want to target or not)
[Re: INTMD8]
#2961870
09/07/21 01:38 PM
09/07/21 01:38 PM
INTMD8
Lake Villa Il
To expand a bit on that.
The gauge in lambda is .5 to 1.5
So, depending on what scale you have it on (gasoline in this case)
.5 to 1.5 lambda would be- 7.35 to 22.4 on a gasoline scale 4.5 to 13.5 on alcohol scale
4.9 to 14.7 on E85 scale
The gauge is just taking lambda and converting it to an AFR number based on what scale. So, he's running on gasoline scale and sees 10 to 1 air fuel that is .68 lambda. That's all you need to see to figure it out, scale (gasoline) and observed air fuel ratio on that scale.
In his case running C14, stoich is 15.07 so at .68 lambda it wa 10.24-1.
When he observed as lean as 13.1, that was .89 lambda so 13.41-1
[Re: dvw]
#2962056
09/07/21 11:51 PM
09/07/21 11:51 PM
Lifsgrt
Engine builders /dyno operator said it made best power at 37°. I have decided the vertical gas ports were a bad idea for this endurance engine and will replace the pistons with no vertical gas ports and lateral gas ported rings. I am confident Wilson Manifolds can make the intake fuel distribution better. I will add an air filter and figure out how to minimize the turbulence in the cowl scoop. There was a lot of (low) pressure above the scoop at speed, as the scoop was rising about 2" or so, and the high pressure of the air flowing over the scoop pushed the windshield in while rolling rhe factory style gasket off the pinch weld. We fixe dthat by putting the gasket and Lexan windshield back in place and supporting it with a 1x block of wood against the roll bar, so there was some interesting wind/turbulence happening there. I think that turbulence had a lot to do with it the fuel distribution problem. We will see. Thanks for all the feedback.
