Re: Diesel fuel mileage [Re: Twostick] #2962127
09/08/21 11:25 AM
09/08/21 11:25 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by Twostick
When was the last time you adjusted the valves on it?
If they've never been done, that might be where at least some of it went.
Any 3406 CAT engines I had were real fussy with valve settings. They called for .015 and .030 and they didn't mean .014 and .029. Fuel mileage would suffer by a few tenths.
Kevin
OP’s 06 will have hydraulic lash adjusters.
I pulled the cover on my 01 at 150k…. Thought there was one getting loud, nothing was really even worth adjusting. Of course one came into work a week afterwords and I could hear the same noise. Forget what “normal” is sometimes.
I’m not a huge additive guy by any means but I’ve seen the CRC diesel fuel therapy do some pretty amazing stuff on the common rail trucks (03 up).
My VP pickup I use 2 cycle oil in the fuel (pint to 35gal)…. Gets so hot out here the newer fuels thin and you can set p0216 pump timing failure codes. Got this tidbit from Cummins.
Re: Diesel fuel mileage [Re: J_BODY] #2962192
09/08/21 02:26 PM
09/08/21 02:26 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Kevin
I’ve used the 2 cycle oil before, Walmart brand low ash but I used a quart or more per fill up. I’ll also check out the CRC stuff. I put the 2 micron Cat filter & water separator filter add on about 3 years ago.
