Re: ram - crap bolts and ex manifold warpage
[Re: mopars4ever]
#2959200
08/30/21 09:25 PM
08/30/21 09:25 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Just had my right exhaust manifold replaced on my 2015 Ram 2500 5.7 4x4. It was the third time the studs broke and the manifold warped. I have lifetime powertrain warranty but each time cost me $200 deductible. I told them this time I was not paying it to they checked the manifold and it was warped bad. They said because the studs kept breaking it cause the manifold to warp. They replaced the studs and the manifold and so far 2500 miles and no further issues, but I will be watching and listening...
JB Rhinehart, Realist
A-Body's RULE!
[Re: mopars4ever]
#2959236
08/30/21 10:21 PM
08/30/21 10:21 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Very common on all years of the 5.7.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#2959319
08/31/21 08:37 AM
08/31/21 08:37 AM
Posts: 9,871 MI, usa
dvw
MI, usa
Also common on the LS and 4.6/5.4 Ford motors. Don't know why. Expansion difference with aluminum heads? I just replaced the Y pipe to manifold studs on my 2005 Magnum 3.5. 2 were rusted right in half. 2 were not. We are talking a 10mm stud. One on each manifold. How does that happen? Doug
[Re: mopars4ever]
#2959388
08/31/21 11:00 AM
08/31/21 11:00 AM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
No warranty on mine. I ordered a new manifold as the manifold end where the bolts were broke was warped bad. I doubt I could of had in machined flat without taking off quite a bit. 318 Poly engines were famous for warping and breaking the driver's side manifold. If you find a Poly in a wrecking yard that still has a driver's side manifold on it, chances are it's cracked. Passenger side rarely cracked so lots of those around. A seasoned but warped manifold machined flat again has pretty much done all the warping it's going to do and will usually live a long happy life with new hardware, assuming it can be machined back true. A new green casting is just asking for rinse repeat. Kevin
[Re: Neil]
#2959389
08/31/21 11:01 AM
08/31/21 11:01 AM
Posts: 3,391 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
The manifolds in the old days did not appear to be as prone to cracking and warping like the new ones are. Maybe the metallurgy of the iron in the newer manifolds is just not as good?. Likely they are using less metal to save weight. Same issue with brake rotors warping--often there is not enough material on them to even turn them.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: Rhinodart]
#2959391
08/31/21 11:03 AM
08/31/21 11:03 AM
Twostick
Still wishing...
Still wishing...
Just had my right exhaust manifold replaced on my 2015 Ram 2500 5.7 4x4. It was the third time the studs broke and the manifold warped. I have lifetime powertrain warranty but each time cost me $200 deductible. I told them this time I was not paying it to they checked the manifold and it was warped bad. They said because the studs kept breaking it cause the manifold to warp. They replaced the studs and the manifold and so far 2500 miles and no further issues, but I will be watching and listening... Pretty sure they've got that backwards. The manifold warps and breaks the studs. Kevin
[Re: 5thAve]
#2959398
08/31/21 11:23 AM
08/31/21 11:23 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
If I had to point a finger somewhere, I would say the manifolds are at fault. Why? The cars almost never do that, the trucks almost always do it. The manifolds are, of course, totally different.
Rich H.
Esse Quam Videri
[Re: Twostick]
#2959498
08/31/21 01:37 PM
08/31/21 01:37 PM
Posts: 13,609 md
mopars4ever
md
Just had my right exhaust manifold replaced on my 2015 Ram 2500 5.7 4x4. It was the third time the studs broke and the manifold warped. I have lifetime powertrain warranty but each time cost me $200 deductible. I told them this time I was not paying it to they checked the manifold and it was warped bad. They said because the studs kept breaking it cause the manifold to warp. They replaced the studs and the manifold and so far 2500 miles and no further issues, but I will be watching and listening... Pretty sure they've got that backwards. The manifold warps and breaks the studs. Kevin that was what I was thinking. I am surprised they don`t pull the threads out of the heads.
[Re: stumpy]
#2959568
08/31/21 04:05 PM
08/31/21 04:05 PM
Posts: 13,609 md
mopars4ever
md
Mine were broke like in the pic above. One came out with some vice grips and the other didn`t budge. I tried a left handed drill bit but it was not going anywhere. Then the bit broke. So I welded a nut to the broken stud and after three tries I got it out. I bought a China manifold from NAPA since the mopar one was going to take at least a week to get it. Anyone use one of those manifolds? Are they any good? Or should I have waited for a mopar one? It appears the mopar ones aren`t really any better it seems. This one lasted about 70,000 miles.
