Re: 572-13 FLOW NUMBERS
[Re: gregsdart]
#295883
04/29/09 01:03 PM
04/29/09 01:03 PM
For a street 4.5 bore NO way I would go 572-13 They make 4.5 bore pistons for use with dash ones--Indy ( better yet Todd ) usually has them in stock--That would be a killer set up and run fast enough to scare most anyone--No matter what the HP numbers came out to. Just my worth
[Re: gregsdart]
#295884
04/29/09 01:37 PM
04/29/09 01:37 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I think the deal is this; the 440-1 heads will show better flow numbers and increased power when you go with a large bore (4.5), not hard to understand. The 572-13 came with a valve as big as you can reasonably put in the 440-1 casting, then there is the optional 2.35 intake, but you still are saddled with the same casting, valve length, etc you have with the 440-1. Once you realize the power potential of any wedge head is the length of the valve stem, (limits port shape) you can understand why this head will have a performance limit higher but still close to the 440-1 if both styles are taken to their limit. At that point, if you want more power, look at the valve lengths of the B-1 heads, and the brewers, They dwarf the 440-1/572 deal, at least the brewer heads do.
thanks for the reply greg.why would indy waste time with a new head? are they really the same? i noticed the largest port they offer for the -1,s is 345 cc. the largest for the 572-13,s is 385 cc. what gives there? the next one i do WILL have b-1,s on it!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#295886
04/29/09 02:05 PM
04/29/09 02:05 PM
Posts: 2,792 IN
Dartman928
IN
I run a 572 572-13 street engine with 10:1 compression. I use any 93 pump gas. It has a solid .660 roller and been to the track a few times. Not the fastest but what do you expect for shifting at 5800 rpm and running pump gas. Best has been 9.74@139 full street trim.
[Re: Old School]
#295887
04/29/09 03:02 PM
04/29/09 03:02 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
its to late for this one. i already have everthing for the indy set up.now i know.... next time
I wouldn't get discouraged about what you have to work with. This motor will make a ton of steam, it will just have its' limits, like everything else. personally, I don't have a clue where a person could use over 900 hp on the street, which is what you have the capability to build, even with a few restrictions like compression and cam choice. I say enjoy what you will get, as it will be a whole lotta fun!!! P.S. The various port volumes are what work best with each heads intended purpose, roughly. My castings are opened up to 365 cc for alky and high rpm.
[Re: Old School]
#295894
04/30/09 06:34 AM
04/30/09 06:34 AM
Posts: 2,933 A shed in England
Tig
A shed in England
its a 4 sp car with a dana w/ 4.10,s
It's gonna be a handfull for sure
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
