Re: Which Dynamat To Use? [Re: Copper Dart] #2958882
08/29/21 11:44 PM
08/29/21 11:44 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Originally Posted by Copper Dart
If I may ask a question, I can't help but wonder if i were to put it on the underside of my roof (i'm just weeks away from cloth headliner replacement on my 1970 Swinger build) with a cloth headliner, that sitting in the South Florida sun, it would take about a half hour and it would drip down through onto my head and interior possibly ruining everything! Please advise with actual first hand experience. Thanks
Copper
The NOICO has been applied on the inside of the roof in my coupe for 4 years, in northern IL. The car sits outside year around, windows closed when the car was not being driven. There is nothing between the NOICO and my head. Nothing has fallen, sagged, or dripped from anywhere. The NOICO is butyl based, not asphalt based. There is NO odder involved with its application or even after sitting days with 90+ temps, in a hot car with the windows up, while sitting in the hot sun. It has a product use range of 150 to -40 degrees. You need to start with clean metal, you trim the stuff with an utility knife, peal off the backing, put it in place, the roll it tight. Once rolled tight, it takes effort to remove it with a putty knife.
Before the NOICO was installed, I had that silver covered bubble stuff glued to the inside of the roof with 3M 77 spray glue. After about 4 years, the glue started letting go and the bubble stuff would drop down, the wind from open windows would catch it, and I ended up regluing it a few times before I pulled that stuff out. The NOICO stuff is holding much more firm (nothing even appears loose) then the 3 M glue held the bubble stuff. The NOICO also offered more insulation and sound deadening then the bubble stuff did. If it matters, the outside of the roof of the coupe is painted white, so that probably helps, but it was also painted white while the bubble stuff was in the car. .Gene
Re: Which Dynamat To Use? [Re: poorboy] #2958900
08/30/21 02:42 AM
08/30/21 02:42 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Great information! Thanks for sharing. up
This stuff looks like it would be perfect for my cloth and bow headliner for roof insulation.
Noico RED 150 mil 36 sqft Сar Sound Insulation, Heat and Cool Liner, Self-Adhesive Closed Cell Deadening Material (PE Foam Sound Deadener) boogie
I ordered 50mil KILMAT for the firewall, floors and wheel tubs, I don't think doing any further back than that would really help much.
Copper.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Which Dynamat To Use? [Re: Sniper] #2958975
08/30/21 11:17 AM
08/30/21 11:17 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've done with both my cars and my truck with Dynamat Extreme in bulk packs. I found it on sale on Amazon for about 1/2 off with free shipping. It is heavy. I do two layers on the wheel tubs, and one the entire floor, ceiling and doors(some strips inside and on the panel).
The key to insulating airplanes or cars is that products like dynamat are designed and are very good at reducing panel resonation, and not so much at reducing heat transfer. You actually don't even need to cover the entire surface, just use enough to stop the resonation of the panels.
For best sound deadening, heat and fume rejection, you must use a double sided foil covered insulating blanket type material on top of it. I get mine from Speedway Motors. Its very reasonably priced there.
I cocoon the entire interior from glass to glass with individually cut pieces that I tape together at the seams with that aluminum foil duct tape that has the peel off wax paper backing..I also do under the headliner, dash and doors.I tape down the edges just out of sight of the interior trim etc. By '70 E-Body sounds like you are sitting in a bank vault when you close the door. I swear it is as quiet as a Bentley rolling down the road. Most people are shocked at how much of a difference in terms of sound reduction/deadening and heat and fume rejection this technique provides. I learned how to do it this way reading about how they insulate small planes.
I cannot begin to imagine how much added weight that is.
It adds 15lbs for each full bulk pack of Dynamat Extreme.. I used 3 packs on my '70 E-Body, The foil insulator adds a couple pounds too.
Thanks, I think what was confusing me was the cocooning statement. Didn't realize that it was foil backed jute you were referring to in that statement. I had thought it was all Dynamat, lol.
Its interesting how much better the foil covered jute is at both sound and heat rejection than Dynamat or Fatmat type products, and drastically less expensive too. Together they are amazing too, but the self adhesive butyl sheets by themselves are only marginal at best as far as insulating against heat and noise. Dynamat and Fatmat really only dampen panel resonation and slow down the heat transfer. they will get just as hot as the panel in a short amount of time. Not so with the foil covered jute. Thats what a lot of guys get wrong when trying to insulate a car. You can read it here.
The word cocooning just came to mind for some reason. I basically cover every square inch with taped together sheets and custom fitted cutouts of the double foil sided jute mats. the aluminum duct tape seals very well at all the seams. The entire form fitted covering can be removed from the car, and it looks like it was molded to the interior. When installed, I tape it down at all the edges, just shy of where the interior will cover.
Here's a picture of my Vintage Air evaporator with the foil, and Dynamat underneath it. I used to have a lot more photos of my '70 while insulating it, but my hard drive got destroyed.
