Re: 1968 Charger steering problem ..new box
[Re: 44070dart]
#2958736
08/29/21 04:15 PM
08/29/21 04:15 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Put a new Lares P/S steering box in my Charger. I couldn't cough up $650 plus for the others. The steering wheel for the first 6 to 8 inches feels like manual steering then it feels like power steering. I bled the steering by moving the wheel lock to lock 10 to 15 with the wheels up with the car not running, then running. When I did that with the car in the air, the power steering felt correct all the way thru the travel. PS belt is tight. thanks for any suggestions Is it their rebuilt box? http://catalog.larescorp.com/part/1033/Or is it their new Power Steering box that has a different design than the older ones? http://catalog.larescorp.com/part/11033/
[Re: autoxcuda]
#2958791
08/29/21 07:19 PM
08/29/21 07:19 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
I bought a remanned box and pump a few months ago from them and couldn’t be happier. What’s your caster set at? Might want to put a pressure gauge on the pump, too, or remove the shim pack from the pump valve if you have a Saginaw. TRW pumps can also have progressive valving but I do not think it is adjustable other than by pulley size and rpm.
[Re: Montclaire]
#2958867
08/29/21 10:42 PM
08/29/21 10:42 PM
Posts: 18,423 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
You said it works fine on jack stands. Alignment can change ease of turning and return to center. In what order did you do everything? Did you get a print out with the alignment? What dont you get. He feels the lack of assist while the car is sitting still.
[Re: 44070dart]
#2958982
08/30/21 11:38 AM
08/30/21 11:38 AM
autoxcuda
So Cal
I bled the system before the alignment. No didn't get the read out. The car when on jack stands running or off steers correctly. It's when I drive it the P/S doesn't work for the first 6 / 8 inches of travel. That sounds like some valve stuck internally or something else internally with the Power Steering gear. I’d contact Lares directly in Minnesota. And please report back with your experience. Sounds like Lares is becoming (or already was) a major supplier of rebuild units. In the past A1 Cardone seemed to be the major supplier to parts houses.
[Re: Montclaire]
#2959193
08/30/21 09:13 PM
08/30/21 09:13 PM
NITROUSN
Ask NITROUSN if he thinks you should check your idler arm. Sorry he never asked me. I think he is on the right track to make sure it is fully bled. At least he did not take the asinine advice on getting an alignment.
[Re: 44070dart]
#2959203
08/30/21 09:29 PM
08/30/21 09:29 PM
NITROUSN
When you first try steering you said no power assist unless you turned the wheel a couple inches. Do you have power assist then? If so it sure sounds like a problem in the gear boxes centering valve/control valve.
[Re: NITROUSN]
#2959232
08/30/21 10:16 PM
08/30/21 10:16 PM
autoxcuda
So Cal
From 1974 FSM (Factory Service Manual)
[Re: autoxcuda]
#2959304
08/31/21 07:35 AM
08/31/21 07:35 AM
Montclaire
Scranton, PA
Oh look at that. Improper wheel alignment. And I didn’t tell him to GET an alignment, I asked if he had the car aligned recently and if he had the spec sheet. The factory recommended different specs for power/manual steering. Changing those specs, especially with stickier modern tires, could aggravate issues and change return to center, which he also complained about. But what do I know, I’m not a total [censored] [censored] like you.
[Re: 44070dart]
#2959762
09/01/21 01:02 AM
09/01/21 01:02 AM
autoxcuda
So Cal
[align:center][/align] Lares says they have a Limited Lifetime Warranty
[Re: autoxcuda]
#2964454
09/15/21 05:09 PM
09/15/21 05:09 PM
Posts: 146 bflo. ny
44070dart
bflo. ny
I give up. They are selling defective boxes and the best they can say is send it back. Can't do this type of work anymore, so I paid twice to have defective boxes installed and removed. I have spoken to other people on Mopar sites that have had problems with their Lares 11033 new box. One of the guys overheard the guy on the phone telling the guy next to him ..it's another problem with the 11033 box. This sucks, I spent 3 grand to do my complete suspension and the car is to dangerous to drive because of the box. Putting it away early because it screwed up. I'll have my old one rebuilt over the winter.
[Re: CKessel]
#2975356
10/17/21 03:39 PM
10/17/21 03:39 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
What are you going to do with the box? Try to get a refund? Throw it away? Sell for scrap? If you are going to keep it, I'd do some trouble shooting. Mark the position of the control valve with punch marks or some method. Pull the control valve off the box to expose the valve actuation lever. Have someone gently move the steering wheel, the lever should move with the slightest movement of the wheel. If it does, I would guess your problem is in the control valve. If it doesn't, or moves only after a lot of wheel movement, I would guess your problem is in the box. I feel your pain.
