Re: Questions about pinion snubbers
[Re: 70dart360]
#29593
09/15/06 10:06 PM
09/15/06 10:06 PM
But at one time Chrysler highly suggested using a PS !
Do you know why they did that ?
And with good SS springs a PS is not needed. There will be 3 to 5 degrees movement - at the most.
So you SET the pinion angle 3 to 5 down ...and you are good-to-go.
May I ask .... what was the rod side clearance on the last motor you built ?
#29594
09/15/06 10:32 PM
09/15/06 10:32 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
I'm building a 410 stroker as we speak. I build lots of "engines" not motors if ya must know. The rod clearance is right at .015, they are steel H-beams, aluminum rods need bout .020 for the expansion difference. Tim
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
#29595
09/15/06 10:33 PM
09/15/06 10:33 PM
Posts: 10,945 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Isn't it called rear axle wind-up? I thought the idea behind using the pinion snubber was that it attaches to the nose of the third member creating a positive stop of torquing at a more precise position.
BTW I have NEVER experienced rear axle hop in a mopar. That's GM voodoo.
I’m listening.
#29597
09/15/06 10:37 PM
09/15/06 10:37 PM
Posts: 6,208 Macomb, MI
Giggy
Macomb, MI
Easy does it. Just yesterday I was amazed we were actually having a conversation about cars and now we are still talking about cars but it's getting a little dicey man! relax and some more....it that doesn't work, take 2 of these and come on back! Easy now
[Re: 70dart360]
#29598
09/15/06 10:40 PM
09/15/06 10:40 PM
That's GM voodoo.
Like I said earlier, sound like he's been taking advice from Chevy guys. Tim
Tim ...... I will just say this .... I was out at Milan Dragway when they were testing the Motown Missle and the Mopar Missle, alot of the factory-sponsored SS cars .... and the White-Whale test car....
AKA .... the same time you were probably still in diapers.
AND ........ 15 sounds good on steel rods ... but alum rods need lots more than 20.
#29599
09/15/06 10:46 PM
09/15/06 10:46 PM
70dart360
Green Meister
Green Meister
Hampton, Ga.
I aint tryin to start no stink, I just know the snubbers work and they look better than traction bars or whatever and ya cant see them. They are kinda sneaky to me. Tim
70 Dart Swinger
#29600
09/15/06 10:47 PM
09/15/06 10:47 PM
Posts: 6,780 Alabama
Mopar-Al
Alabama
That's GM voodoo.
Tim ...... I will just say this .... I was out at Milan Dragway when they were testing the Motown Missle and the Mopar Missle and alot of the factory-sponsored cars ....
Wow braggin rights over PS's !!! Back in 74 we used to weld extentions on our pinion snubbers and mount another plate to help with lift. but................ it really doesn't matter much.
#29601
09/15/06 10:49 PM
09/15/06 10:49 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
BUT with proper springs ... there will be no wrap-up ...and the pinion angle should not move anymore that 3-5 degrees at the most.
As many chassis builders have said ... a PS is just a band-aid for INeffective rear springs.
Yep - pinion snubbers are just a waste of time and effort and money, and pure garbage/crutch. Ask some of the race guys.. Buy good springs and install them and you will eliminate wheel hop. DAMHIK.
[Re: Mopar-Al]
#29602
09/15/06 10:53 PM
09/15/06 10:53 PM
NOPE ... he can have ALL the ones out there !
And IF they "work" for him .... GOOD for him.
[Re: IronWolf]
#29603
09/15/06 10:59 PM
09/15/06 10:59 PM
Welcome ... to another defender of the "truth" .. !
I should add .... Some time ago - I saw a car with bad springs and a snubber BLOW the driveshaft OUT from under the vehicle ....during a 60 foot shot --
You could HEAR the snubber banging-on-the-floor and then the DS was just SPIT out.
#29604
09/15/06 11:18 PM
09/15/06 11:18 PM
70dart360
Green Meister
Green Meister
Hampton, Ga.
I totally agree some folks use them as a crutch, but I have installed new springs in quite a few cars and ran them, then added snubbers. Got a way better 60 foot time with them. What ever works I guess. Tim
70 Dart Swinger
[Re: 383man]
#29607
09/16/06 06:10 AM
09/16/06 06:10 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
We were posting about this same topic the other night and Namvet keeps asking others to quote thier sorses, but can he post all his? Can he post WHY Chrysler put them on the cars when Ford and GM did not? He starts posting hostal right off the bat. Sounds like HES the one that needs to chill out. Post proof or please dont post. I dont want to start a fight, but lighten up. DaveJ
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Quicktree]
#29609
09/16/06 09:17 AM
09/16/06 09:17 AM
Posts: 1,630 Burma Shave
plymouthfan
Burma Shave
Hey, even my Slant six Scamp came out of the factory with a pinion snubber bolted onto it's 7 1/4 rear, so I guess Chrysler believed they served a valid purpose. Although I seriously doubt that snubber has ever touched the floor of my car Wheel hop has never been an issue with a slant six...
One red car, one yellow car.
[Re: Quicktree]
#29610
09/16/06 12:17 PM
09/16/06 12:17 PM
Posts: 7,863 Colorado
Leadfoot
Colorado
every body has a right to post and express there opinion. problem is we don't know how to act when someone else has a different oppinion.
Aint that the truth! Somebody coming back with a different opinion is often taken as a personal slap in the face. It's not. BTW, you spelled opinion wrong the second time.
[Re: Leadfoot]
#29611
09/16/06 02:41 PM
09/16/06 02:41 PM
Quicktree
whats your point? it was dark I was half a sleep and I can't spell. would you like the grammar fixing job
[Re: Quicktree]
#29612
09/16/06 02:57 PM
09/16/06 02:57 PM
Leadfoot
Colorado
Are you kidding? I can't spell or structure sentences either! But it's always fun to point out others errors.
