Re: Lifter oiling an Indy Maxx [Re: LA360] #2957810
08/26/21 09:33 PM
08/26/21 09:33 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
We might not be talking about the same thing, being a danger.
I don't see a lot of drilling in the block.
I only see long hole drilling in the manifold piece. All other drilling is small holes.
I don't see how the block can "go bad very quickly".
Please help me understand.
Re: Lifter oiling an Indy Maxx [Re: hemienvy] #2957828
08/26/21 10:27 PM
08/26/21 10:27 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I am, and many above, are referring to drilling the block for pushrod oiling in the manner the OP discussed, as Indy or KB would when they manufacture the block with the pushrod oiling option.
I'm not talking about the machining required for adding the manifold and oil supply lines to the lifter valley.
Alan Jones
Re: Lifter oiling an Indy Maxx [Re: LA360] #2957832
08/26/21 10:43 PM
08/26/21 10:43 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
OK, now I understand.
I also agree, drilling galleys in the block, very bad.
Thank you.
Re: Lifter oiling an Indy Maxx [Re: CompWedgeEngines] #2957840
08/26/21 11:24 PM
08/26/21 11:24 PM
AndyF Offline
AndyF  Offline
Originally Posted by CompWedgeEngines
I would not suggest this. I am with Todd Marsh. I had this exact situation, and I would not attempt it. I asked one of the best in the business to do it, Weston Machine, and they wouldnt either. It went back to Indy. This can go bad very quickly.
I think that is good advice for any backyard guy but based on what I know about Indy, I doubt that they have any sort of "sophisticated" process for drilling these holes. I'm pretty sure I could come up with a method for drilling the holes that would work as well as anything Indy has. If someone who has toured the Indy machine shop wants to weigh in with a description of the Indy "hi tech" process I'm all ears.
Re: Lifter oiling an Indy Maxx [Re: AndyF] #2957980
08/27/21 11:17 AM
08/27/21 11:17 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Deep or long hole drilling success is as much related to the drill edge profile and drilling technique as it is the machine the block is being drilled in. The guy running the machine is going to make the biggest difference.
