Re: Electrical draw on new resto,,,,where to start,,,
[Re: JMCFAN]
#2956742
08/23/21 08:59 PM
08/23/21 08:59 PM
Posts: 15,569 Omaha Ne
TJP
Omaha Ne
just remember that the ammeter is the feed for everything electrical in the car, so disconnecting this connector may not be as useful as it could be. Well after going through the starter relay and starter it appears its the ammeter feed.... no need to dissect that.... jeeez I am a bit puzzled, the Ammeter feed just supplies the current to whatever is causing the draw. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: TJP]
#2956767
08/23/21 09:47 PM
08/23/21 09:47 PM
Posts: 2,106 New Mexico
JMCFAN
New Mexico
just remember that the ammeter is the feed for everything electrical in the car, so disconnecting this connector may not be as useful as it could be. Well after going through the starter relay and starter it appears its the ammeter feed.... no need to dissect that.... jeeez I am a bit puzzled, the Ammeter feed just supplies the current to whatever is causing the draw. Yup... I have been through the 3 firewall connectors.....and isolated to that one lead... now I need to figure out where to go from here.....
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: JMCFAN]
#2956833
08/24/21 08:17 AM
08/24/21 08:17 AM
Posts: 6,358 nowhere
Sniper
nowhere
just remember that the ammeter is the feed for everything electrical in the car, so disconnecting this connector may not be as useful as it could be. Well after going through the starter relay and starter it appears its the ammeter feed.... no need to dissect that.... jeeez I am a bit puzzled, the Ammeter feed just supplies the current to whatever is causing the draw. Yup... I have been through the 3 firewall connectors.....and isolated to that one lead... now I need to figure out where to go from here..... Seems the issue is something that doesn't go back thru the firewall, so it's inside the pass compartment or maybe the trunk. Years ago I had a problem with my battery draining over night, Eventually, I found out that when I replaced the trunk lid weatherstripping it was now thick enough that the trunk light stayed on. No idea what kind of current draw that light pulled, doubt it was anywhere near what you are seeing, but pull the bulb and see.
[Re: Sniper]
#2956883
08/24/21 10:57 AM
08/24/21 10:57 AM
Posts: 10,780 North Dakota
6PakBee
North Dakota
I would have guessed it would be either the ammeter (P terminal) or the alternator terminal (J terminal) as they are connected to the battery directly. If you look at your wiring diagram, the alternator terminal leads to a splice in the wiring harness in the passenger compartment that feeds:
1) Ammeter 2) Ignition switch 3) Headlights 4) Fuse panel (always energized circuits)
It looks like it's one of them.
[Re: 6PakBee]
#2956895
08/24/21 11:27 AM
08/24/21 11:27 AM
JMCFAN
New Mexico
It looks like it's one of them. Am leaning towards the Ammeter since its original.. have pulled the headlight switch plug...not sure that is sufficient. Pulled individual fuses...but not all at once...will try that. Also disconnect the 2 large flat white connectors ( ignition switch and turn signals) Is there another connector..?
[Re: JMCFAN]
#2956906
08/24/21 11:55 AM
08/24/21 11:55 AM
TJP
Omaha Ne
You can bypass the ammeter by disconnecting & tying or jumpering the two leads together. If the draw is gone the ammeter ( unlikely) or it's insulation for the posts is the problem. IF not, you'll know it's not the ammeter. Just an FYI: Hopefully someone did not use rubber washers/ tubing for insulating the posts and rubber can be conductive keep us posted ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: TJP]
#2956909
08/24/21 12:01 PM
08/24/21 12:01 PM
JMCFAN
New Mexico
You can bypass the ammeter by disconnecting & tying or jumpering the two leads together. If the draw is gone the ammeter ( unlikely) or it's insulation for the posts is the problem. IF not, you'll know it's not the ammeter. Just an FYI: Hopefully someone did not use rubber washers/ tubing for insulating the posts and rubber can be conductive keep us posted Thanks! Have a show on Sunday so will attack on Monday. Will the rally dash instrument cluster come out easily? I installed the dash fully assembled...
[Re: JMCFAN]
#2956913
08/24/21 12:05 PM
08/24/21 12:05 PM
Posts: 4,770 Moved to N.E. Tennessee
GomangoCuda
Didn't someone recently discover a miswired harness from Year One?
[Re: JMCFAN]
#2956918
08/24/21 12:27 PM
08/24/21 12:27 PM
6PakBee
North Dakota
It looks like it's one of them. Am leaning towards the Ammeter since its original.. have pulled the headlight switch plug...not sure that is sufficient. Pulled individual fuses...but not all at once...will try that. Also disconnect the 2 large flat white connectors ( ignition switch and turn signals) Is there another connector..? I'll look after breakfast. What I can't get my arms around is the 5 amp current. At that current you are dissipating over 60 watts of power. Typically you would be burning something up. Are you absolutely sure you are reading that correctly? That it's not 5 ma?
[Re: 6PakBee]
#2956923
08/24/21 12:39 PM
08/24/21 12:39 PM
JMCFAN
New Mexico
It looks like it's one of them. Am leaning towards the Ammeter since its original.. have pulled the headlight switch plug...not sure that is sufficient. Pulled individual fuses...but not all at once...will try that. Also disconnect the 2 large flat white connectors ( ignition switch and turn signals) Is there another connector..? I'll look after breakfast. What I can't get my arms around is the 5 amp current. At that current you are dissipating over 60 watts of power. Typically you would be burning something up. Are you absolutely sure you are reading that correctly? That it's not 5 ma? Can I delete this post...?? First...I need to remember how to uses a meter correctly. Measure with the lead in the correct port...300ma port and not the Volt/Ohm port..the draw when measured from the neg battery terminal to the neg cable is 10.3 ma....OMG..... Sorry to waste everyone's time!!
[Re: JMCFAN]
#2956956
08/24/21 02:28 PM
08/24/21 02:28 PM
6PakBee
North Dakota
Don't worry about it. Sometimes the learning path is not smooth. All that matters is that the concern has been resolved. I wouldn't worry about 10 ma.
[Re: 6PakBee]
#2956961
08/24/21 02:37 PM
08/24/21 02:37 PM
JMCFAN
New Mexico
Don't worry about it. Sometimes the learning path is not smooth. All that matters is that the concern has been resolved. I wouldn't worry about 10 ma. Thanks....its probably the clock....which actually works... lol
[Re: TJP]
#2957236
08/25/21 11:50 AM
08/25/21 11:50 AM
Posts: 15,960 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I recently had to chase down a parasitic draw that turned out to be the alternator but along the way I had to deal with a faulty voltmeter too. How annoying that was because it was throwing me off until I borrowed another to find it was part of the issue.
Facts are stubborn things.
[Re: larrymopar360]
#2957263
08/25/21 12:51 PM
08/25/21 12:51 PM
JMCFAN
New Mexico
I recently had to chase down a parasitic draw that turned out to be the alternator but along the way I had to deal with a faulty voltmeter too. How annoying that was because it was throwing me off until I borrowed another to find it was part of the issue. Wish I could blame the meter..LOL
[Re: JMCFAN]
#2957270
08/25/21 12:59 PM
08/25/21 12:59 PM
Posts: 19,700 north of coder
moparx
the main thing is you now have the issue solved ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) just wait until the "cobwebs" start to invade your noggin, like me ! ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: moparx]
#2957287
08/25/21 01:43 PM
08/25/21 01:43 PM
JMCFAN
New Mexico
the main thing is you now have the issue solved ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) just wait until the "cobwebs" start to invade your noggin, like me ! Whats sad is I was a electronic tech for 5 years....and a BSEE for 30........ ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: JMCFAN]
#2957299
08/25/21 02:15 PM
08/25/21 02:15 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I recently had to chase down a parasitic draw that turned out to be the alternator but along the way I had to deal with a faulty voltmeter too. How annoying that was because it was throwing me off until I borrowed another to find it was part of the issue. Wish I could blame the meter..LOL Haha no biggie we all do something like this now and then just glad you solved it ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: JMCFAN]
#2957446
08/25/21 09:06 PM
08/25/21 09:06 PM
TJP
Omaha Ne
the main thing is you now have the issue solved ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) just wait until the "cobwebs" start to invade your noggin, like me ! Whats sad is I was a electronic tech for 5 years....and a BSEE for 30........ LOL It sucks getting old AMHIK Had one that drove me around the bend for a while. 57 T-bird, 10 or 15 ma draw as i recall. Car was bone stock. Checked thi s, checked that, scratched my a-- etc. After a few hoursone of the guys says disconnect the clock. I said why? It doesn't work. Another hour or so of the above. Finally disconnect the clock. POOF! draw is gone ? WT-O? Being an old points style clock, the main spring had broken and consequently the points stayed closed and the motor that wound the spring was running continuously ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
