Re: 727 Drive and 2nd slipping! [Re: B300 VanDanage] #2965515
09/19/21 05:02 PM
09/19/21 05:02 PM
Guitar Jones Offline
That part of the reaction shaft and inside the converter hub matter not.
Re: 727 Drive and 2nd slipping! [Re: John_Kunkel] #2965544
09/19/21 07:39 PM
09/19/21 07:39 PM
Chino Valley
B300 VanDanage Offline OP
Chino Valley
What about the output shaft bushings?
Which is which? I can't tell...
It's hard to see in the pic but the one on the left is lighter and yellower than the one on the right. I assume the one on the right is bronze? So what's the yellow one on the left?
Maybe just a different shade?
I also have another bushing(pictured) but the dimpled one suppose to be better?
Re: 727 Drive and 2nd slipping! [Re: Guitar Jones] #2965546
09/19/21 07:41 PM
09/19/21 07:41 PM
Chino Valley
Chino Valley
Awesome! Thanks.
Re: 727 Drive and 2nd slipping! [Re: B300 VanDanage] #2965553
09/19/21 08:39 PM
09/19/21 08:39 PM
Output shaft bushings are the same. That front pump bushing is bronze. I've used them all with no appreciable difference.
Re: 727 Drive and 2nd slipping! [Re: Guitar Jones] #2965592
09/19/21 10:11 PM
09/19/21 10:11 PM
Chino Valley
Chino Valley
I might just leave the front since its brand new and already "worn" into the hub a little...
The output shaft bushing is also brand new but it has a little scuffing, which is normal I know but I also noticed that the notch doesn't line up with the housing. The notches in the new one will match the housing perfectly.
Someones going to tell me it doesn't matter...
