Electrical draw on new resto,,,,where to start,,,
#2956040
08/21/21 04:55 PM
08/21/21 04:55 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Newly restored 70 RR, Runs great,,,,but, I have a 5.4 amp draw on battery when measured at the neg battery terminal when car is off, Have pulled individual fuses with no change, where should I start? Freshly painted....so grounding issue?
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Electrical draw on new resto,,,,where to start,,,
[Re: JMCFAN]
#2956050
08/21/21 05:20 PM
08/21/21 05:20 PM
Andrewh
restored, or resto modded?
[Re: JMCFAN]
#2956051
08/21/21 05:21 PM
08/21/21 05:21 PM
Posts: 21,471 It's a dry heat
gtx6970
It's a dry heat
Car all stock build? If so, ck the alternator Glovebox light, key in cylinder light etc etc
[Re: JMCFAN]
#2956053
08/21/21 05:25 PM
08/21/21 05:25 PM
Posts: 272 Anchorage, Alaska
metallicareload
Anchorage, Alaska
Unplugging harnesses until it goes away will help narrow it down
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: BigBlockMopar]
#2956070
08/21/21 05:56 PM
08/21/21 05:56 PM
Posts: 2,954 GA
roadrunninMark
GA
Also check starter relay / starter, things that are wired "hot most of the time" w/o the key on. If no luck there, pull each fuse one at a time. Should be able to check draw at battery or jumping the fuse blade ends at the box to see if there is draw or not.
[Re: JMCFAN]
#2956074
08/21/21 06:04 PM
08/21/21 06:04 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Disconnect the wire from the alternator BAT lug.
[Re: roadrunninMark]
#2956097
08/21/21 07:09 PM
08/21/21 07:09 PM
JMCFAN
New Mexico
Also check starter relay / starter, things that are wired "hot most of the time" w/o the key on. If no luck there, pull each fuse one at a time. Should be able to check draw at battery or jumping the fuse blade ends at the box to see if there is draw or not. I did pull each fuse....no change
[Re: John_Kunkel]
#2956098
08/21/21 07:10 PM
08/21/21 07:10 PM
JMCFAN
New Mexico
Disconnect the wire from the alternator BAT lug. What should I look for there,,,,?
[Re: JMCFAN]
#2956118
08/21/21 08:38 PM
08/21/21 08:38 PM
Posts: 15,469 Omaha Ne
TJP
Omaha Ne
Disconnect the wire from the alternator BAT lug. What should I look for there,,,,? if the draw gores away you may have an alternator partially shorting. DO KEEP THE BATTERY DISCONNECTED while the car is unattended
[Re: TJP]
#2956239
08/22/21 11:14 AM
08/22/21 11:14 AM
JMCFAN
New Mexico
Couple of checks this morning
Batt lead to Alternator pulled-
Headlight Switch
High/low beam switch.
Draw still there,,,,with a fully charged battery it is 7 amps,,,,,,
[Re: JMCFAN]
#2956240
08/22/21 11:22 AM
08/22/21 11:22 AM
Posts: 15,919 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Sure there's nothing else wired hot through a switch? Fog lights?
Facts are stubborn things.
[Re: larrymopar360]
#2956243
08/22/21 11:34 AM
08/22/21 11:34 AM
JMCFAN
New Mexico
Sure there's nothing else wired hot through a switch? Fog lights? No all stock build,,,,and all new harness from Year One ( M&H)
[Re: larrymopar360]
#2956245
08/22/21 11:35 AM
08/22/21 11:35 AM
Posts: 10,749 North Dakota
6PakBee
North Dakota
What specifically are you using to measure the current? That seems high with no light visibly on and no motors running. If this is a stock setup what are the high current consuming devices, assuming that something hasn't failed?
1) ignition 2) A/C clutch 3) heater blower motor 4) headlights 5) rear window defogger 6) power windows 7) horn 8) windshield wiper
There just aren't that many devices that can draw that kind of current constantly and not have some kind of problem show up.
[Re: 6PakBee]
#2956253
08/22/21 12:09 PM
08/22/21 12:09 PM
gtx6970
It's a dry heat
There just aren't that many devices that can draw that kind of current constantly and not have some kind of problem show up. Agreed that kind of draw is huge and not see anything on. Nothing on these cars back then had a key off draw except maybe time delay lighting for key switch
[Re: Andrewh]
#2956281
08/22/21 12:52 PM
08/22/21 12:52 PM
JMCFAN
New Mexico
I don't think you answered. is this a stock restoration or have you modded it? any modern features or added items that wouldn't be stock for that year?
how are you measuring amps drawn? Stock resto..with all new harness from Year One ( M&H) .only mod would the the upgraded digital tach added to the original Tic Toc tac which doesnt work,..... Measuring with Fluk meter at the neg battery cable
[Re: 6PakBee]
#2956285
08/22/21 12:55 PM
08/22/21 12:55 PM
JMCFAN
New Mexico
1) ignition works fine.....? 2) A/C clutch none 3) heater blower motor- have not check yet....its not running 4) headlights pulled switch cable-no change 5) rear window defogger none 6) power windows none 7) horn works fine 8) windshield wiper have not checked motor is a Jules rebuild...but does not work...will pull switch cable to test next
[Re: JMCFAN]
#2956297
08/22/21 01:10 PM
08/22/21 01:10 PM
Posts: 6,299 nowhere
Sniper
nowhere
There just aren't that many devices that can draw that kind of current constantly and not have some kind of problem show up. You are making assumptions when you say "works fine". Something is not working fine and until you physically disconnect EACH item on the list and check you cannot assume it "works fine". For example, your ignition could very well draw 7 amps in use, but is still drawing current when it should be off. So while it make "work fine" in start and run, it should not be drawing current at all in off. Until you disconnect it you won't know.
