Re: trouble shooting frustration
[Re: RustyM]
#2956558
08/23/21 12:47 PM
08/23/21 12:47 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Thanks for the update,, keep us posted
[Re: CSK]
#2956723
08/23/21 07:38 PM
08/23/21 07:38 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What were the bolts, what was the torque, and what lube was used to install the heads?
[Re: fast68plymouth]
#2957665
08/26/21 03:42 PM
08/26/21 03:42 PM
Posts: 575 Texas
RustyM
Texas
Bolts are ARP, used Arp thread lubricant. Don't have tq specs here with me . Gary is wondering is he left a little water or fluid in the bolt holes that compressed and we didn't get actual tq values. Im not sure, wasn't there when they were torqued. Will be this time with my torque wrenches etc. Just has to be right for three more dates, which is actually 4 races. Then end of the season dyno pulls, after that we pull it down, box up the parts that are coming to you. Cylinder walls all look good but, time for a rebuild even if we weren't going to the new block. We looked really good to see if anything "kissed" since pistons are out of the hole so far.
