Re: Did any magnum engines come with windage trays? If not, why? [Re: Rhinodart] #2965659
09/20/21 09:00 AM
09/20/21 09:00 AM
scratchnfotraction Offline
IMHO, you find them in Heavy Duty apps. more often, every police car 318/360 headed 4v engine I have torn down has had a windage tray in it. from a 80-89 and I had about 20 of them since 1980. I have only found it on HD service engines.
and all of them had some interesting pieces that go along with them that I have not seen or been able to buy when rebuilding them.
on the oiling system it has the oil cooler with these factory pieces in the engine every time.
full groove main bearings for full time oiling to the rod bearings
#2 & #4 cam bearing have a full oil groove for full time oiling to rockers
factory windage tray
factory oil cooler- hollow fuel pump bolt for return oil/timing chain oiling
double roller t chain - with oil slinger
so IMHO I think they used them for more longevity/oil control for long idle times and HP gains are a plus with it. I have read the 318 police engine 360 heads/4v q-jet -flat tappet cam rated @177HP over a 2v/tbi roller cam 318 with small port heads rated @150HP (why I like them)
not sure when the early LA roller cam engines went from a non oil through roller lifter/sold push rod combo to the oil through/hollow push rod but I did notice when they oiled both LA rocker shaft & roller lifter hollow PRs they all tend to have massive VC leaks on daily drivers. mostly the 89-91 LA roller cam engines. I assume they were tooling up for the magnum engine 92-93 as early magnums did have the block drilled for LA style rocker oiling but blocked by head gasket.
not sure what went into a HP engine that came with a windage tray? did it also have some special piece inside as well?
what about racing engines when the oiling mods are performed on a engine and trays are used? drilling it 1/2" from pump/cap/block/full groove bearings - 4 extra oil filter plate holes - oil galleys drilled 9/32" restrictors in the rocker shaft oiling feed?
I would think with all those mods a tray is mandatory or just rule of thumb when building?
Re: Did any magnum engines come with windage trays? If not, why? [Re: scratchnfotraction] #2965908
09/21/21 06:29 AM
09/21/21 06:29 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
During the 1992-2003 5.2/5.9 Magnum V8 era
was there a “police vehicle package” from the factory.
Around the year 1998 Evans Cooling had an article on their website that my fuzzy memory recalls as involving Detroit Police Magnum 5.2 V8 Jeeps that tried out Evans Cooling NPG waterless coolant, including describing how the Magnum 5.2 head gaskets had to have enlarged holes near cylinders #7 and #8.
I do not know whether these engines were plain factory Magnums 5.2s or had some police modifications.
During that era I remember seeing some Ram Pickups with Police paint jobs.
Re: Did any magnum engines come with windage trays? If not, why? [Re: Michael Ecks] #2965978
09/21/21 12:20 PM
09/21/21 12:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If you are talking the 92-03 318 and 360 magnum engines I would say no, none ever came with them. I have taken apart hundreds of them and NEVER saw evidence of one, not a special bolt, not a place to mount one, not a part number nothing. If someone said they found one I would be extremely skeptical. They had a 4800 RPM redline and hardly wanted to turn that many RPM, anything over about 4500 RPM was a waste, they just didn't need one.
