What is the BIGEST crank you can get in a 383 block ?25-
#2950043
08/03/21 03:17 PM
08/03/21 03:17 PM
Posts: 910 West Virginia
B1Frank
West Virginia
What is the bigest crank you can get in a low deck 383 block ? with little to no work with grinding ? 4.25 - 4.50 1965-71 block thanks
Re: What is the BIGEST crank you can get in a 383 block ?25-
[Re: B1Frank]
#2950044
08/03/21 03:21 PM
08/03/21 03:21 PM
Posts: 10,049 MN
JERICOGTX
MN
I don't think you can go more than 4.25 on a low deck.
69 GTX
68 Road Runner
[Re: B1Frank]
#2950224
08/03/21 10:04 PM
08/03/21 10:04 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
It depends on which size rod journals you have on the crankshaft, I have one 400 stroker motor with 4.300 stroke with BB Chevy rod sizes on the rod journals, almost no grinding needed on the block other than the stock oil pump pickup boss. Years ago I bought a 1959 383 stroker motor that was suppose to have a 413 crank with welded stroke to make it 1/2 stroker (stroked to 4.250) with the stock 383 rods and Jahns stroker flat top pistons. I was told it was 454 C.I. with the stock early heads and it had a old Isky 505T solid lifter flat tappet camshaft, I thought it ran good in my 1960 Dodge Phoenix weighing 4160 Lbs. without me in it, it ran. Best ET was around 12.70 at 105 MPH on a set of J.C.Penney 700x14 seven inch wide cheater slicks with a set stock 3:73 gears in open non posi rear end. On your deal if you want to make it big you could go with a custom rod and have the crank journals ground to 2.00 size to get between 4.375 and 4.500 stroke and use a custom made real long aluminum or steel rod The smaller Honda rod journal sizes are used in a lot of high end all out builds, but they have a limited life span due to the HP those usually motor make, 2000++++
[Re: B1Frank]
#2950371
08/04/21 01:05 PM
08/04/21 01:05 PM
Posts: 16,932 NC
440Jim
NC
What is the bigest crank you can get in a low deck 383 block ? with little to no work with grinding ? 4.25 - 4.50 1965-71 block thanks Depending on what your goals are, etc. Using a 4.250" stroke crank with 2.200" BBC 6.535" long steel rods is pretty easy, " with little to no work with grinding"Here is a picture of the tiny grind on the oil pickup casting area (used 1/2 NPT pick-up). Depending which 1/2 NPT pickup tube you use, the base near the block may need a little grind also. Having the crank shop reduce the counterweight dia, and putting a bevel on the counterweight edges does the trick.
[Re: B1Frank]
#2950404
08/04/21 02:22 PM
08/04/21 02:22 PM
Posts: 4,705 Wichita
GY3
Wichita
Thanks guy, A lot of people building #383 blocks, going #65 over finished bore to get the cubes + stoker crank Who are the machinists that think a larger overbore (for minimally more cubic inches) is more important than thicker cylinder bores?!
[Re: B1Frank]
#2950537
08/04/21 09:57 PM
08/04/21 09:57 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
WE know #65 over is one and dune as for as a stock 383 block and people chose that Why .065 over? At .060 there’s a ton of ring choices (bbc) or .070 = stock 440 bore.
[Re: cudaman1969]
#2950671
08/05/21 11:36 AM
08/05/21 11:36 AM
B1Frank
West Virginia
I talk to alot of people , and they are looking for #65 over, Im like you why not #60 over if you have to go that far, thanks on the crank photos, good point !
[Re: B1Frank]
#2950693
08/05/21 12:28 PM
08/05/21 12:28 PM
Cab_Burge
The stock 383 bore is the same as the 426 bores, 4.250. Boring it .065 will make it 4.315, why do that I've built a bunch of RB and 426 Hemi at either 4.310 or 4.320 bore sizes when needed, never thought of trying to find or have 4.315 pistons made and use 4.320 rings on them, why are you wanting to do this?
