Re: Aftermarket wiring harness
[Re: 68jim]
#2949785
08/02/21 07:27 PM
08/02/21 07:27 PM
Posts: 240 British Columbia, Canada
Old Ray
, is that they did not use a bulkhead connector for their cars. Sorry, I'm old and not that bright, ... who did you mean about no bulkhead connector, ... the Australian Charger ... or the A, B, C, E body versions? I would modify one of the aftermarket kits or just wire it from scratch using a aftermarket bulkhead connection (as I am going to do) if that is what is required? Like this: BULKHEAD or BULKHEAD 2 or cut both parts out of a wreck (messy) or maybe both parts of a trailer connector.
[Re: Sniper]
#2949954
08/03/21 10:39 AM
08/03/21 10:39 AM
Posts: 16,163 Mesa, Arizona
dart4forte
Mesa, Arizona
When I rewired my 51 Plymouth I used one of Speedway's house brand harnesses, key is to determine how many circuits you need. This is th eone I used
https://www.speedwaymotors.com/22-Circuit-Universal-Automotive-Aftermarket-Wiring-Harness-Kit,229874.html I have an EZ wiring harness in my 52 Dodge PU. Previous owner installed it. Presently I’m wiring LED lights and so far it’s been pretty easy. My harness is is a 12 circuit. I would suggest going through another vendor besides Speedway. Their customer service sucks. I spend over an hour and a half yesterday just to get one question answered. Turns out the instructions for the wiring on my truck were updated.
Abe Lincoln
[Re: 68jim]
#2949988
08/03/21 12:34 PM
08/03/21 12:34 PM
Posts: 19,641 north of coder
moparx
I think a previous owner of this car was a 15 year old who really liked wire nuts and scotch tape...68Jim don't forget to add in lamp cord and 8 butt connectors on a single wire run of two feet. some of the things i have seen over the many years would make you just shake your head because you couldn't form words to describe it ! i like to use factory items whenever possible, including bulkhead connectors and terminal ends. also, use a quality automotive wire with automotive grade insulation. i forget the name for it now, but some kits use cheap insulation that doesn't hold up to heat well. as hot rods and street rods have different requirements than normal vehicles, i like to choose the amount of circuits needed, then obtain a fuse panel that has a couple of extra circuits in case you decide to add something in the future. i have used ron francis items, and they are good quality. don't forget the pliers needed for terminating the wire ends. you will more than likely need a couple different ones, depending on what connectors you use. over the years, i have acquired many, and as newer connectors are invented, i seem to get the tools needed to use them. also, there are special picks used to remove the wire terminals from the factory connectors. you will need several of those as well, as mistakes can happen, or you will want to move a wire from one cavity of a connection to another, and the picks prevent damage to the terminal, wire, or connector. probably the most important item of all, is to sketch a diagram of your system. this will help in the future for multiple reasons, and you will be glad you took the time to do this when that occasion arises. wiring is not that difficult if one takes their time, carefully route the harness, and use quality components. just my experience over 50 years. your mileage will vary. and i have made MANY mistakes, so don't feel bad if something happens and you need to redo something.
[Re: dart4forte]
#2950295
08/04/21 08:28 AM
08/04/21 08:28 AM
Posts: 6,330 nowhere
Sniper
nowhere
https://www.speedwaymotors.com/22-Circuit-Universal-Automotive-Aftermarket-Wiring-Harness-Kit,229874.html I have an EZ wiring harness in my 52 Dodge PU. Previous owner installed it. Presently I’m wiring LED lights and so far it’s been pretty easy. My harness is is a 12 circuit. I would suggest going through another vendor besides Speedway. Their customer service sucks. I spend over an hour and a half yesterday just to get one question answered. Turns out the instructions for the wiring on my truck were updated. I got a universal kit, did not expect Speedway to provide any technical support since that is pretty much the nature of anything universal, i.e. fits nothing. If I wanted a plug and play, fits like the factory made it, kit I would have gone to Rhode Island wiring,
