How big can you go with after market block? #2948835
07/30/21 01:36 PM
07/30/21 01:36 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Saw an article the other day, and the guy had a 636 Hemi, Indy block I believe....I thought 605 or so was it, but I guess not. Is that a raised cam and a 5" stroke?
Re: How big can you go with after market block? [Re: Dragula] #2948838
07/30/21 01:43 PM
07/30/21 01:43 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
655 ci. 4.840 B/S 4.56 bore x 5 stroke. up
Re: How big can you go with after market block? [Re: Tig] #2948858
07/30/21 02:41 PM
07/30/21 02:41 PM
Dragula Offline OP
Dragula  Offline OP
I feel small.....Standard Chevy now is 632....We Mopar folks need a bigger platform.....
Re: How big can you go with after market block? [Re: Dragula] #2948863
07/30/21 02:53 PM
07/30/21 02:53 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
4.90" or 5.00" B/S on a Hemi 99. Not sure of Deck height though ??
Re: How big can you go with after market block? [Re: Tig] #2948866
07/30/21 03:06 PM
07/30/21 03:06 PM
Dragula Offline OP
Dragula  Offline OP
Yes Todd Goodwin makes those...I have seen those at nearly 700 cubes. And I know there was one by a member on here for sale on RJ...$43k...Looked awesome. Would love to know more about them.
Re: How big can you go with after market block? [Re: Dragula] #2948871
07/30/21 03:17 PM
07/30/21 03:17 PM
New York
polyspheric Offline
polyspheric  Offline
New York
When you replace the block, crank, cam, heads, manifold, pan...
what part is still MoPar?
Boffin Emeritus
Re: How big can you go with after market block? [Re: polyspheric] #2948875
07/30/21 03:27 PM
07/30/21 03:27 PM
Dragula Offline OP
Dragula  Offline OP
Well then my current G2 isn't really a Mopar....But it sure looks good in their.
Re: How big can you go with after market block? [Re: polyspheric] #2948885
07/30/21 03:54 PM
07/30/21 03:54 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
The same can be said for every make out there.
Think the Chevy and Ford guys use only OEM parts?
'63 Dodge 330
11.19 @ 121 mph
Re: How big can you go with after market block? [Re: Dragula] #2948892
07/30/21 04:22 PM
07/30/21 04:22 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
.7854 X 4.5bore X 4.5bore X 5stroke X 8=636 Would require a raised cam block.
Re: How big can you go with after market block? [Re: GY3] #2948897
07/30/21 04:35 PM
07/30/21 04:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I see being wrong doesn't affect your interest in criticizing me...
Boffin Emeritus
Re: How big can you go with after market block? [Re: Dragula] #2948900
07/30/21 04:46 PM
07/30/21 04:46 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Ive got the goodwin and its 648 cubes, and they use a chevy block. These engines are a 5.0 borespace and mopar doesn't make Its sitting in my shop. I have it listed for 40 with the racepak, carbs, converter etc etc. It'll sell for that or ill keep it on display.
Those 655 hemi's and 636 cube deals arent for me, and id never want to make them over 604.... I mean think about it, there isn't an engine with a heavier piston then a hemi, and when you add stroke you are adding piston speed. If you can get it done with less cubes I would. My last street build was a 572, and my new one will be the same only because its not boosted.
Now if it was a wedge engine, i might take the cubes. This would depend on how serious the build was, cylinder head, cam shaft, etc etc...
Re: How big can you go with after market block? [Re: cuda499] #2948923
07/30/21 06:44 PM
07/30/21 06:44 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Doing a KB 636 hemi right now. Raised cam and 5.1 stroke. hell just call my man Charlie Buck and ask for the Big Buck. 959 CID and they cost Big Bucks to.
Todd
Re: How big can you go with after market block? [Re: Dragula] #2948927
07/30/21 06:57 PM
07/30/21 06:57 PM
I think there is combination of bore and stroke (as well as all the other parts) of every type of motor we play with that makes the most HP per C.I. twocents work
Finding what exactly it is the hard part whistling grin
I've said it more than once, it is not JUST the motor that makes the car fast, it is every part being the best for the application your making from the front bumper bolts to the rear bumper bolts scope twocents
Re: How big can you go with after market block? [Re: cuda499] #2949042
07/31/21 03:11 AM
07/31/21 03:11 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
I've drooled over that for a while, since it's based on a chevy block I'm guessing the rear bolt pattern is for 'glides / TH type transmissions ? The 655 we have is a pump gas N/A wedge deal.
Re: How big can you go with after market block? [Re: Tig] #2949079
07/31/21 09:41 AM
07/31/21 09:41 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
655" is the limit. 4.563"x5". Does not have to be a 4.84" BS block. We have done a 645, 4.530"x5" and a 655 Predator engines. I have a 655 in our Dragster. It is a "low compression" smallish cam makes 1100 pretty easily with a single 4bbl on a cast intake.
Re: How big can you go with after market block? [Re: Tig] #2949086
07/31/21 09:48 AM
07/31/21 09:48 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Can I ask why you are so stuck on cubic inch? A 572 built right will make all the HP a stock body small tire car can use. One thing no one talks about with these large cube engines is maintenance. First you need to find a head with a large enough CSA and volume. Then there is valve lift in the 1.00 to 1.30 range. The majority of the 700+ cube motors have Titanium con rods that have cycle life of an aluminum rod. They are not Bracket or street motors. Put a ProCharger on one of your engines and be done.
Re: How big can you go with after market block? [Re: fbs63] #2949119
07/31/21 12:05 PM
07/31/21 12:05 PM
Dragula Offline OP
Dragula  Offline OP
Remember the days of running around town in a stock stroked mopar....Then getting your hands on a good running stroker! Having the cubes is awesome.....Those guys are putting blowers on 9:1 632's....I would like to hit 1000hp some day....I will get my street junk back out to the track somtime this year and see how its running and if I found more HP....I envey you guys with the big engines and +1000hp...Would like to hear about some of them...The wedge based one, and the predators are cool...
Re: How big can you go with after market block? [Re: Al_Alguire] #2949121
07/31/21 12:10 PM
07/31/21 12:10 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Actually that’s incorrect....... the biggest combo I’ve seen is a world cast iorn block 4.560” bore and 5.120” stroke = 668” with an early cast iorn world block or Chicago connection cast block 4.60” bore and 5.12” stroke 680” is possible........
Re: How big can you go with after market block? [Re: boatracer572] #2949137
07/31/21 12:43 PM
07/31/21 12:43 PM
San Jose Ca.
San Jose Ca.
I agree on an earlier post ,no need for that much cid. with out a head to feed that many cubes... the predator head was designed over 20 years ago and hasn't really been updated or the platform built on to another, better head for 2nd gen blocks. i would love to see someone design a head like the hemi 99 to bolt onto a second gen hemi or wedge block, ive been waiting and will be one of the first to buy a set
Re: How big can you go with after market block? [Re: Tig] #2949226
07/31/21 06:50 PM
07/31/21 06:50 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
yes it is, but i have a glide for it as well.
