Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2950221
08/03/21 10:00 PM
08/03/21 10:00 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
I haven't replace an old rubber gasket slider in years. The frames of the factory sliders were wide and require a gasket to fit it. The aftermarket sliders were designed for guys wanting to replace a standard back glass without having to buy a new gasket. If you broke a factory slider, it was cheaper to by an aftermarket slider plus a new gasket
Re: 1985 w150 sliding rear window/ gasket [Re: JDMopar] #2950225
08/03/21 10:08 PM
08/03/21 10:08 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
Originally Posted by JDMopar
Are you looking for the rubber just for the sliding parts of the window, or the whole gasket? Reason I ask, is I used to have an 84 D350 with a solid glass, and a friend gave me a sliding rear window. I had a glass guy come swap it out, and he reused the same gasket that was around the perimeter opening. Of course, this was about 1990 when the truck wasn't very old.
Are you sure your friends slider was factory and not aftermarket
Re: 1985 w150 sliding rear window/ gasket [Re: 58pwrwgn] #2953545
08/13/21 07:01 PM
08/13/21 07:01 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Here's a picture of the rear window. My guess is that it's factory.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 1985 w150 sliding rear window/ gasket [Re: 73cuda340] #2953554
08/13/21 07:44 PM
08/13/21 07:44 PM
5thAve Offline
5thAve  Offline
Looks aftermarket. The factory ones the frame matches the window hole better then that and the ends join at the bottom not some random spot on the side. Unless things changed in the 80s.
Re: 1985 w150 sliding rear window/ gasket [Re: 58pwrwgn] #2953849
08/14/21 08:06 PM
08/14/21 08:06 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
No idea. It was free, other than the $20 it cost me to get it installed by someone who knew what he was doing. It looked very similar to the one in the above post. It moved air thru the non AC truck, and that was all that mattered to me...lol.
Re: 1985 w150 sliding rear window/ gasket [Re: 5thAve] #2953863
08/14/21 08:38 PM
08/14/21 08:38 PM
Guitar Jones Offline
Looks aftermarket to me as well. All the factory ones I've seen had black frames and I've had an 89 and 92 with them. The factory ones sit pretty flush as well. The aftermarket ones not so much.
