70 Challenger dash question #2948276
07/28/21 07:27 PM
07/28/21 07:27 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Other than the limiter what would make the temp gauge and fuel gauge read low... not sure on the oil gauge and I have a volt gauge instead of the amp gauge.. checked grounds and replaced the limiter... thanks
Re: 70 Challenger dash question [Re: 70Challengerse] #2948547
07/29/21 02:16 PM
07/29/21 02:16 PM
moparx Offline
moparx  Offline
aftermarket fuel sending units are known to be inaccurate, and the temperature sending unit may not be getting a good ground due to excess sealing material [tape or dope] on it's pipe thread, or the ohm value may not be the same as the factory original one.
old wiring could also be an issue with too much resistance, bulkhead connections [in the case of the temperature sending unit], or the connections to the sender units themselves could be not making complete contact due to corrosion or misshapen ends.
just a few things to check. i hope this points you in some direction to find the problem[s].
please keep us informed as to what you find.
beer
