Re: Low Oil Pressure After Oil Filter Change
[Re: Mr PotatoHead]
#2950588
08/05/21 07:07 AM
08/05/21 07:07 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
Thank you Mr. P! As I work my way back out of the pan I will check out those areas.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#2950824
08/05/21 08:22 PM
08/05/21 08:22 PM
YO7_A66
Indiana
I got the pan off and found chunks of gasket material in the pickup and in the pan. I was able to scrape some out of the pickup with my finger tip and there is a piece hanging on in this picture. This does not surprise me since I have made three cam swaps with this pan in place over the years.
My next move is to check the bearings.
Note: The existing pump has a HV tag and has been in this engine for 22+ years but only about 5-7k miles.
[Re: YO7_A66]
#2951324
08/07/21 10:47 AM
08/07/21 10:47 AM
YO7_A66
Indiana
I pulled the pump and pickup this morning and found no gasket between the block and pump. Is this correct? All the pictures of new pumps show a gasket. I also found the inside of the pickup to have orange and blue gasket material up inside of the pickup screen. I can’t get the pickup removed or get the screws off the pump cover to look inside.
I am feeling a little weenie thinking about pulling any of the main caps. I’ve never done it before and could use some advice. Thanks!!
[Re: NITROUSN]
#2951384
08/07/21 02:05 PM
08/07/21 02:05 PM
YO7_A66
Indiana
Will the bearing fall out of the cap?
Do I need to wipe off the oil before applying a piece of the plasti-gage?
Thanks again!
[Re: YO7_A66]
#2951708
08/08/21 03:32 PM
08/08/21 03:32 PM
YO7_A66
Indiana
I got some time today to pull the oil pump apart and found some damage to rotor and housing. I also dug out some more crud from the screen. I will check back in when I get some time to check the clearances. Thanks
[Re: Sniper]
#2951737
08/08/21 04:05 PM
08/08/21 04:05 PM
YO7_A66
Indiana
I didn’t pull it apart (I got called in to start the grill), but I will tomorrow. That will be the first item on the list. Thanks
[Re: NITROUSN]
#2951821
08/08/21 06:51 PM
08/08/21 06:51 PM
YO7_A66
Indiana
Nitro: I have ordered a new pump/pickup and while I am waiting on them to be delivered, I will check the bearings. Thank you!
[Re: TJP]
#2951969
08/09/21 09:26 AM
08/09/21 09:26 AM
Posts: 9,434 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Waiting to see some bearing pics.
What rocker arms are you running?
To me overall and with the paperwork it looks like a decent build. I wonder if thats a melling pump or the reman version of the hv72?
How hard did you run this motor?
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2952014
08/09/21 11:39 AM
08/09/21 11:39 AM
YO7_A66
Indiana
Mr P: I hope to get time to look at the bearings this week.
I run Yella Terra 1.65 rockers for about 5 years now on two different sets of heads.
I had not run the motor hard since the cam swap over the Winter. I had put about 4 hours of cruising time on the new cam/lifters and then I changed the break-in oil over to 10W-40. On that first drive on the 10W-40 is when I noticed the oil pressure change during the drive. I just got done with a half throttle hit and then came to a stop sign and I noticed the oil pressure going down. I was actually getting ready to make a WOT hit and that is when I looked at the guage. I slowly made it back to the garage with no extra engine noise. The gauge was showing 25'ish while cruising back to the garage. Ever since this time I have been showing 38'ish on cold startup and then it creeped down to 10 or less at warm idle. Then I started pulling it apart.
Thanks!
[Re: Mr PotatoHead]
#2952166
08/09/21 07:40 PM
08/09/21 07:40 PM
YO7_A66
Indiana
No crud found in relief valve of oil pump. The valve needed a little persuasion to come out though. It seemed stuck.
First bearing cap: please let me know.
