PICK UP COIL ISSUE
#2946114
07/22/21 06:18 PM
07/22/21 06:18 PM
Posts: 10,651 S.E.Ohio
Magnumguy
S.E.Ohio
Lately, I"ve been having what feels like a cross fire issue at idle with my 78 Magnum w/318.
Only does this at idle. If i don't hold the pedal down a tad, it'll die. But starts back up OK. Changed cap, wires, & plugs. Still does it. It has been elect. ign. converted from leanburn. I have no idea how long ago. I bought this from an estate.
Re: PICK UP COIL ISSUE
[Re: TJP]
#2946187
07/22/21 09:44 PM
07/22/21 09:44 PM
Magnumguy
S.E.Ohio
I thought carburator at first, but if you've ever had a cross fire experience, you'd understand what I'm saying. It "bumps" when it occurs.
Definitely not the carb, at least I'm 99% sure on that. Too hard a miss. I lightly cleaned the reluctor and changed the rotor. We'll see.
[Re: Magnumguy]
#2946481
07/23/21 09:02 PM
07/23/21 09:02 PM
Posts: 15,527 Omaha Ne
TJP
Omaha Ne
if you were closer I might have you bring it by and throw it on the scope to confirm your suspicions. And yes I still have a working one Silly question, what are your voltages doing at idle. I ask because if they drop below a given level with electronic ignition it can wreak havoc. You're mentioning that slightly raising the idle makes it stop could indicate a ground, alternator or connection issue Do keep us posted
[Re: TJP]
#2946493
07/23/21 09:47 PM
07/23/21 09:47 PM
Magnumguy
S.E.Ohio
OK, tonight. it ran great till I got it home, idled horribly and kept dying but immediately starts back up. Can't say I notice a voltage drop, but will check that out.
I went out and started it, turned on the headlights and no change. Starts immediately and runs fine when cold. This roughness is after it's warmed up at highway speeds. Almost feels like crossfiring.
Thanks.
[Re: TJP]
#2946582
07/24/21 10:37 AM
07/24/21 10:37 AM
Posts: 1,016 rust belt
Moparite
rust belt
This roughness is after it's warmed up at highway speeds. Almost feels like crossfiring. Sure it's not vapor lock? Put a timing light on the coil wire and look at it. Does it ever stop flashing when the engine is running?
[Re: Moparite]
#2946588
07/24/21 10:55 AM
07/24/21 10:55 AM
Magnumguy
S.E.Ohio
[quote] This roughness is after it's warmed up at highway speeds. Almost feels like crossfiring. Sure it's not vapor lock? Starts right back up. Almost instantly.
[Re: NITROUSN]
#2946633
07/24/21 01:52 PM
07/24/21 01:52 PM
Magnumguy
S.E.Ohio
Plugged carb. When it wants to die try partially choking it to see if it smooths out. I will try that.
[Re: Magnumguy]
#2946776
07/24/21 08:34 PM
07/24/21 08:34 PM
TJP
Omaha Ne
Thanks. I'm getting confused In your original post you said: Lately, I"ve been having what feels like a cross fire issue at idle with my 78 Magnum w/318.
Only does this at idle. If i don't hold the pedal down a tad, it'll die. but now your saying its also "after it's warmed up at highway speeds? The misfiring at hiqhway speeds could be due to a number of things including too much advance. Please clarify
[Re: Magnumguy]
#2946810
07/24/21 10:40 PM
07/24/21 10:40 PM
Posts: 1,757 Phila
PhillyRag
Phila
OK, tonight. it ran great till I got it home, idled horribly and kept dying but immediately starts back up. Can't say I notice a voltage drop, but will check that out. I went out and started it, turned on the headlights and no change. Starts immediately and runs fine when cold. This roughness is after it's warmed up at highway speeds. Almost feels like crossfiring. Thanks. I always treated Misfires/CrossFires as follows: At Idle/Low Speed: focus on primary side of ignition, At High Speed: focus on the secondary side. Also #5 & #7 plugs wire routing.
[Re: SALEM1912]
#2947087
07/25/21 07:33 PM
07/25/21 07:33 PM
Magnumguy
S.E.Ohio
Is the EGR still hooked up? Sticking open at idle? No.
