Re: Metal Building/Garage Recommendations [Re: Cab_Burge] #3108439
01/04/23 02:14 PM
01/04/23 02:14 PM
moparx Offline
moparx  Offline
make sure to build it twice the size you think you need.
it still won't be big enough...... biggrin
beer
Re: Metal Building/Garage Recommendations [Re: moparx] #3108489
01/04/23 03:42 PM
01/04/23 03:42 PM
beer
up Dat be TRUE grin
Re: Metal Building/Garage Recommendations [Re: Cab_Burge] #3108493
01/04/23 03:47 PM
01/04/23 03:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Big as you can. Plenty of electrical outlets. Plenty of lights. Heat and AC.
Re: Metal Building/Garage Recommendations [Re: CMcAllister] #3108723
01/04/23 11:31 PM
01/04/23 11:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
you can always wall off sections not being used on a regular basis. Also lowerin the ceiling where the height is no needed helps
A LOT with lighting, heat and A/C twocents
Re: Metal Building/Garage Recommendations [Re: Chargerfan68] #3108929
01/05/23 01:20 PM
01/05/23 01:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Carolina carports did my Garage & shop, sold through Alans factory, I priced out others & this was in the middle, lots of options, I went with the 12g structure & 26g tin
This is the garage https://alansfactoryoutlet.com/
Re: Metal Building/Garage Recommendations [Re: CSK] #3108931
01/05/23 01:20 PM
01/05/23 01:20 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Shop just done
315786089_5687998094592186_1244097628916862131_n.jpg323116750_545199317327358_4230213059218127532_n.jpg316537112_5707987495926579_5046420100653765971_n.jpg
