Head drawings/blueprints #2943261
07/14/21 09:52 PM
07/14/21 09:52 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Are there any drawings/blueprints getting around for the Gen 3 Hemi heads? I am helping out a friend with a project and a blueprint would save me some reverse engineering.
Cheers
Alan Jones
Re: Head drawings/blueprints [Re: LA360] #2944195
07/17/21 10:04 AM
07/17/21 10:04 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I can't help you with drawings, but I do have a lot of actual cross cut sections of Eagle, BGE 6.1 and pre eagle heads.....I'd be more then happy to share.
I was invited to work on a new Head project late last year, basically raising the "height" of the head from deck surface up , making the intake port more rectangle then square,(2X 2.4ish ) more material under the valve seat for high spring loads....and utilize 5.65-5.85 length valves., 6 & 7 MM stems ..(readily available GM/Ford SB nascar style valves) exhaust port is raised .25 . bolt on rocker pedestals,....... but trying to use stock rockers , oiling would be direct from the block passage and not from the groove(slot) under the head.. the one bad thing as it is right now, end user would have to buy head and manifold package, and height of the intake manifold is obnoxious.. Drag pack on steroids.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Head drawings/blueprints [Re: ric3xrt] #2944488
07/18/21 09:25 AM
07/18/21 09:25 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I'd like to see those heads!
Re: Head drawings/blueprints [Re: fbs63] #2944529
07/18/21 11:43 AM
07/18/21 11:43 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'll get some cross sections up this week,
Re: Head drawings/blueprints [Re: ric3xrt] #2947158
07/25/21 10:10 PM
07/25/21 10:10 PM
LA360 Offline OP
LA360  Offline OP
I am doing some billet valve covers for a friend, he's not found a billet set that clears his T&D rocker arms and fits in his car. I was after bolt patterns and things like that, so I could get a head start on the design, before he ships an example over.
Thanks for your responses though.
Cheers
Alan Jones
