Re: 383 oil pooling on top of valley pan????
[Re: modelmakerinc]
#2942607
07/13/21 12:17 PM
07/13/21 12:17 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I've seen this before, the oil is splashing, seeping, leaking out of the valley pan on the bottom side of the pan and heads, it is not sealing properly. I would try thicker gaskets to seal it better. If that doesn't work you may need to have the intake surfaces corrected to match the angle of the heads. I've seen many aluminum intakes needing that ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I found that out fighting the same thing but mine was sucking the oil into the intake ports, I remove the pan and cleaned up the heads and intake mating surfaces and set the intake on the heads and used feeler gauges to see how much gap was on all four corners at the top and bottom, it was easily measurable so I wrote them down and took it to a good machine shop and they fixed it by surfacing the intake ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: modelmakerinc]
#2942624
07/13/21 12:46 PM
07/13/21 12:46 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Inspect the valley pan for cracks.
[Re: modelmakerinc]
#2942642
07/13/21 01:20 PM
07/13/21 01:20 PM
Posts: 273 Anchorage, Alaska
metallicareload
Anchorage, Alaska
...Too much crankcase pressure maybe or cracked valley pan Absolutely! It almost looks like the pan is bulged up a little, based on the shape of the puddle of oil towards the middle
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: modelmakerinc]
#2942645
07/13/21 01:22 PM
07/13/21 01:22 PM
TRENDZ
Milwaukee WI
Sure looks cracked to me.
[Re: TRENDZ]
#2942693
07/13/21 04:22 PM
07/13/21 04:22 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
It can absolutely come through the threads of the intake bolts if they weren't installed w/ thread sealer.
[Re: DoubleD]
#2942733
07/13/21 07:10 PM
07/13/21 07:10 PM
Posts: 9,101 Rogue River, OR
Jeremiah
Rogue River, OR
Every time I've ever had that much oil on the Valley Pan it was cracked or rusted out.
[Re: an8sec70cuda]
#2942741
07/13/21 07:35 PM
07/13/21 07:35 PM
Cab_Burge
It can absolutely come through the threads of the intake bolts if they weren't installed w/ thread sealer. How? ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Cab_Burge]
#2942931
07/14/21 08:17 AM
07/14/21 08:17 AM
an8sec70cuda
It can absolutely come through the threads of the intake bolts if they weren't installed w/ thread sealer. How? Crankcase pressure causes it to wick up through the threads. Had it happen to me years ago. Thread sealer on the bolts stopped it.
[Re: an8sec70cuda]
#2943000
07/14/21 11:18 AM
07/14/21 11:18 AM
Cab_Burge
That had to be a hoop of crankcase pressure ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) I've not seen that as far as I can remember ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif) My old 415 HP 1963 M.W. Stocker would blow one or both breather caps off in the burn out with 42,000 miles on the original pistons, the top ring groove had over .011 thousands side clearances ![puke puke](/ubbthreads/images/graemlins/custom/puke.gif) That was back when NHRA only allowed OEM stock pistons ![whiney whiney](/ubbthreads/images/graemlins/custom/whiney.gif) I should have had those pistons cut wider on the top ring and used a spacer to tighten up those clearances, hind sight is wonderful, isn't it ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
[Re: Mr PotatoHead]
#2944244
07/17/21 11:41 AM
07/17/21 11:41 AM
TRENDZ
Milwaukee WI
Absolutely needs a better crank case ventilation system, and likely a ring job.
So.... what was the verdict in this?
