Page 3 of 7 1 2 3 4 5 6 7
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2830552
10/08/20 08:43 PM
10/08/20 08:43 PM
Newton, KS
70B5Cuda Online content OP
70B5Cuda  Online Content OP
Newton, KS
Since the TR6060 has a fixed flange (not a slip yoke) I ordered a Magnum conversion kit. This makes the transmission crossmember much easier. Transmission crossmember is in place
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2832108
10/12/20 09:28 PM
10/12/20 09:28 PM
Newton, KS
Newton, KS
Rear end is set up...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2833854
10/17/20 01:06 PM
10/17/20 01:06 PM
Newton, KS
Newton, KS
I sourced the clutch/brake pedals and master cylinder from a 2010 Challenger SRT8. The pedals had to be straightened and shortened but they will work well.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2845882
11/13/20 08:30 PM
11/13/20 08:30 PM
Newton, KS
Newton, KS
Exhaust is mocked up
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2846342
11/14/20 11:13 PM
11/14/20 11:13 PM
Newton, KS
Newton, KS
Front frame rails are reinforced by a bar that runs from the cowl to the front frame rails; the bar also ties into the top of the shock tower. I don't like these types of reinforcements to be in the engine bay. A plate was welded in at each end for the bar to be welded to.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2851079
11/24/20 08:22 PM
11/24/20 08:22 PM
Newton, KS
Newton, KS
I'm going with 2010 Challenger SRT8 front seats so the floor pan profile needed to change. In the first picture, you can see the humps that needed to be removed in order to get the seats to sit lower in the car. The seat motors interfered with the humps and ig pedestals would have been built, the seats would sit too high.
The center of the pans was cut out and a new plate welded in...
Also, the column is now in place...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2861089
12/16/20 11:18 PM
12/16/20 11:18 PM
Newton, KS
Newton, KS
Exhaust is mostly done and brakes have been mounted...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2862086
12/19/20 11:10 AM
12/19/20 11:10 AM
Newton, KS
Newton, KS
The car is now sitting on it's wheels for the first time in nearly 2 years.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2862385
12/20/20 12:22 AM
12/20/20 12:22 AM
Superfreak
Superfreak
Looking really nice.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: ] #2930115
06/04/21 06:50 PM
06/04/21 06:50 PM
Newton, KS
Newton, KS
Thank you!
Time to get back on this Charger. Doors are coming off first to rebuild the door hinges....
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2932129
06/10/21 10:26 PM
06/10/21 10:26 PM
Newton, KS
Newton, KS
Panels and gaps are getting dialed in starting with rebuilding the left door hinges first. Then a relief cut was made along the bottom of the quarter to pull the quarter in at the bottom. Once the door and lower quarter were set, the forward edge of the quarter was adjusted to create an even gap between the door and quarter.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2933404
06/14/21 11:48 PM
06/14/21 11:48 PM
Newton, KS
Newton, KS
The left door had some rust in the corners...which has now been repaired. Also, the AMD rocker was a little too short; you can see it as you follow the door's leading edge gap down to the rocker. It's now been fixed.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2935577
06/22/21 10:37 AM
06/22/21 10:37 AM
Newton, KS
Newton, KS
I may get some static on this post, but the marker lights have been deleted. The wheel lips were also trimmed.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2938977
07/02/21 10:55 AM
07/02/21 10:55 AM
Newton, KS
Newton, KS
A cut was made along the bottom right quarter panel so the quarter panel could be pulled in match the door profile.
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2940169
07/05/21 02:36 PM
07/05/21 02:36 PM
Newton, KS
Newton, KS
Right door hinge was rebuilt and then the right door to quarter gap was set before welding the leading edge of the right quarter...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2942329
07/12/21 01:18 PM
07/12/21 01:18 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Tedious work, but it really pays off when those panels all fit perfectly.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: DynoDave] #2944566
07/18/21 02:23 PM
07/18/21 02:23 PM
Newton, KS
Newton, KS
Agreed!
Next up...fine tuning on the rear valance and valance corners. They always fit terriby.
A pie cut was used to straighten the upper line on the valance.
A pie cut was also made on the quarter just forward of the corner. After...
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 70B5Cuda] #2945141
07/20/21 12:03 PM
07/20/21 12:03 PM
mopar4don Offline
mopar4don  Offline
So because you pie cut the quarter you were not able to weld the valance corner along the flange right?
So where is the valance corner plug welded?
just along the top and at the bottom?
Your work looks great!
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: mopar4don] #2945421
07/20/21 10:47 PM
07/20/21 10:47 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Amazing metal work bringing this charger back to life. Super awesome project
Re: Rough & tumble 68 Charger-6.1L and A518 [Re: 69Cuda340S] #2945862
07/21/21 11:27 PM
07/21/21 11:27 PM
Newton, KS
Newton, KS
