Re: How hard is it to rebuild an a518 transmission? [Re: Hemi_Joel] #2945079
07/20/21 10:19 AM
07/20/21 10:19 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Undercar inspections are a good thing on older vehicles. Every car that comes through my shop gets one before the works starts. You might be amazed at the number of things we have found just waiting to cause a problem. We have also found issues ( normally rust) that caused us to recommend not proceeding with any work short of a complete restoration.
glad you found the issue beer
Re: How hard is it to rebuild an a518 transmission? [Re: TJP] #2945107
07/20/21 11:06 AM
07/20/21 11:06 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
The hose that rubbed through was actually replaced this year, and routed the same as the old one. I had a hard time finding any half inch hose rated for transmission cooler duty. Apparently the new foreign-made hose does not have anywhere near the abrasion resistance as the original hose. Last night I picked up some 3/4-in corrugated split tubing to surround the entire hose to prevent any more rub-throughs.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How hard is it to rebuild an a518 transmission? [Re: Hemi_Joel] #2945199
07/20/21 02:14 PM
07/20/21 02:14 PM
moparx Offline
moparx  Offline
is that "T" gizmo the thermostat that partially blocks fluid flow until the transmission warms up ?
beer
Re: How hard is it to rebuild an a518 transmission? [Re: Hemi_Joel] #2947712
07/27/21 09:55 AM
07/27/21 09:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Seems like back in the day the “slow” leaks would lead to more damage than a sudden loss of fluid where the vehicle stopped moving…. That said we had an old international travel all with a 727 that quit moving due to low fluid more times than I care to think about. Throw 2-3 quarts in and away we’d go! smile
