158 replacement bulb for dash in LED #2931859
06/10/21 06:25 AM
06/10/21 06:25 AM
md
mopars4ever Online content OP
mopars4ever  Online Content OP
md
What part number LED bulb do I need to get as a replacement for the 158 dash cluster bulb? Looking for a brighter white bulb.
Re: 158 replacement bulb for dash in LED [Re: mopars4ever] #2931946
06/10/21 11:53 AM
06/10/21 11:53 AM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
Don’t know which replaces the 158 but I replaced mine 168’s I ended up switching back. They were too bright and no longer the greenish tint. that was all washed out because it was so bright just FYI
Facts are stubborn things.
Re: 158 replacement bulb for dash in LED [Re: larrymopar360] #2931951
06/10/21 12:04 PM
06/10/21 12:04 PM
moparx Offline
moparx  Offline
as i understand it, when replacing regular [white] bulbs with LED's, the LED's must be the color of the required position.
such as red for tail lights, amber for turn signals, etc. for the dash, i would think green would be the correct bulbs to use. shruggy
beer
Re: 158 replacement bulb for dash in LED [Re: moparx] #2931956
06/10/21 12:30 PM
06/10/21 12:30 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
158 168 and 194 are all the same style bulbs. There are other less common numbers, but those are the ones you'll find at most parts stores.
Re: 158 replacement bulb for dash in LED [Re: John Brown] #2931989
06/10/21 01:47 PM
06/10/21 01:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 158 replacement bulb for dash in LED [Re: moparx] #2932179
06/11/21 03:14 AM
06/11/21 03:14 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
beer
Agreed. Unless using a warm white bulb similar to the stock one ( 3000K or so ) the pure white bulbs ( 4000K and over ) will wash the lense color, so better get a colored led for each location if you want to keep the color shade of course.
Cluster light lenses are actually blue, just with stock warm light it becomes greenish, so it at each own choice keeps the greenish look using a green led or reinforce the blue lense color with a blue led.
Take care on get dimmable leds for intensity graduation. Not everyone it is. Driving at nights on dark roads with full cluster light on stock bulbs gets your sight already tired, so using brighter leds it will become worst
Re: 158 replacement bulb for dash in LED [Re: John Brown] #2932180
06/11/21 03:23 AM
06/11/21 03:23 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
The diff numbers on these bulbs is just because the diversity on filament design and wattage. Being leds this is not anymore important, so just need any WEDGE bulb which fits on base. Will actually need to pay attention on the socket code... T3-1/4 is the socket code
Re: 158 replacement bulb for dash in LED [Re: NachoRT74] #2932365
06/11/21 09:12 PM
06/11/21 09:12 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
great info Nacho up
Re: 158 replacement bulb for dash in LED [Re: TJP] #2932477
06/12/21 01:10 PM
06/12/21 01:10 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Strange note on their website: Important Notes
Vehicle manufacturers do not typically release instrument panel bulb information making a lot of this information unavailable. You may head over to our Instrument Cluster & Gauge section to view typical instrument panel LED replacement bulbs. It is important to check your vehicle's instrument panel bulb to confirm the LED replacement bulb is appropriate.
This in green seems to be a good option. They are polarity sensitive so just flip it over if it doesn't come on and CAN bus capable. Hope this all works in older vehicles. https://www.superbrightleds.com/mor...iature-wedge-base-135-lumens/6325/14249/
Re: 158 replacement bulb for dash in LED [Re: NachoRT74] #2932839
06/13/21 03:26 PM
06/13/21 03:26 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Besides the wattage spec and color, note carefully that LEDs will have a different # of smaller LEDS mounted. Also LEDs will have a different types of light output dispersion.
Because of the wide variance, before buying quantities buy a couple of different versions try each then decide what looks best for your application. Over the last few years there have been a lot of advances in various LEDs for automotive applications. I tried at least (5) different versions before deciding on a single 1. Also I would suggest that U purchase a couple of spares for possible future use.
Just my $0.02... wink
Re: 158 replacement bulb for dash in LED [Re: Sinitro] #2932847
06/13/21 03:58 PM
06/13/21 03:58 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I agree! I know they can be problematic so settling on the right one is a good idea!
Re: 158 replacement bulb for dash in LED [Re: larrymopar360] #2932928
06/13/21 08:24 PM
06/13/21 08:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
While on this subject, does anyone have recommendation's of a reputable and reliable source ? I have no problem with Super bright LEDs just wondering of any experiences with sources, good or bad ? There's some bad ones on Amazon per the reviews so I thought while on the subject, Ask Here beer
Re: 158 replacement bulb for dash in LED [Re: TJP] #2933236
06/14/21 03:01 PM
06/14/21 03:01 PM
moparx Offline
moparx  Offline
are there any made in this country, or do all the different vendors get their supply from a couple of chinesium factories ? shruggy
beer
Re: 158 replacement bulb for dash in LED [Re: moparx] #2933266
06/14/21 04:46 PM
06/14/21 04:46 PM
here.
Remy-Z Offline
Remy-Z  Offline
here.
I did an LED conversion kit on my wife's 1980 Mustang and didn't take into account the color difference. Stock is greenish, but the Ford color covers seem thicker than the Chrysler units and I got a funky blue glow. These are the Scott Drake units.
Re: 158 replacement bulb for dash in LED [Re: TJP] #2934085
06/16/21 10:08 PM
06/16/21 10:08 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
Phillips has a good reputation https://www.philips.ca/c-p/194ULWX2/ultinon-led-interior-car-light
I've got them in both Cuda's
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: 158 replacement bulb for dash in LED [Re: Sinitro] #2934961
06/20/21 03:27 AM
06/20/21 03:27 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Agreed! Most of the cases, the correct led bulb selection comes from a tryal and error process.
About dispersion... several tries have been made for this, from a diff led arrangement and quantity to a diff kind of lenses for them ( diff optical dispersion used, or translucent lenses ). What I have seem is that the best kind of led bulb would be the one which looks like this
Instead of these
This is a G4 bulb made for home lamps which I used as an example. The first one shows a led like a continuous ribbon which bends to both sides and makes a continuous dispersion. The other one is more the tipical one being an array of leds. Difference is huge between both. HOWEVER I dunno if auto minibulbs are being made yet like the first one I posted.
Re: 158 replacement bulb for dash in LED [Re: NachoRT74] #2935016
06/20/21 11:33 AM
06/20/21 11:33 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
That's some good info Nacho. I'll have to look for the ribbon like type. Remy, that's what my gauges sort of looked like in my Diplomat my first try when I didn't buy colored bulbs. Washed out the green tint and all looked silver despite the colored caps over bulbs. Now I will buy green bulbs.
Re: 158 replacement bulb for dash in LED [Re: mopars4ever] #2935041
06/20/21 01:09 PM
06/20/21 01:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I do not know if this applies to any of your situations but figured I would mention it.
A recently departed employee left a half finished project with dim dash lights. The entire gauge housing gauges etc. had been replaced. After verifying grounds, bypassing the switch and chasing my tail etc. I dug a bit deeper by taking the original apart.
The original cluster housing was molded out of white plastic and the entire inside was painted a bright florescent green.
The new one was molded out of black black plastic and completely black inside as well shock
I proceeded to do a bit of research und used Rustoleum flat white primer and their Fluorescent Green Spray Paint.
After reassembling the cluster the dash lights are now nice and bright with the recommended bulbs. IMAGINE THAT ? LOL
beer
Re: 158 replacement bulb for dash in LED [Re: TJP] #2935176
06/21/21 03:09 AM
06/21/21 03:09 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Green led lights if you want to keep the greenish shade the originals got due the mix of the warm yellowish white with the existant blue lense, but honestly I think green colour leds are "excesivelly" green, something like the turning lights. I'd use blue or even better warm white ( 2500-3000K ) leds.
As mentioned I dunno if that kind of ribbon leds are used on automotive applications yet.
AND YES, definitelly refinishing the white finish into the cluster housing also helps. Dunno on the fluorescent colour, but sounds interesting.
Re: 158 replacement bulb for dash in LED [Re: NachoRT74] #2935178
06/21/21 03:22 AM
06/21/21 03:22 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
superbright leds got the wedge t3 bulb in all colors and white temperatures
https://www.superbrightleds.com/mor...25-miniature-wedge-base-135-lumens/6325/
As posted by LarryMopar360 on his reply ( sorry bud, I didn't pay attention to the link you posted before.. really running all these days! ), they seem to be at this days the best option of those I have seen. Still dunno how they would light up into the vertical angle thought.
I would put my votes on get simply the 2500K bulbs all around. But I still think 135 lumens is way too much for the number of bulbs used on cluster and still could wash the lense color still using warm white, where incandescent are maybe 15-30 lumens... just my 2 cents.
With 135 lumens you can even light up a small room with 3 or 4 of them. Fortunately they are dimmable.
