Re: Best engine combo for a 9 second Duster!
[Re: 1Fast340]
#2938707
07/01/21 12:34 PM
07/01/21 12:34 PM
Posts: 2,690 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Gen 3 wasn't on his list of engines he wants to use. Lot's of guys aren't comfortable with Gen 3. I love the engine. It looks like the most beautiful combustion chamber in 2V history. But we (the old guys) don't have 40 years of experience with a Gen 3 like we do with the other engines. If a Gen 3 doesn't start there's no way I could ever figure out the EFI/electronics/COP etc.
2011 Drag Pak Challenger
[Re: Hemi_Joel]
#2938711
07/01/21 12:37 PM
07/01/21 12:37 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Heads cost about the same, the only thing more costly on a Hemi vs. wedge is the block and the rockers.
But look at the cost of ownership, factoring in resale. How many used Gen 2 hemis do you see for under $10,000? How many used wedges for over $6,000? You get the difference in up front cost back when you sell. You hemi guys are a riot. I love beating them at the track with my “little block”. Lol 😂 Not sure how some of them squeeze their heads into the helmet.
[Re: pittsburghracer]
#2938712
07/01/21 12:46 PM
07/01/21 12:46 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
I knew the hemibashers would make an appearance. Oh well. He didn't ask for the cheapest motor, he asked for the best.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2938714
07/01/21 12:48 PM
07/01/21 12:48 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I knew the hemibashers would make an appearance. Oh well. He didn't ask for the cheapest motor, he asked for the best. In Your mind maybe. There are cheaper, faster options out there believe it or not. Take off your blinders.
[Re: AndyF]
#2938737
07/01/21 02:03 PM
07/01/21 02:03 PM
Posts: 725 Southern Alberta
Uberpube
Southern Alberta
. If I had a customer who wanted to go rounds weekend after weekend in a 9 second Duster I'd probably LS swap it. And then take out bottom end bearings taking the high G turn into the staging lanes.
[Re: Uberpube]
#2938741
07/01/21 02:19 PM
07/01/21 02:19 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
. If I had a customer who wanted to go rounds weekend after weekend in a 9 second Duster I'd probably LS swap it. And then take out bottom end bearings taking the high G turn into the staging lanes. Or the cam bearings.
#2938771
07/01/21 03:13 PM
07/01/21 03:13 PM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
A basic 500 +/- inch RB w/ a decent set of Indy heads would be my choice. Cookie cutter combo that works.
[Re: an8sec70cuda]
#2938792
07/01/21 03:46 PM
07/01/21 03:46 PM
Posts: 19,391 Las Vegas
Al_Alguire
Las Vegas
My old buddy Bills Demon went 9.30's at 3400lbs all steel all glass with a pretty simple 511" deal with -1 heads. Not even very heavily ported -1's with a jacked up 4 link. We shifted it at 6400! One of the many issues it had when we met he was shifting at 7100 because that what someone told him it needed BUT there is more to getting your car to run well than just the engine. But it dont take a ton of power to run 9's at A body street strip weights for sure. I also built a 511" for a 69 RR nothing fancy Indy CNC head and it can run 9.40's all day long shifting at 6800 and that thing tips the scales at 3720. We are talking 650ish HP to make a middle/high 9 second pass in a typical 3000-3100 A body
[Re: Al_Alguire]
#2940041
07/05/21 04:09 AM
07/05/21 04:09 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
Wonderful replies GUYS! No hemi-bashing please and talk of Chev-lumps is very un-helpful too. Yes lots of Guys have run Chev bigblocks for financial reasons , BUT NOT ME!!! Of course I would run my knackered hemi if I knew it would work. But a 50 year old broken and welded/brazed 426ci high comp 'hemi' is probably 'old hat' these days... So realistic alternatives 'on a budget'? Leaning towards a 512ci with Indy DASH-I's. Or, due to old age and lack of strength (covidity), go small-block with a 408ci engine with Brodix heads? Only ever run a small-block for grocery getting. All the guys I know who run '9 second' 408's are not doing it for very long, maybe one weekend or two at best...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
