Re: street manners of a Comp XS268s in a 499 [Re: Jeff_383] #2937483
06/27/21 10:02 PM
06/27/21 10:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted by Jeff_383
Well I have a 247/255 in there now. Lift is not a concern at 549/571. I can't stop it from bucking when trying to lug it around. I can get idle down to about 800.
What is the LSA on that cam? What is the seat timing on that cam?
Re: street manners of a Comp XS268s in a 499 [Re: BSB67] #2937505
06/27/21 11:07 PM
06/27/21 11:07 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
LSA is 110. Now's where I get my head shaking some, the seat time I don't have in my head. I'll have to look for the cam card from Comp.it was a custom grind and was in my coronet.
Re: street manners of a Comp XS268s in a 499 [Re: Jeff_383] #2937546
06/28/21 07:35 AM
06/28/21 07:35 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
when the cam card is found look to see if the advertised duration is at .020" lobe lift. this is a big deal because actual seat timing with lash will be noticeably greater than the advertised number. even if real seat timing is 290-300 that cam can be tuned some with 499". the fly in the ointment is something like 260@.050". in my experience a long slow cam is easier to tune for the street than a long fast cam. large throttle bore/venturii carbs can add to the low rpm misery index but 499 cubes should soak some of that up. race/performance type single plane intakes aren't your best friend at lower rpm's. i use a multi carb set-up and drive off a pair of fairly small throttle bores which is a big help for low rpm throttle response.
Re: street manners of a Comp XS268s in a 499 [Re: Jeff_383] #2937555
06/28/21 08:25 AM
06/28/21 08:25 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I was concerned about similar problems with my 541. Dewayne helped me tweak a grind to fill the need.
I haven't fired it up yet so I can't give final results but I'm sure it'll do the trick.
- Stu Harmon
