Re: Septic tank additives, what brands are good? [Re: JDMopar] #2945124
07/20/21 11:34 AM
07/20/21 11:34 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've been on a septic system for years. I use whatever chemicals and soaps I feel will do the job I need to do. Some grease from cooking goes down the drain but if it's a large amount I try to pour it into a bottle instead. I've never bought any snake oil for my tank. Had it pumped last year after 5 years of not doing it and everything came out nice and clean.
Re: Septic tank additives, what brands are good? [Re: DaytonaTurbo] #2945144
07/20/21 12:08 PM
07/20/21 12:08 PM
Cab_Burge Offline OP
I'm going to start using yeast in the new tank that I'm going to have installed soon.
I did buy some additive from a local building supply lumber store, it has 4 packages and says to use them 4 months apart, I used one and will use yeast in the new tank from now on.
I'll see what the old tank contents look like when the septic company pumps the old tank out to remove and replace it later this summer, I'll try to remember to post what I find then along with the name of that additive.
Thanks to all of you for the help bow up
Cab
Re: Septic tank additives, what brands are good? [Re: Cab_Burge] #2945223
07/20/21 03:11 PM
07/20/21 03:11 PM
New Jersey
Dartforforty Offline
New Jersey
Cab
So contrary to some comments in this thread, I guess some of us do know how a septic system works and how to maintain them
Ed
Re: Septic tank additives, what brands are good? [Re: Dartforforty] #2945250
07/20/21 04:23 PM
07/20/21 04:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Previous owner never emptied or treated the septic. I had it checked and had it cleaned out when we bought the house. It wasn`t pretty. My county now requires a pump out every 5 years. I actually do mine every about every three years to keep the drain field is good shape. Never had any issues. Honestly I don`t worry about adding any treatment since we pump it so often. I think extra pumpings are cheaper than having to get the drain field redone.
