Re: street manners of a Comp XS268s in a 499
[Re: Jeff_383]
#2937483
06/27/21 10:02 PM
06/27/21 10:02 PM
Posts: 4,312 Prospect, PA
BSB67
Prospect, PA
Well I have a 247/255 in there now. Lift is not a concern at 549/571. I can't stop it from bucking when trying to lug it around. I can get idle down to about 800. What is the LSA on that cam? What is the seat timing on that cam?
[Re: Jeff_383]
#2937555
06/28/21 08:25 AM
06/28/21 08:25 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I was concerned about similar problems with my 541. Dewayne helped me tweak a grind to fill the need.
I haven't fired it up yet so I can't give final results but I'm sure it'll do the trick.
