Re: I lost the rabbit
[Re: VITC_GTX]
#2935177
06/21/21 03:11 AM
06/21/21 03:11 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Unless I'm mistaken, if it's a B/RB/Hemi you should be able to see the lifters for #1 cylinder through the distributor hole. A/LA/Early Hemi/Poly, I've never had much luck with the finger in the spark plug hole with a fresh motor. Off with the valve cover.
[Re: hemienvy]
#2935554
06/22/21 09:05 AM
06/22/21 09:05 AM
Posts: 4,687 Wichita
GY3
Wichita
I took the valve cover off, I think it was leaking anyway.
I have to say, this is a 360 in a 79 D150 half ton. A small block in a truck.
AND THE F-N VALVE COVER ALMOST DIDN'T CLEAR THE BRAKE BOOSTER.
A small block in a truck, not a Hemi in an A-body.
Sheeesh.
Can barely reach the distributor, need scaffolding to stand on. I found it easiest to sit on the inner fender with my feet on the framerails while working on my '75 Powerwagon.
