Page 3 of 4 1 2 3 4
Re: Engine Masters: 6pack vs HEMI [Re: hudsonhornet7x] #2934947
06/19/21 11:37 PM
06/19/21 11:37 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Originally Posted by hudsonhornet7x
but who builds stock displacement engines anymore?
I just did grin
Fair enough lol. What did you build?
Well to be fair to you, the answer to who builds stock displacement engines anymore is probably mostly no one.
I think many prefer a power curve focused on low/lower rpm.
I'm the opposite. I like short gearing and higher rpm, so kept stock crank, ported the heads, single plane intake, higher compression and solid roller.
Re: Engine Masters: 6pack vs HEMI [Re: INTMD8] #2934948
06/19/21 11:46 PM
06/19/21 11:46 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Dana 60 is better than a 9inch…. Change my mind! laugh
Re: Engine Masters: 6pack vs HEMI [Re: moparpollack] #2934963
06/20/21 05:51 AM
06/20/21 05:51 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Originally Posted by moparpollack
If you insure through Hagerty they give you motor trend for free.
MT jumped the shark years ago haven't watched any new content in 3 years.
Had it for free for a year with Hagerty. Did they renew it so you can get another year? I never found a link or email on how to get another year free.
Re: Engine Masters: 6pack vs HEMI [Re: Uberpube] #2934988
06/20/21 10:14 AM
06/20/21 10:14 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted by Uberpube
Originally Posted by 340Cuda
Originally Posted by Cab_Burge
Originally Posted by MoonshineMattK
Anyone watch it? Interesting results. Has me wondering if the cams should have shared the same lift but otherwise been customized to suite each engine best.
How about a link to it so we can watch it help shruggy
They are having a Father's Day sale, $36 a year. Well worth it.
https://www.motortrend.com/news/motortrend-app-fathers-day-gifts/
Deal only available in the US. Bummer.
Can you subscribe at all? Some folks outside the U.S. cannot get it for any price.
I wish you all would open the boarder up and let the racers come see us.
Re: Engine Masters: 6pack vs HEMI [Re: GTX MATT] #2935042
06/20/21 01:14 PM
06/20/21 01:14 PM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted by GTX MATT
I did not know that Stage V made a dual plane? Somehow I suspect that a stock intake would have made more torque.
https://www.hotrod.com/articles/mopp-0310-hemi-426-crate-engine-dyno-test/
This is an article from Dulcich on Westechs dyno from 20 years ago. The otherwise stock 465 HP crate motor he used made WAY more low end torque with more cam with the crate motor intake manifold. How much do you want to bet its actually the same crate engine?
Here's the spec's on that crane cam they used in that article. I run it too with a stage V single plane 2-4 manifold. Dyno pull needed to go up to at least 7500rpm.
IMG_2122-1.jpg09C5A455-D19B-482E-9D1F-59B7E559D409.jpgAEE5A75F-287E-40E6-A15B-E9E31D609C16.jpg
Re: Engine Masters: 6pack vs HEMI [Re: MoonshineMattK] #2935080
06/20/21 04:20 PM
06/20/21 04:20 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I guess the outcome was as one could expect.
anyway it sucks not being able to watch it.
Re: Engine Masters: 6pack vs HEMI [Re: second 70] #2935145
06/20/21 10:14 PM
06/20/21 10:14 PM
Hopefully you ran more valve spring pressure than what the cam card called for luck
There is no way I would run solid roller cam in a hemi with only 450 Lbs. open pressure, maybe a hydraulic roller, bot never a solid roller with that little pressure tsk
Re: Engine Masters: 6pack vs HEMI [Re: MoonshineMattK] #2935199
06/21/21 08:05 AM
06/21/21 08:05 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Some details from the test
the 440 was 9.5:1 compression with 906 heads milled to reduce volume from 87cc to 83cc and a valve job back in 2001.
the 426 was 9:1 with standard iron crate motor heads as cast
On the Hemi, they claimed to be running Ray Barton's valvetrain setup reduced to 1.5 ratio rockers so actual valve lift would be similar
The 440 had the edelbrock six pack manifold
The 426 had a marine style dual plane with two Holleys
I think its important to point out that one engine was built down while the other had a bit of help to make the test more..."equal".
Re: Engine Masters: 6pack vs HEMI [Re: GTX MATT] #2935266
06/21/21 11:28 AM
06/21/21 11:28 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
He said on the show that the engine came out of a car he had, never mentioned it being a crate engine.
They even showed the car on the show.
Re: Engine Masters: 6pack vs HEMI [Re: 73DAD] #2935267
06/21/21 11:29 AM
06/21/21 11:29 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
So glad you wedge guys had no say so when Chrysler decided to build the HEMI. Really could that wedge run 1 2 3 4 at Daytona in 64?
Re: Engine Masters: 6pack vs HEMI [Re: 340Cuda] #2935283
06/21/21 12:58 PM
06/21/21 12:58 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
At the 7min mark onward he said it was a very early crate Hemi.
Re: Engine Masters: 6pack vs HEMI [Re: Cab_Burge] #2935441
06/21/21 10:29 PM
06/21/21 10:29 PM
NW Illinois
MoonshineMattK Offline OP
NW Illinois
This thread did not go in any direction I had anticipated. So HEMI's are junk? Suddenly I'm a man without a country. Without the HEMI residing as the supreme power in the universe I have some soul searching to do.
Jokes aside. I wasn't planning to debate the merits of Motortrend on Demand.
More curious for opinions on cam specs. 549/541 lift seems healthy to me. Never having built or owned a HEMI can't say from experience but would make sense to me that it would need a different cam profile than a wedge at the same lift? Maybe I misunderstood what cams they actually used in the dyno session? Sounded like they were as identical as possible.
Re: Engine Masters: 6pack vs HEMI [Re: cudaman1969] #2935500
06/22/21 01:38 AM
06/22/21 01:38 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Indeed.
We still have time to stop all this Gen 3 Hemi nonsense and re-engineer a head that makes some power. wink
Mo' Farts
Moderated by "tbagger".
Re: Engine Masters: 6pack vs HEMI [Re: Grizzly] #2935508
06/22/21 02:11 AM
06/22/21 02:11 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Like I mentioned earlier
The 440 - 6 came out of a 1971 Dodge Charger R/T many moons ago
Steve Dulchich first car he said - That was the car shown on the episode of Engine Masters
It will go back into the car he said after all these years at some point - He pulled the 440 - 6 out when he was a youngster , one of his first engines he rebuilt and played with
The 426 Hemi is a Mopar Performance Crate motor circa 1994/1995
It is going into a AMC Gremlin on a future episode of Roadkill
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Engine Masters: 6pack vs HEMI [Re: Grizzly] #2935569
06/22/21 10:04 AM
06/22/21 10:04 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Mopar's first V-8 was a Hemi. The only reason they got away from that design was simple economics. When they needed a horsepower boost, they went back to that design. When they needed a modern V-8 to compete globally, they again turned to the Hemispherical combustion chamber. And today, it is the design of choice for the fastest and quickest vehicles on earth.
Does anyone here believe that the current crop of Demons, Hellcats, and Redeyes would be as fast/efficient with wedges rather than Hemis?
Our wedges are certainly great engines. But the hemispherical combustion chamber that allows for a better valve arrangement is simply much more efficient. And when taken to it's logical extremes, cannot be beat. That continues to be proven over and over again. Any mod or improvement to a wedge head can be trumped by modifications to a Hemi head. The only times that a wedge head wins is when a Hemi head is saddled with half measures.
Now, it is a fair argument that in many applications (actually most applications), the additional complexity and expense of the Hemi design is not worth the trouble given the level of performance being sought. But then the argument becomes performance bang-for-the-buck, not overall superiority. Which is essentially the same decision that Mopar came to in the late 50s.
Master, again and still
Re: Engine Masters: 6pack vs HEMI [Re: 73DAD] #2935598
06/22/21 11:53 AM
06/22/21 11:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I thought we were talking about the 440, I may have misunderstood.
Re: Engine Masters: 6pack vs HEMI [Re: 340Cuda] #2935622
06/22/21 12:45 PM
06/22/21 12:45 PM
moparx Offline
moparx  Offline
i thought the GEN III hemi is not a "true" hemi ? shruggy
beer
Re: Engine Masters: 6pack vs HEMI [Re: DaveRS23] #2935758
06/22/21 06:20 PM
06/22/21 06:20 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I'm not smart enough to explain why but I remember Monte Smith always mentioning the Hemi was best suited to boosted applications. For N/A or on spray, a canted valve style head with symmetric exhaust ports was the best option.
Re: Engine Masters: 6pack vs HEMI [Re: moparx] #2935881
06/23/21 02:35 AM
06/23/21 02:35 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
beer
As far as I can tell it's the best of both worlds, the quench pads combined with the dome are Engineering brilliance. twocents
Mo' Farts
Re: Engine Masters: 6pack vs HEMI [Re: Blusmbl] #2935940
06/23/21 10:06 AM
06/23/21 10:06 AM
The Great White North
RAMM Offline
RAMM  Offline
It's because of the already "softened" chamber<<< I dislike that terminology--It's scalloped IMO. The HEMI has a factory scalloped chamber that widens the tuning window significantly under power adder applications--Basically the HEMI chamber is a slow burning chamber which is why when you add a second plug--things change so much. Hate to say it but a single plug wide open 170cc chamber is inefficient. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Page 3 of 4 1 2 3 4
