It was really clean at the ports, not so much further up inside shruggy
I had done the bead blasting due to seeing grind marks at the edges of several of the ports and thought some one before me had done the grinding to remove casting burrs, turns out that was done at the foundry S.O.P. by Mopar shruggy
