N2O fuel system #2932525
06/12/21 03:03 PM
06/12/21 03:03 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I have a N2O kit, fogger and plate, was thinking of running the plate. I was wondering if anybody has run a separate fuel system for the N2O up in the engine bay....like maybe where the battery used to be. I'd think it would be a much easier install. Bottle would be in the trunk.
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2932551
06/12/21 04:59 PM
06/12/21 04:59 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
It's been done, but you'd better have some kind of low fuel level (or pressure) cutoff for when your little fuel tank runs out! shock I'm not crazy about having a tank of fuel next to the headers, either... may not be allowed at the strip.
How much nitrous are you planning to run? And how big is your existing fuel line/pump? work
Re: N2O fuel system [Re: DrCharles] #2932555
06/12/21 05:17 PM
06/12/21 05:17 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
it would be nowhere near the headers. I'd probably check it after every pass and only a 100 shot to start with. This engine is supposed to make around 700 N/A. I have a big Eddy pump 1/2" all the way up. Can't remember the #.
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2932570
06/12/21 06:00 PM
06/12/21 06:00 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Like the master cylinder on my car,Insulate it and the a metal shield maybe polished aluminum.
Re: N2O fuel system [Re: Clanton] #2932739
06/13/21 10:06 AM
06/13/21 10:06 AM
sweden
carter Offline
carter  Offline
sweden
We may have same thoughts about a fuel tank in engine bay, I weld this little tank for a small nitrous system.
Re: N2O fuel system [Re: carter] #2932747
06/13/21 10:32 AM
06/13/21 10:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
For a 100 shot I would just add a regulator to the existing system. No need for a stand alone fuel system for a 100 shot unless you are really close to maxing out the current pump and lines.
Re: N2O fuel system [Re: carter] #2932785
06/13/21 12:15 PM
06/13/21 12:15 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
that is what I was thinking about.
Coming soon!!!!
Re: N2O fuel system [Re: Jeremiah] #2932788
06/13/21 12:18 PM
06/13/21 12:18 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I have a fogger system as well...not sure I will ever use it but I'd like the option down the road. I could "T" off the existing I guess. I have -10 all the way up.
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2932799
06/13/21 12:35 PM
06/13/21 12:35 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That tank looks way too big in my opinion.You only want to have enough fuel for 2 runs[100 or 200hp] and I think that would only be 1 gallon so another 1/2 for safety.
Re: N2O fuel system [Re: Clanton] #2932812
06/13/21 01:27 PM
06/13/21 01:27 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I was thinking 1/2 gallon, I'm only going to use it in 2nd and 3rd.
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2932823
06/13/21 02:27 PM
06/13/21 02:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The smallest fuel cell is probably 1 gal off the shelf.
Re: N2O fuel system [Re: Clanton] #2932825
06/13/21 02:33 PM
06/13/21 02:33 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
they make 1/2 gallon purge tanks, wonder if I could modify that...
Re: N2O fuel system [Re: Mr.Yuck] #2932827
06/13/21 02:40 PM
06/13/21 02:40 PM
sweden
carter Offline
carter  Offline
sweden
It may look big, but it's holds 4,1/2 quarters. And you don't have to topp it when you fill it up in hot engine bay. I thinking it so easy to overfill a tiny tank panic
Re: N2O fuel system [Re: carter] #2932828
06/13/21 02:46 PM
06/13/21 02:46 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I see the battery tray now sorry but it looked deeper.ty!
Re: N2O fuel system [Re: Mr.Yuck] #2932875
06/13/21 05:16 PM
06/13/21 05:16 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
No mention of what
Your fuel system is now , but a standalone under the hood is not really needed if you have a decent pump for the engine . Just need sepereate regulator for the nitrous system
....BAD A$$ STREET CAR.....
Re: N2O fuel system [Re: n20mstr] #2932894
06/13/21 06:23 PM
06/13/21 06:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What do you have for a fuel pump,filter and lines? With an ample pump you can install a splitter and new fuel regulator.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: N2O fuel system [Re: hemi-itis] #2932902
06/13/21 06:35 PM
06/13/21 06:35 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I can't recall the Eddy pump, it is a big one -10 up I run a big filter
Coming soon!!!!
Re: N2O fuel system [Re: Mr.Yuck] #2933053
06/14/21 05:35 AM
06/14/21 05:35 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use a JAZ Jr. Dragster fuel cell located on the core support where the horns normally go. I mounted an electric pump below it. Works perfectly.
'63 Dodge 330
11.19 @ 121 mph
Re: N2O fuel system [Re: GY3] #2933074
06/14/21 08:29 AM
06/14/21 08:29 AM
an8sec70cuda Offline
Years ago I ran a small 1 gallon cell where the battery used to be on my cuda. Mounted a Holley blue pump underneath and fed a plate system w/ it. It worked good, but I wouldn't do it again.
I'd "T" into your current system ahead of your carburetor regulator and feed a separate nitrous only regulator from there. It'll be a much cleaner looking setup IMO.
AS far as comments about the size of the cell...A 1/2 gallon would last a LOT longer than you'd think w/ a small shot.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: N2O fuel system [Re: an8sec70cuda] #2933078
06/14/21 08:56 AM
06/14/21 08:56 AM
UK
rb446 Offline
rb446  Offline
UK
Way back in the 80's/early 90's, I got the N20 bug, read up a lot about it and decided that the N20 fuel was very important to keep volume there for hp and tune ability of pressures, like most of us we start out with a 100 shot but want the capability to go to 250+. On my '71 340 street/strip car we drilled the stock tank for 2 x 1/2" outlets and I had 2 blue pumps, 1 for N20 only with 1/2" lines to front. On the '69 440 race car the same with a fuel cell in the rear. Not necessary to go that route for smaller shots, a tee off is adequate in most cases but if your gonna get a bit serious thats what I would do and not because of any lean out cos lean won't kill the motor, you just won't make the power, too much timing on a lean jet spread will do that.... twocents
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
